Old 11-06-2010, 10:59 AM   #21226
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,953
While we are still on the cam damage issue,........ Did'nt someone say something about a "Mod" for the upper banjo bolt on the oil line that gives more oil to the top end? Is this just an additional part # from Honda? or is it a Mod to the existing bolt? Sorry if I missed the post on this, and Thanks for any info. on this.
Boojum
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly"
BMW's: 1999 GS 1100 "Work Horse", 1975 R90/6 "Black Betty", 92 R100 GSPD,
03 XR 650L with Farkles, KLR 250, 72 Honda CL-70
Boojum is offline   Reply With Quote
Old 11-06-2010, 11:24 AM   #21227
mcma111
mcma111's Avatar
Oddometer: 12,088
Oil Bolt Mod
There are two different bolts for the upper end oil feed line. The lower bolt has a slightly larger hole than the upper bolt. Why Honda uses two different bolts I don't know but they do. So the mod is to replace the upper bolt with one of the lower ones. I didn't know that there was a difference and when I checked my bike I had them reversed. Opps. Oh well, no damage done. I found a larger holed bolt in the bolt box and swapped it in.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-06-2010, 11:30 AM   #21228
Boojum
Boojum's Avatar
Oddometer: 5,953
Thanks Steve! So I can just order a "bottom bolt" and swap out the existing "top bolt".........................Cool!
Boojum
Old 11-06-2010, 11:39 AM   #21229
truck6driver
The Fireman
Oddometer: 7,436
Boojum
Was told by the service manager at the dealer the upper bolt is to retain oil pressure and keep from putting too much oil in the top end.
That said I also have not heard of problems from those that did the "Mod".
I have seen the upper bolt and lower drilled out to a larger size but I do not recommend that.
Now I have not used an aftermarket cam but at 15,000miles I did have to replace the stock cam and rockers because of scoring on the rocker faces and cam lobs. Once it starts you cannot stop it. Only reason I found it was a countershaft spline issue that was being replaced and saw the damage during tear down.
Ray
When the system fails you, what then?? Do you fight it or just surrender and give up? If all seems doomed what is left to fight for? Is it just me or does the world seem to close in on you when you seem to be making ground? Options are dwindling down, what comes next? And in the words of Pink Floyd "Is there anybody out there". All I know is I WILL SURVIVE.
truck6driver is offline   Reply With Quote
Old 11-06-2010, 01:07 PM   #21230
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Supposedly the RS600 flattrack engine from HRC used a larger oil line and possibly different bajo bolts. The oil pump is supposed to move more volume as well. That info did not come from a reliable source, so take it with a big grain of salt. RS600 parts are like hen's teeth anyway.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 11-06-2010, 01:40 PM   #21231
mcma111
mcma111's Avatar
Oddometer: 12,088
Oil Flow
I don't know how much an over size oil feed line or banjo bolts will feed the top end but I do know the limiting factor is the oil feed holes in the cam that WILL limit the amount of oil flow. It's like a nozzle on a hose. I don't care how big the hose is, it's the hole in the nozzle that decides how much water will come through. And no, increasing the feed line and banjo bolts will not effect oil pressure. That is the oil pumps work.
My .02 but I may be wrong. Have been before.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-06-2010, 03:58 PM   #21232
kubiak
Oddometer: 4,829
Boojum
i did the oil line bolt swap about 700 miles ago and the topend on my xr with 54,000 miles seems much quieter. you can drill the top bolt the same size as the bottom but i just bought a new bottom bolt from honda, i think it was around ten bucks. if you compare the hole size the bottom bolt looks to be a bout twice the size as the top.
Old 11-06-2010, 04:21 PM   #21233
Boojum
Boojum's Avatar
Oddometer: 5,953
That's It,............. I'm gonna do it. I'll call my friend (parts mgr. @ honda) and let him tell me I'm Stupid, yada-yada.......... and then perhaps order it online. The theory works for me.
Boojum
Old 11-06-2010, 05:22 PM   #21234
rrittner
SometimesY
Oddometer: 251
XR's only temp dipstick & Magnetic drain plug
I have a used XR's only temp dipstick used red, and it does fog up on rainy days, also an unused engine oil drain plug magnetic also in red.
$20 shipped.
I installed a vecter computer that has a temp sensor. The drain plug was a wrong purchase, I thought I was buying the frame oil drain plug.
send me a pm, I take paypal. I'll send a picture if interested.
rrittner is offline   Reply With Quote
Old 11-06-2010, 05:28 PM   #21235
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,305
$20 shipped.
PM sent........
B
techforlife is offline   Reply With Quote
Old 11-06-2010, 05:35 PM   #21236
mcma111
mcma111's Avatar
Oddometer: 12,088
B,
Isn't that magnet in the clutch cover gonna get jealous ??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-06-2010, 05:44 PM   #21237
techforlife
CDI REPAIR
Oddometer: 4,305
B,
You can have the magnet oil plug..........my 7 pound magnet in the clutch cover is quite enough.........i gotta clean nails,bolts and shit off the case bottom as is
B
Old 11-06-2010, 05:48 PM   #21238
mcma111
mcma111's Avatar
Oddometer: 12,088
Magnet
B,
Hey, Does your magnet trip signal sensors at intersections??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-06-2010, 05:54 PM   #21239
techforlife
CDI REPAIR
Oddometer: 4,305
B,
No,actually......i was talking to a cop last week about this,believe it or not.....i get to some intersections and the f`ing lights won`t change.....i asked him if i had to stay at the light all day until a car rolled up,or can i do a stop and go...he said i can`t go through a red light........and offered no advise.....so screw-em....i`ll wheelie through.....uncycles are allowed i think...
B
Old 11-06-2010, 07:37 PM   #21240
mchester
Honda Cult Member
mchester's Avatar
Oddometer: 1,462
Originally Posted by flatfender
How did you get a pod filter air inlet higher than the air box inlet? (assuming the air box inlet you're talking about is the one on the top of the air box)
yeah the stock air box is not water tight unless you add your own gasket or bead of silicone.
Sorry, no, I meant the intake tract that comes from the airbox. IF you managed to seal up the airbox, then you could get the intake height to just under the seat, but I think it'd be pretty difficult to seal that side panel and still have it be easily removable with the Dzus fasteners as it is OEM.
"I intend to live forever. So far, so good" Steven Wright
"If you choose not to decide, you still have made a choice" Rush
2004 XR650L & 2003 ST1300
mchester is offline   Reply With Quote
Times are GMT -7.   It's 12:25 AM.
