05-07-2010, 06:09 PM
#17371 | |
CDI REPAIR
Oddometer: 3,310
Yes,,,,,,Both were OE RK i believe,,,and i use chain lube too..... B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
05-07-2010, 06:11 PM
#17372 | |
CDI REPAIR
Oddometer: 3,310
Brian
05-07-2010, 07:21 PM
#17373 | |
M0DAH0LIC
Oddometer: 1,943
This is it
![]() It's pretty straight forward and simple and subject to change when my windshield shows up
05-07-2010, 07:27 PM
#17374 |
M0DAH0LIC
Oddometer: 1,943
Back in the saddle
Well I got my chain installed
![]() but I still have this little problem ![]() I have a sprocket cover/case saver from XRs only on the way but I wanted to put something on there. I found out that the reason I couldn't shift the bike out of gear was because the chain was wedging the shifter down so apparently the only damage from my chain was the sprocket cover and the chain it's self. -Barron |
05-07-2010, 07:51 PM
#17375 |
Oddometer: 899
Barron thanks.
I got 19000 miles out of my stock set. Probably could have pushed it farther. I tried to save moeny and bought the Primary drive set 14/48. I don't have much on it but I can see that it won't last too long. That crazy break in the chain has me reconsidering using the chain. I have a 15/45 coming just in case it pooches earlier than expected.
Riding something on two wheels |
05-07-2010, 08:10 PM
#17376 | |
Gnarled up Northerner
Oddometer: 710
I've only got 7500 kms on my bike, and I'm on my third chain ... it amazes me how you guys make your chains (and sprockets) last so long.
~You don't stop riding because you get old, you get old because you stop riding~ |
05-07-2010, 08:34 PM
#17377 | |
Hold On Loosely
Oddometer: 422
Thanks. |
05-07-2010, 11:31 PM
#17378 |
Oddometer: 1,023
Chain life
This is What my chain life has been.
At 13,700 miles replaced original DID O ring chain with new Did O ring chain. Replace sprockets with Suntour sprockets. Replaced Chain slider. It was worn through and chain was rubbing swing arm. 25,172 Replaced chain with DID O ring chain. Replaced chain slider. At 25490 replaced both sprockets. (They were back ordered) 33,200 replaced chain and sprockets. DID O ring chain suntour sprockets. 47,030 Replaced chain, DID non O ring. Replaced sprockets, suntour 48,153 Replaced chain with DID O ring chain. (Master Link broke) 55,144 In preparation for a long trip, replaced chain with RK X ring chain and new suntour sprockets. This chain and sprocket set were not wore out. I just didn't want to deal with finding a new chain and sprockets on the road. I'll finish them off later. Current milage on the bike is 67,833. On the first 2 chains I use chain wax for lube. After that I have used PJ1 black label. Chain wear has been comparable with both lubes, but I have not worn out a chain slider since switching to the PJ1. Walter
"How much a dunce That has been set to roam Excels a dunce That has stayed at home." |
05-08-2010, 01:57 AM
#17379 | |
TAT'erd
Oddometer: 1,815
John
Endeavor to suck less--Gaspipe I would rather be riding an imperfect bike than waiting around for perfection. --JDowns |
05-08-2010, 02:10 AM
#17380 | |
M0DAH0LIC
Oddometer: 1,943
Sprocket cover/case saver
http://www.xrsonly.com/content/index...mart&Itemid=70 I could have replaced it with an OEM one but I have wanted one of those things for a while. Until now I just couldn't see spending the cash on it, but since I have to replace it anyway... -Barron |
05-08-2010, 05:01 AM
#17381 | |
Oddometer: 769
I found out why my highway ride was so bad, bent front rim. Maybe I should look into some IRC GP110's too |
05-08-2010, 07:07 AM
#17382 | |
Oddometer: 899
05-08-2010, 09:23 AM
#17383 | |
Oddometer: 1,023
Yes Walter
05-08-2010, 09:31 AM
#17384 | |
Oddometer: 1,023
Walter
05-08-2010, 09:49 AM
#17385 | |
CDI REPAIR
Oddometer: 3,310
Sweet,gotta like that all that got damaged was the chain cover That`s a pretty crazy airbox cover... B
