Old 05-05-2010, 09:46 AM   #17251
gottyours
smog sucks
gottyours's Avatar
Oddometer: 86
Question Cam
Hey Steve...
How is that 148x9 cam. Sounds like you have run it. Is it an all around or mid to top. Xrs is wanting me to go with a cam they have called x9. But they haven't been able to get me specs on it yet.
gottyours is offline   Reply With Quote
Old 05-05-2010, 09:50 AM   #17252
prince_ruben
prince_ruben's Avatar
Oddometer: 1,734
Originally Posted by mcma111
A 9:1 piston is not much of an improvement over the OE. Try 10:5. A Mikuni pumper should be OK. The Keihin may be better but it's more $$. I always use Mega Cycle cams. Your gonna need a pipe to go along with all this so it can breathe.
Cool. 10.5 it is. As far as pipes, I have the FMF Q4, but should I get the bigger header?
No worries in death, no worries in life.
prince_ruben is offline   Reply With Quote
Old 05-05-2010, 10:03 AM   #17253
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,352
You Suck.
Gotta act fast around here.
Congratulations B.
Thanks boss
HEY I GOTTA BEAT YOU TOO IT AT LEAST ONCE IN AWHILE
Now onto chain buying....looking at RK GB520GXW What you think,decent chain...
B
techforlife is offline   Reply With Quote
Old 05-05-2010, 10:09 AM   #17254
techforlife
CDI REPAIR
Oddometer: 4,352
Originally Posted by prince_ruben
The rockers are OEM and I actually adjusted the valves so it's m fault the lock nuts came off. I didn't tighten them enough. I rode home 1/4 of a mile and parked the bike so that's probably why there isn't more damage. The adjusters are longer because the eventually rose/backed out because the lock nuts weren't in place. The rockers looked fine though.
I do think one nut fell through the cam chain assembly because I can't find it but I'm taking the cam chain off tonight as well as the head.
Steve, I'll pull the clutch cover off as well. At this point I want to upgrade the motor with the XR head work.
Man I'm lucky, but I'm not giving up!
CHECK THAT CAM CHAIN REALLY WELL..
IF that nut went down that way it might have nicked,chunked,beat that cam chain,,look at it really closely,and the gears it runs on,,,,,,,,,barring that,,i`d do what MCMA111 said,,adjust it up properly and see what happens
B
Old 05-05-2010, 10:19 AM   #17255
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
B
I think thats the chain I have... works well so far.
Bbasso is offline   Reply With Quote
Old 05-05-2010, 10:54 AM   #17256
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
B
What? That pic I posted scare you???
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 05-05-2010, 11:46 AM   #17257
mcma111
mcma111's Avatar
Oddometer: 12,880
Cam
Originally Posted by gottyours
Hey Steve...
I have the Mega Cycle 173x25 cam in my XR600 w/ 654 piston and in my son's and buddies 2 XRL's. All the XRL's are 675cc. It works well. Actually I haven't even replaced the valve springs. All stock springs. This is a drop in cam. Works with a stock piston, springs. No mods necessary to install.
I was thinking of the 173x9 for Wattner because he will be doing the 720cc and with the longer duration and higher lift it will give the engine more time to get the fuel charge into the cylinder.
Go here: http://www.megacyclecams.com/
Down load their catalog. Page 30/31 for the XR/XRL specs.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 05-05-2010 at 11:51 AM
Old 05-05-2010, 11:47 AM   #17258
mcma111
mcma111's Avatar
Oddometer: 12,880
Header
No need. Just grind the inside welds at the head connection.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-05-2010, 11:49 AM   #17259
mcma111
mcma111's Avatar
Oddometer: 12,880
Shark Fin
Thanks boss
B
B.
I saw that within minutes of it's posting. I didn't think it looked as good as it does due to his picture of the fin. I thought about it though. RK chain is good stuff.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-05-2010, 11:55 AM   #17260
prince_ruben
Oddometer: 1,734
Where'd you get the 675? Thumper Racing?
Old 05-05-2010, 12:39 PM   #17261
techforlife
CDI REPAIR
Oddometer: 4,352
Originally Posted by WhereAmI
So I just got my bike back.First time I've seen it since the crash and from what I can see the clutch lever snapped off and the exhaust can is toast the header looks fine.What exhaust would you guys suggest.The previous owner jetted it but no sign of dave's mods,a k&n filter and a sumo setup.I really liked that the White bros can was adjustable and with no plates still had decent low end torque with enough top end to keep up with highway traffic on 15/48 gearing I know I just missed the xr's can.I would think noise is of no concern because an e-series running straight open is a loud fire breathing beast but I still have a while as I'm laid up with a broken leg
Sorry to hear about the leg...........
Can i call you Hop Along Cassidy now
Kiddin.....
Look,,unless you like alot of noise,,get the FMF Q4......you really are not going to get anymore flow than that,and it sounds really nice..
B
Old 05-05-2010, 12:43 PM   #17262
techforlife
CDI REPAIR
Oddometer: 4,352
John
Well honestly,,,,,,,yes
My chain, if you shake it up and down ,now rattles ,,,the front sprocket has hooked teeth,,,and the rear teeth are really bad,you can move the chainback and forth on the sprocket teeth...
Think i should wait a little longer
B
Old 05-05-2010, 01:07 PM   #17263
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
Wish me luck...
I'm going to attempt my first tire/tube change on a motorcycle.
Old 05-05-2010, 01:23 PM   #17264
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
River run 2010
Just got back from a trip up the Mississippi from Prairie Du Chein to La Crosse, Drove up on the Iowa/MN side. It was a great ride. The XR worked very well with it's new Highway pegs and wind screen. The new wind screen does not buffet at all. And let me tell you it was plenty windy. We did a small section of gravel road (I was the leader with the only GPS) on accident. The cruiser dudes were pretty whinny about the 2.5 miles of gravel.
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 05-05-2010, 01:33 PM   #17265
O Captain My Captain
Modern Day Walter Mitty
O Captain My Captain's Avatar
Oddometer: 506
Originally Posted by Bbasso
Wish me luck...
Godspeed.
O Captain My Captain is offline   Reply With Quote
Times are GMT -7.   It's 10:03 AM.
