Old 12-03-2010, 03:27 PM   #21841
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,352
Originally Posted by Ben99r1 View Post
ScooterDave. The fumes will cause the tank to expand over time. I was a bit over 6 glns on my acerbis 5.8. Ben
ScooterDave..........:rof l
Sorry,,just about kills me everytime
B
techforlife is offline   Reply With Quote
Old 12-04-2010, 07:10 AM   #21842
COXR650L
Oddometer: 1,545
XR650L Wheels and Tires
FYI, if anyone is interested I have this posted in the flea market for a set of wheels and tires off an 07'....
http://www.advrider.com/forums/showthread.php?t=640749
COXR650L is online now   Reply With Quote
Old 12-04-2010, 07:29 AM   #21843
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,626
Wish you would get those sold
I traded for your old 03 from Greco and I always thought it would be cool to have an extra wheel set up with ice screws for winter driving. But my toy fund is cleaned out at the moment. Good luck with your sale.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 12-04-2010, 01:19 PM   #21844
Ben99r1
Ben99r1's Avatar
Oddometer: 3,090
I have had a extra wheelset for over a year. I think I have used them for 2 trips. i guess I really didn't need them. When I wanted to do some road riding I would just take one of my other bikes. Well I just sold that bike so now I am glad I have the other set. Because of the extra wheels I can take my time looking for a replacement bike. One set has 606's the other has mt90's. Ben
Ben99r1 is offline   Reply With Quote
Old 12-04-2010, 06:26 PM   #21845
eeore39648
eeore39648's Avatar
Oddometer: 2,054
My Low beam headlight went out. The High beam still works. What bulb is used in the XRL?
Honda CB500X
eeore39648 is offline   Reply With Quote
Old 12-04-2010, 07:46 PM   #21846
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,967
12v 55-60w standard h4 3 prong plug.
Boojum
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly".......
Boojum is offline   Reply With Quote
Old 12-04-2010, 08:10 PM   #21847
Boojum
Boojum's Avatar
Oddometer: 5,967
I have a question for the guys running the Edelbrock Quick Silver Carb on their XRL's. What is your carb set on? I mean, what needle #, and what "click" position on the adjuster, on top of the carb? I had one on mine, but went back to the stock (daves mod'd) carb. I just want to get in the ballpark, and go from there. Now, my elev. is around 600-900ft. most of the time, Stock airbox, snorkel removed and opened up, K&N filter with the pre-charger cover-net thingy. Last time I had the carb out, I had put a #18 Needle in it. I have a few others to swap out if need be. Thanks for any input on how you'r running your Edelbrock QS Carb on your bike.
Boojum
Old 12-04-2010, 09:30 PM   #21848
flyingwombat
frozen dead guy
flyingwombat's Avatar
Oddometer: 803
2001 XR650R skid plate no-go
I bought a Ricochet skid plate for a 2001 XR650R, because I saw some of you guys running them (much much earlier in this thread ) and they look like they offer better protection than the L version.
Mine did not fit and it was not even close to fitting. It wasn't a matter of holes not lining up- I was prepared to drill it, it was just the wrong shape. It did come with clamps, but it does not have the extra welded piece on the front (right under the frame oil drain) like I have seen in some of the bike pictures here. Looks like it might be hit or miss on these unless there is a specific model year to get... just thought I would let you all know.
I guess I'll see if I can exchange it for Ricochet's L version, unless someone knows of a better skid plate for the L.
flyingwombat is offline   Reply With Quote
Old 12-04-2010, 09:37 PM   #21849
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,872
I didn't know anything about the R plate, but my L's plate is not mounted if you need measurements or pics.
katbeanz is offline   Reply With Quote
Old 12-04-2010, 09:43 PM   #21850
OSSO
OSSO's Avatar
Oddometer: 11
Ricochet revised the XR650R skid plate..... the new rev. apparently does not fit. I have the original design and it fits well.
OSSO is offline   Reply With Quote
Old 12-05-2010, 06:12 AM   #21851
eeore39648
eeore39648's Avatar
Oddometer: 2,054
Boojum
Thanks Boojum.
Honda CB500X
Old 12-05-2010, 10:19 AM   #21852
Ben99r1
Ben99r1's Avatar
Oddometer: 3,090
eeore. You can find a replacement bulb at walmart. It also comes in a hype white bulb. Its better than the stock one. Ben
Old 12-05-2010, 01:45 PM   #21853
rrittner
SometimesY
Oddometer: 252
Does the top end look ok.
So in an effort to stop my bike from using excessive oil I'm replacing two valve guides and seals that are leaking, now that I have the head off I took some pictures.
From some of the other pictures of rebuilds that I've seen my cylinder looks good. Also the carbon build up isn't too bad.
Just asking if it looks OK to anybody with more experience with this.
Also how do I compress the valve springs??
Thanks for any help.
rrittner is offline   Reply With Quote
Old 12-05-2010, 01:59 PM   #21854
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 715
With a valve spring compressor, here is my homemade job using a harborfreight C clamp and a small piece of electrical conduit with access holes drilled in the side:
Ghost_Mutant is offline   Reply With Quote
Old 12-05-2010, 02:10 PM   #21855
mcma111
mcma111's Avatar
Oddometer: 12,895
Notice how the outer edge of the piston is clean of carbon build up? That is due to oil passing the rings and washing the carbon away. You better plan on a hone job and a set of rings. Better yet get the piston and cylinder measured and see if it is still in spec. But hey, you wanted a high compression slug anyway, didn't you?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 09:04 AM.
