Old 02-17-2006, 11:39 PM   #226
Smith898
Dancin Man
Smith898's Avatar
Oddometer: 279
'04 XR650L new owner
Hey guys a newby to the XR650L only 2 hours getting ready to take it out tommorrow. Ant words of advice it only has 850 miles on it and has never hit the dirt. I am usually a KLR ride but could not pass up the sticker price!
1997 KLR 650
1975 Honda XL175 - Every one has to have a classic
Smith898 is offline   Reply With Quote
Old 02-18-2006, 05:27 AM   #227
wheelnut46
wheelnut46's Avatar
Oddometer: 631
Have fun. The stock tires suck so watch out. But most importantly have fun. Let us know how it does.
Forum motto - Buy a bike like mine
Gravity - It's not just a good idea, It's the law.
1998 Honda Valkyrie
1946 Chevy pickup
wheelnut46 is offline   Reply With Quote
Old 02-18-2006, 05:31 AM   #228
Mr Kawasaki
Sardonios Irritatus
Mr Kawasaki's Avatar
Oddometer: 6,346
The XR has a has a higher center of gravity then the KLR so go easy until you get used to it. If you cross any moss covered spillways go slow DAMHIKT.
It wouldn't worry us so much about what other people think of us if we knew how seldom they do.
Mr Kawasaki is offline   Reply With Quote
Old 02-18-2006, 10:27 AM   #229
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,448
Touratech is making a cool guard for that Buell Oil Cooler.
I like the size of the Buell cooler, but I also like the way the XR400 cooler is well protected by the forks.
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Chad Berger DR650, KTM 990 Adventure R
Lone Wolf Expeditions
rokklym is offline   Reply With Quote
Old 02-18-2006, 01:36 PM   #230
scootertrash
Mobile Homie
scootertrash's Avatar
Oddometer: 2,074
Has anyone temp'ed the oil to compare between one with a cooler and one without? I'm interested in how effective it is. There seems to be way more aftermarket for the XL than the DR and I'm debating on another DR or XRL down the road for my son so we can make some longer runs...
TV-free for 7 years and counting
"The difference between Adventure and Adversity is Attitude"
scootertrash screwed with this post 02-18-2006 at 02:05 PM
scootertrash is offline   Reply With Quote
Old 02-18-2006, 07:01 PM   #231
xr-nut
Out Ridin' Around
xr-nut's Avatar
Oddometer: 63
on mine with the jagg cooler its between 30-50 degrees cooler(according to src temp dipstick). where I noticed that the most is when trail riding in the heat and riding hard, the oil will get hot enough to burn the grease out of the steering head bearings(because thats the oil tank, in case you didnt know?). it would leak out the lower neck seal and run down the back of the front fender. with the cooler that doesnt happen at all. basic automotive common sense says that cooler oil means longer engine life. BTW-oil seems to look and smell better with the cooler at changes too.
RIDE RED>xr-nut http://xr-nut.smugmug.com
xr-nut is offline   Reply With Quote
Old 02-19-2006, 09:43 AM   #232
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,958
Run Cooler!
Run cooler on the XRL simply by removing the stock front fender and installing a low one such as the Acerbis Fast Front Fender about $35.
RED CAT is offline   Reply With Quote
Old 02-19-2006, 01:00 PM   #233
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,448
Does anyone have alot of experience with the XRL in sand?
I've had my fair share of troubles in the loose & deep stuff. I was wondering if anyone else has issues with their XRL in sand?
last fall, I went on a trail ride with a completely worn out rear D606 and two days later I did the same trail with a new tire and the bike handled alot worse. I was thinking this was due to the geometry change due to the taller tire. Anyone else notice anything like this? I was considering softening up my rear shock to give it more sag.
If I could make this bike handle better in the loose stuff, I'd like it alot more! I was also wondering if anyone has tried a fork brace or a steering stabilizer. I think the brace would help alot, those forks are pretty skinny!
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Old 02-19-2006, 04:27 PM   #234
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,958
Sand.
Try and ride faster with plenty of power. Mine's great in sand.
Old 02-19-2006, 04:35 PM   #235
goblin
pig rider
Oddometer: 371
Thumb
I did a fork brace to my XRL along with other bike's i've owned and it made a nice diff. Climeing out of ruts was a nice improvement.
XRL rider western mass.
goblin is offline   Reply With Quote
Old 02-19-2006, 04:55 PM   #236
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,448
That works for me to a point. Going stright, yeah staying on the throttle is great, its just when you have to slow down to turn or avoid something that things get crazy.
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Old 02-19-2006, 05:17 PM   #237
ram1000
ram1000's Avatar
Oddometer: 1,833
Has anyone noticed the rear hub is not dampened like the DR or KLR. I think I noticed the DRZ is not dampened as well. No big deal except that that point seems to be the difference between some buying the XRL and the XRR. Appearently this is not as much an issue so many seem to be concerned with.
ram1000 is offline   Reply With Quote
Old 02-19-2006, 06:04 PM   #238
TWISTEDL
Watch This !!!
TWISTEDL's Avatar
Oddometer: 10
Rokklym
I am curious where are you riding at??
TWISTEDL is offline   Reply With Quote
Old 02-19-2006, 07:21 PM   #239
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,448
Originally Posted by TWISTEDL
Rokklym
The picture I posted was from the U.P. of Michigan last summer when we did the U.P. Safari http://rokklym.smugmug.com/gallery/1034044
I usually do most of my riding up in Central Wisconsin on the ATV trails and forest roads. There is plenty of sand in that area!
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Old 02-19-2006, 07:42 PM   #240
onaXR OP
Druid
onaXR's Avatar
Oddometer: 2,086
I have noticed that also, not really a issue for me except it will wear a chain faster. But chains have got so good I have over 9000 on mine and will need to replace next month.
Klaatu barada nikto
onaXR is offline   Reply With Quote
Times are GMT -7.   It's 09:23 AM.
