Old 03-20-2008, 04:13 PM   #2146
heetseeker
Hopelessly addicted
heetseeker's Avatar
Oddometer: 370
Originally Posted by cornelieaz
Hello my friends.
What brand of fairing is that? How's the lights at night?
GS 1200, 12' EXC 500, ktm sx250, RZR 900 XP
PDMC 38x
heetseeker is offline   Reply With Quote
Old 03-20-2008, 05:28 PM   #2147
BeeDub
Havagoowan
BeeDub's Avatar
Oddometer: 2,022
It appears to be one of these, but I have no idea how well it works at night...
http://www.acerbis.com/p107_headlight/3002.html
BeeDub is offline   Reply With Quote
Old 03-20-2008, 07:17 PM   #2148
cornelieaz
Oddometer: 2
Acerbis Cyclops indeed. It's a good light. You've got:
Bulb 1. 55w. Great for distance output. Very "beam" like.
Bulb 2. 55w. Great for side to side coverage. No good for distance.
Bulb 3. 5w. Inside the "beam" light, Does nothing for the bike operator, but does light up the second light to be seen by other drivers when you're using only the wide angle light.
I feel comfortable just using bulbs 2 and 3 for cruising, and bulb 1 on it's own for higher speed travel. Running both 55w bulbs together would be about the same feel as the stock light but with a bit more distance coverage.
cornelieaz is offline   Reply With Quote
Old 03-20-2008, 07:53 PM   #2149
murgatroid42
Great Adventurer
Oddometer: 4,185
Originally Posted by Hawkesroost
Engine should run quiet and smooth, no clicking or tapping.
Check for oil leaks and hits to the engine cases.
Suspension front and rear, good compression and rebound.
No leaks on front or rear seals.
Chain and sprocket wear. With 2k miles these should be in fine shape.
Wheels run true, no big hooners in the rims.
Check all electrical, lights horn, signals.
Ride it, Gears shift smooth, steers straight when you let the bars go, brakes work good.
Look at the way he keep his shop or garage, it will tell you alot about how the bike way taken care of.
Ask lots of questions.
Then wheel and deal and buy it, XRL's are cool.
All good advice, I'll add my additional $0.02 for t burson56:
Take it for a test ride. Shift from first to second and back, at higher RPMs. If the bike grinds gears going into first or second, beware, that's a weak point on these bikes.
- Find out if the owner maintained it. Did he adjust the valves, change the oil? Look at the oil. Listen to the valves.
- It probably has the orginal tires. Look for cracks in the sidewalls. After 8 years, the probably need replacing anyway, and the stock ones are not great on dirt. Use it as a bargaining chip to reduce the price.
- The XR650L's are very reliable, and 2000 miles is very little. If it hasn't been beat or neglected, go for it.
"We hang around people who think these activities are normal."
"Me and gravity, we are really, really good friends." - Streetbike Tommy, Nitro Circus
"I'm a dude in his mid-40s, who acts likes he's in his 20's. But I don't plan on stopping any time soon." - Ken Block
murgatroid42 screwed with this post 03-20-2008 at 08:03 PM
murgatroid42 is offline   Reply With Quote
Old 03-23-2008, 11:34 AM   #2150
coppertop
occasional meanderthal
Oddometer: 245
Once more, road-worthy
I began a top-end engine rebuild on my '86 XL600R last year. Once I started and found out what new parts I needed, I ordered them and had the frame powder-coated. One thing led to another, and I had my front wheel re-laced with an 18" rim, because the ultimate goal is to get more of a street-tracker look to it. Well, the parts have finally come together. I bought a battery eliminator on E-bay for cheap, and was slightly worried about the lights, horn and turn-signals working with it, but the bike fired up on the second kick and runs like it ought to.
I am somewhat astounded that I did not lose any of the bits and pieces. I start projects like this with great intentions of documenting with photos and carefully organizing the parts that I remove. Those intentions are always overridden by my zeal as I start removing parts.
I still intend to replace the gas tank and seat, and I want to mount a larger brake disc up front and probably get a different speedometer, but for now, it is really nice to be able to ride it again after nearly a year apart.
coppertop is offline   Reply With Quote
Old 03-23-2008, 05:20 PM   #2151
blshelley
5th Gear Pinned
blshelley's Avatar
Oddometer: 20
Finally got my Dunlop D606's on.
I love these tires, puts the stock ones to shame offroad. I'm hoping I get decent milage outta them.
2007 Honda XR650L~Click Here
blshelley is offline   Reply With Quote
Old 03-23-2008, 05:53 PM   #2152
BigBob
BigBob's Avatar
Oddometer: 449
I want to ride so bad I'm nauseous.
Got a lot of snow Friday. I was out of town for the weekend, no big deal.
The race bike has a disassembled front end, waiting on seals.
The Tiger needs a shock.
And the XR650L is still on the lift with no suspension, waiting to get my stuff back from RaceTech.
-Big Bob
Chicago, IL
BigBob is offline   Reply With Quote
Old 03-23-2008, 08:17 PM   #2153
lowflyer
Doubleplusgood
lowflyer's Avatar
Oddometer: 2,478
I was out today.
lowflyer is offline   Reply With Quote
Old 03-23-2008, 08:32 PM   #2154
arkansawyer
Oddometer: 1,951
I rode about 2.5 hours/60 miles Saturday. Mostly dirt. Some of it single track. I am really starting to like my L.
arkansawyer is offline   Reply With Quote
Old 03-24-2008, 04:47 AM   #2155
husky123
Oddometer: 1,454
Originally Posted by lowflyer
I was out today.
Cool helmet!
husky123 is offline   Reply With Quote
Old 03-24-2008, 07:23 AM   #2156
lowflyer
Doubleplusgood
lowflyer's Avatar
Oddometer: 2,478
Originally Posted by husky123
Cool helmet!
Thanks. It was just too cold for my dirt bike lid so I opted for my trusty Caberg Justissimo.
Old 03-24-2008, 07:27 AM   #2157
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,076
Great helmet.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-24-2008, 09:58 AM   #2158
mongox
ARRRRGH!!!
mongox's Avatar
Oddometer: 2,520
JStory has one on his xl600. He got it at motostrano.com and I think it is the same as my 650L.
Originally Posted by coppertop
(Yes, I meant to yell...) To those of you who have mounted an oversize brake disc to the front; Does anyone know what oversize disc will fit an '86 XL600R? and the follow up questions: Did you have to fabricate your own relocating bracket and use the stock caliper or did you have to use a different caliper?
I recently had my front wheel relaced with heavy duty spokes and an 18" rim, and I want to improve the front brakes a bit. Unfortunately, I cannot find an oversize rotor that explicitly states that it will fit the '86. I've tried backing into it with stock hub and disc part numbers, but have only succeded in confusing myself.
I know I saw a picture on this thread where someone used an oversize rotor they bought from supermostrano (sp?), but they did not give a part number...
Your collective assistance is, as always, greatly appreciated!
"First, God made idiots" Mark Twain
"Those who dance are considered insane by those who can't hear the music" unknown
mongox is offline   Reply With Quote
Old 03-24-2008, 11:43 AM   #2159
Mercury264
Mercury264's Avatar
Oddometer: 22,076
Chain and sprockets
I need a new chain and sprocket set for The Comet.
Planning on doing a trip to Gaspe this year with my wingman (also on an XRL) and so we were debating gearing. I am leaning towards just going with stock - not sure whats on there now but it 'aint stock since it tops out at about 70 on the highway.
Thoughts ?
What is stock by the way
Best place to buy ?
Found this
http://www.sprocketcenter.com/p/4786...50l-93-06.html
$126
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-25-2008, 07:38 AM   #2160
t_burson56
OWNER/USER
t_burson56's Avatar
Oddometer: 29
Think it will work?
Well, I cant seem to find an xr650l in my price range, but I found a 2001 Suzuki DR-Z400S that I can afoord. Like I said I am a big guy (6'3" 270), do you think the DR will be too small? Under-powered? I dont want my knees riding on the bars... or
t_burson56 is offline   Reply With Quote
Times are GMT -7.   It's 09:36 AM.
