11-14-2007, 01:09 PM
#1561 |
Sooper Brane
Oddometer: 14,031
I cut the rod in half and made two supports. I broke one side and ended up making these out of steel.
Everyone is entitled to my opinion. |
11-14-2007, 01:32 PM
#1562 | |
Once you go Triple...
Oddometer: 20,485
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
11-14-2007, 01:33 PM
#1563 | |
Oddometer: 20,485
![]() The other one is fine for a car but just a bit too big to carry on a bike. I am going to order a couple of these. Thanks
11-14-2007, 02:48 PM
#1564 | |
Havagoowan
Oddometer: 2,019
11-14-2007, 03:08 PM
#1565 | |
Oddometer: 1,431
I got the regular pivoting (not anti-vibe) 2 inch 7/8 to 1 1/8th risers. Clearance on the tank is fine and stock cables are fine with my Pro Taper RM mids. |
11-14-2007, 03:26 PM
#1566 |
Whenindoubtthrottleout
Oddometer: 37
My 06 xrl
Here's a couple pics of my xrl
Never mind the "R" behind it. I know its forbidden in this thread. I really hope the link works!!!!! Photo noob. |
11-14-2007, 03:48 PM
#1567 | |
Havagoowan
Oddometer: 2,019
11-14-2007, 03:50 PM
#1568 | |
Havagoowan
Oddometer: 2,019
11-14-2007, 10:48 PM
#1569 | |
Yea, its a friggin L
Oddometer: 1,765
Is that an aftermarket seat or just a seatcover? Can you post a few more pics?
BP Quote:
11-15-2007, 12:15 AM
#1570 | |
Wannabe Adventure Tourer
Oddometer: 2,019
BTW, what problems are there installing the Acerbis tank?
Ciao Doghouse Canis meus id comedit. |
11-15-2007, 06:47 AM
#1571 | |
Oddometer: 20,485
11-15-2007, 12:12 PM
#1572 | |
Havagoowan
Oddometer: 2,019
As far as problems go, I guess you have to relocate your blinkers, and shave down those "pins" that are welded to the frame. I don't know what to call them, but those things the slots on the OG tank fit on. I've also heard the bar lock doesn't work with that tank, but I'm not sure how true that is??? |
11-15-2007, 12:14 PM
#1573 | |
Havagoowan
Oddometer: 2,019
![]() You know what though, I bet you can just order the petcock adapter from Clarke, an OEM petcock from Honda (or just some sort of valve), drill a hole, and mount it right up. From there, just get yourself some automotive fuel line, a brass T, and set it up. |
11-15-2007, 02:21 PM
#1574 |
Oddometer: 100
Acerbis tank
Acerbis tank issues were, like stated earlier having to relocate blinkers up about 2" or so, cut pins off the frame, and relocate my regulator. I welded a bracket to the tube support that came w/ the acerbis tank. So i then just screwed the regulator to that instead of the frame. Some people have said they didn't get the full benefit of the reserve because the carb is located higher than the lowest part of the tank. I've never ran my gas that low to really know, but it doesn't look like there will be a problem with that. If i was that low and the reserve gas wasn't feeding through gravity feed, i guess you could try and tilt the bike to consolidate it all into one side.
Its a much tighter fit than the stock or the clarke 4.7gal tanks ive dealt with before. I think its worth making sure everything is seated correctly and firmly, and not rubbing up against anything , like the regulator for example. Its so big it can be hard to see underneath to fit it all together the first time. That being said i love my new tank, and dont understand why nobody else uses double petcocks, just makes too much sense? maybe. |
11-16-2007, 05:54 AM
#1575 |
Sooper Brane
Oddometer: 14,031
I guess I'm old-school...I just lay my bike on it's side to get the fuel on the petcock side.
