Old 11-23-2010, 11:29 AM   #21631
mcma111
mcma111's Avatar
Oddometer: 7,974
B,
Ya may have gotten off cheap but you sure missed the
BLING
of that new triple clamp
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-23-2010, 11:38 AM   #21632
El Birdo
El Birdo's Avatar
Oddometer: 899
Giant Loop
Thanks for posting those photos guys. Now maybe Santa can bring me A GL since I've been so nice this year.
Riding something on two wheels
El Birdo is offline   Reply With Quote
Old 11-23-2010, 11:52 AM   #21633
zcooney
Ask about my red wings
zcooney's Avatar
Oddometer: 144
Originally Posted by JWhitmore44
Talking about XR400 oil coolers, will the XR250 oil cooler work also?
I'm sure it would work, and probably easier to fab on with the banjo bolts. The only downside is that there isn't the same surface area as the xr400 cooler, maybe you could double up the XR250's.
zcooney is offline   Reply With Quote
Old 11-23-2010, 01:15 PM   #21634
flatfender
flatfender's Avatar
Oddometer: 769
The XR250 cooler I installed on my bike works fine, if not great. The summer I put mine on I was every day running up to 275 degrees. After installing the XR250 cooler it would sometimes run up to 240 degrees, but mostly stayed in the 220-230 range in the same temperatures on the same trails.
The shorter XR250 makes cramped quarters cable routing a non-issue. Hooking up the XR250 cooler couldn't be easier, just cut the cooler lines past the banjo fittings and the bikes' oil lines then connect them together with flexible transmission lines and hose clamps. The used price for a XR250 cooler is usually $25.
Some guys say the XR250 cooler is not worth the effort, but yet have never tried this cooler on a XR600/650L. I have and it is a very cheap and very effective way to bring down the oil temperatures in the summer heat.
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 11-23-2010, 01:40 PM   #21635
mcma111
mcma111's Avatar
Oddometer: 7,974
Well you know what they say. Everyone has one.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-23-2010, 02:17 PM   #21636
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 3,312
I`d have to agree with Steve,,not enough oil capacity,surface area to be worth the effort..Flatfender says it works though....i`d go XR400 or check out GSMarks oil cooler.......Vanpelt also makes a nice one...bolts to the skidplate..
B
01 XR650L,102mm JE 11.25:1..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
techforlife is offline   Reply With Quote
Old 11-23-2010, 02:23 PM   #21637
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,873
Originally Posted by mcma111
B,
BLING
My friends say I have enough "Bling"............
When/If I do the front fork swap,.................then I'll get the Bling.
Boojum
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly"
BMW's: 1999 GS 1100 "Work Horse", 1975 R90/6 "Black Betty", 92 R100 GSPD,
03 XR 650L with Farkles, KLR 250, 72 Honda CL-70
Boojum is offline   Reply With Quote
Old 11-23-2010, 04:17 PM   #21638
eeore39648
eeore39648's Avatar
Oddometer: 1,933
B
A fellow ADV'er has a oil cooler he wants to sell. His screen name is 57Frontier.
You might PM him a get a new oil cooler, at a good price.
2009 Kawasaki Versys
eeore39648 is offline   Reply With Quote
Old 11-23-2010, 04:24 PM   #21639
mcma111
mcma111's Avatar
Oddometer: 7,974
Here it is:
http://www.advrider.com/forums/showthread.php?t=633437
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-23-2010, 05:35 PM   #21640
kubiak
Oddometer: 4,139
check out power steering coolers and other bike coolers on ebay. i get mine from ebay since they are so cheap but it took awhile to get one that doesnt cool the oil too much. i ended up with a 84 kawasaki gpz550 oil cooler which is just right.
Old 11-23-2010, 07:41 PM   #21641
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,299
Originally Posted by bluemtnridr
Hadn't seen the coyote with a cyclerack and wonder if it would be to wide.
The nice thing about the GL bags is they don't need racks. They are designed to be used without racks. I have an orginal GL, the bolt on version and I have it mounted just behind the end of the seat but it could be mounted further forward so a fender rack would fit behind it. The owner/designer is here on ADV and goes by the handle: Wachs. He lives a few miles from me and is super cool so he might have some suggestions for you. Just PM him.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 11-23-2010, 09:14 PM   #21642
Memnok
Fly high, go far.
Memnok's Avatar
Oddometer: 341
Send a message via Yahoo to Memnok
If I get a complete CRF triple clamp (like this set), I can use my L steering stem by purchasing conversion bearings from All Balls?
Also, if I use the CRF triples, will they work with the stock steering stops?
Clint >>> 2007 XR650L <<<
Good government is no substitute for self-government. Mahatma Gandhi
That government is best which governs least, because its people discipline themselves. - Thomas Jefferson
Memnok is offline   Reply With Quote
Old 11-23-2010, 10:48 PM   #21643
flatfender
flatfender's Avatar
Oddometer: 769
Not an opinion, if the cooler didn't cut it I would post a warning to avoid it.
Old 11-24-2010, 05:21 AM   #21644
mcma111
mcma111's Avatar
Oddometer: 7,974
No and No.
The CRF steering tube is larger diameter than the XRL top and bottom. You would need an Emig Racing conversion stem and top bushing.
These stems allows the conversion of 00-08 CR/CRF forks on a XR400 or XR600 / XR650L. The steering stem accepts the CR triple clamps, while accommodating the XR bearings and correct length. Stem will retain the stock spanner and top clamp nuts. When using the CR top clamp, an additional bushing is necessary to fit this steering stem to the top clamp stem bore. The stem's top clamp dimension cannot be made to accept the CR top clamp bore, as the XR bearing is smaller.
XR 400 Conversion Stem $150 Complete Conversion Clamp Kit Available....Click Here
XR 600 / XR650L Conversion Stem $150
Top Clamp Stem Bore Bushing $30
And the CRF triples don't line up with the XRL frame stops so I add some material at either side to the bottom of the steering tube. I used a 1/2" Woodruff key. Dry fit the triple trees and filed to final fit.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-24-2010, 05:48 AM   #21645
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,299
No and No.
I've also heard that the CRF forks need to be shortened a bit because they are longer than stock XRL forks. Is that true? I was told that using them "as is" messes up the geometry, making the bike want to turn less than it already does.
Prov 3:5 & 6
Times are GMT -7.   It's 09:57 PM.
