Old 04-09-2011, 03:57 AM   #26626
Olderslowerguy
Olderslowerguy's Avatar
Oddometer: 424
Cdi
Anyone know anything about these:
http://cgi.ebay.com/ebaymotors/XR-60...item3f08f3c0a7
Make sure you read the entire description.
OSG
Clearwater, Fl.
Olderslowerguy is online now   Reply With Quote
Old 04-09-2011, 03:59 AM   #26627
Wattner
Wattner's Avatar
Oddometer: 5,348
Originally Posted by kenny61 View Post
Thanks. Its painted not powder coat. I was gonaa powder coat but since I have the KTM now thsi bike will see mostly street and smooth dirt roads so the paint should hold up fine. The high wear areas will recieve a layer of bedliner
Very nice... you had the linkage and motor mounts painted as well. Cool touch!
Wattner is offline   Reply With Quote
Old 04-09-2011, 04:04 AM   #26628
Wattner
Wattner's Avatar
Oddometer: 5,348
Wow OSG, neer heard of such an animal... It would be interesting to see what they actually offer as far as performance goes
I am curious as to whether it is a reworked stock unit or all new. I hope it is OEM quality
Old 04-09-2011, 04:05 AM   #26629
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,665
Thanks, I dont have the artistic ability to see in my head how something is going to turn out. I get more of a rough draft and make revisions as I go
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 04-09-2011, 04:08 AM   #26630
Wattner
Wattner's Avatar
Oddometer: 5,348
Originally Posted by screamin injin View Post
Looks good Kenny. I thought about getting the frame powder coated, but I want to ride in two weeks, so prob save that for next time.
Did you ever call Banz? He is someone that you don't want to miss... He has a garage stuffed with bikes and wants to ride all of the time. He is good people and a real nut. Incredible wrench as well.... Was working for DG in high school welding exhaust
Old 04-09-2011, 04:11 AM   #26631
Olderslowerguy
Oddometer: 424
RE: RallyRaid Fairing
Originally Posted by mrfixit54016 View Post
Hey Jack, I would like to know how tall that fairing is above the top of the headlight?
It's about 12" above the headlight. I'm 5'11", with about 1" of foam removed from the seat, and the wind hits me around my helmet at highway speeds. But, it's not so bad that it bothers me.
OSG
Clearwater, Fl.
Old 04-09-2011, 04:15 AM   #26632
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
Hmmmmmmmmm....the XR600 uses AC volt.....the XR650L is DC.....can`t see how that would work.....am i missing something,the OE XR600R CDI will not work in the XRL......i`d be carefull,i bet the seller has no idea of that..
B
techforlife is offline   Reply With Quote
Old 04-09-2011, 04:58 AM   #26633
screamin injin
FUBAR
screamin injin's Avatar
Oddometer: 2,519
Banz? I don't remember. There have been a few new guys in the area that I rode with. Shoot me a pm.
screamin injin is offline   Reply With Quote
Old 04-09-2011, 06:35 AM   #26634
eeore39648
eeore39648's Avatar
Oddometer: 2,006
B
Thanks for that tip techforlife!
I may be needing a CDI soon, this tip will be helpful.
Honda CB500X
eeore39648 is offline   Reply With Quote
Old 04-09-2011, 07:21 AM   #26635
Roll_n
2WheelsDown
Roll_n's Avatar
Oddometer: 148
Question Installing Lowering Link
Hi BRP think tank-
Any tips/suggestions for installing a XRonly lowering link? Doesn't look too complicated, but wanted to see what you folks think.
Dave
2013 NC700X
1982 ATC110
Roll_n is offline   Reply With Quote
Old 04-09-2011, 07:28 AM   #26636
mcma111
mcma111's Avatar
Oddometer: 12,386
Originally Posted by WackaWacka View Post
Hi BRP think tank-
Dave
Raise bike onto a lift or a box. It is easier with the rear wheel removed as you'll be fighting it's weight or someone to help . Remove the 2 bolts and the link is off. Installation is the reverse. Grease everything. The bolts get tightened to 33 lbs IIRC.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-09-2011, 07:53 AM   #26637
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,484
Lowering Link
When I did mine I left the rear wheel on. Put the bike on a hydraulic lift so that I could adjust the angle of the swing arm by using the lift. Very easy to do alone.
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 04-09-2011, 08:00 AM   #26638
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
Rotopax on a rack
Iam getting ready to order a rotopax setup for the testing process,, and again i need the help of the inmates, question
what size can would be best 1 gal then stack them or 3 gal alone
iam thinking to have one on either side of the front rack, or
on the top of the rear rack, again thanks to all for your support
and kind words, mike
jungleplant is offline   Reply With Quote
Old 04-09-2011, 08:03 AM   #26639
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,665
I think thats gonna be a matter of opinion as each has its pros and cons.
3 gallon for the simple 1 item choice
1 gallon allowing you to take only as much as needed. if you drop the bike maybe only puncturing one vs all 3 etc etc etc
Old 04-09-2011, 08:09 AM   #26640
Olderslowerguy
Oddometer: 424
Re: Cdi
B
PM sent
OSG
Clearwater, Fl.
Times are GMT -7.   It's 03:05 PM.
