Old 04-08-2008, 08:47 PM   #2251
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
first time in the dirt, 3 hours off the trailer from the long ride from San Antonio.
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 04-08-2008, 09:23 PM   #2252
BushwickKLR
BushwickKLR's Avatar
Oddometer: 1,580
looks like your had a great time.
BushwickKLR is offline   Reply With Quote
Old 04-10-2008, 12:31 PM   #2253
onaXR OP
Druid
onaXR's Avatar
Oddometer: 2,086
Taillight, turn signals, dash lights, neutral light, and horn are they fused somewhere together at a spot not in the fuse box?
I lost them all this morning 4 am commute with only a headlight.
Klaatu barada nikto
onaXR screwed with this post 04-10-2008 at 04:16 PM
onaXR is offline   Reply With Quote
Old 04-10-2008, 12:53 PM   #2254
McLeod
Oddometer: 429
Originally Posted by onaXR
Taillight, turn signals, dash lights, neutral light, and horn are the fused somewhere together at a spot not in the fuse box?
Pull your seat, their is a wire bundle on top of your air box, I would start there.
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450
McLeod is offline   Reply With Quote
Old 04-10-2008, 01:02 PM   #2255
RocknTroll
RocknTroll's Avatar
Oddometer: 777
Kinda along the same lines
Does anybody know if the blank slot in the fuse block has a wire that ends up some where??
I noticed that the lower side is wired to the ignition, hot with the key in the on position, but I haven't pulled the fuse block apart or opened the wire harness to see what's in there if anything.
I may get older but I refuse to grow up
"Stay smart. Don't put your stupid hat on at this point in time... " Gov. Pat McCrory
RocknTroll is offline   Reply With Quote
Old 04-10-2008, 07:18 PM   #2256
Tslapper
Tslapper's Avatar
Oddometer: 6,774
Nuthin new here
A month ago this was a complete stocker. Nothing major, just rigged her up for some distance riding. This is my second L and it's pretty much a mirror (cept the bash plate and exhaust) of the last one. I made some brackets for the turn signals to get em up off the tank. Turned out pretty good.
I'll put an exhaust on it later this year and I'm still on the fence about another bash plate. Functional but like the looks without. Take my chances I guess. Love this bike!!
Tslapper is online now   Reply With Quote
Old 04-10-2008, 07:24 PM   #2257
truck6driver
The Fireman
Oddometer: 7,566
What did poor Eeyore do to you to deserve to be hung in your garage?
RH
Life has F@#ked with the wrong man. I will come out on top. Just watch.
truck6driver is offline   Reply With Quote
Old 04-10-2008, 07:31 PM   #2258
Tslapper
Tslapper's Avatar
Oddometer: 6,774
The wife knows when to stop backing the cage in when she hears, oooooohhhhh botheeeerrrrr. Probably would do better with a character that talks a little faster.
Old 04-10-2008, 07:32 PM   #2259
onaXR OP
Druid
onaXR's Avatar
Oddometer: 2,086
Got it, some freaky fuse that didnt look blown.
Klaatu barada nikto
Old 04-11-2008, 06:17 AM   #2260
McLeod
Oddometer: 429
Sweet.
Old 04-11-2008, 06:40 AM   #2261
McLeod
Oddometer: 429
I just switched back to the stock exhaust because I am getting tired of rebuilding my White Brothers E2.
So my question is who makes the most durable, quite exhaust on the market.
I guess I shouldnt complain too much the White Brothers has 20k miles on it, but dam it I expect the packing to last longer that 3 months, and the bolts to stay tight.
Old 04-11-2008, 06:45 AM   #2262
onaXR OP
Druid
onaXR's Avatar
Oddometer: 2,086
Im running a FMF q2 about 7k on it so far, I had a issue with the cheap mounting nut but other than that no complaints. I took it apart to repack but it was like new at 6k, red loctite the bolts too.
Klaatu barada nikto
Old 04-12-2008, 04:45 PM   #2263
Brtp4
Powdercoat it.
Brtp4's Avatar
Oddometer: 1,987
Finally finished fork swap on my XRL
2006 650L w/CRF forks:
BP
Bend, OR
Brtp4 is offline   Reply With Quote
Old 04-12-2008, 05:53 PM   #2264
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,332
Chain snapped on Thursday
Thankfully I was just pulling out of a parking lot and not on the highway.
Standard sprocket cover did it's job though and the chain didn't damage the case. It's toast now, however, as is the chain.
So.....couple questions:
1. I need a new sprocket cover/case saver - is XRs Only about the only choice (aside from OEM obviously)
2. Do I need new sprocket bolts (rear in particular but front also) when I install the new chain and sprockets.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 04-12-2008, 10:02 PM   #2265
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,310
Not unless you round out the stupid shallow allen hole in the bolt head. If you do the initial breaking loose from the nut side, the chances of that happening are greatly reduced.
Walter
Walterxr650l is offline   Reply With Quote
Times are GMT -7.   It's 02:35 PM.
