Old 06-14-2011, 10:51 PM   #29536
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Spud your pictures make me hate where I am more and more every day. Theer are beautiful parts around here but there is something about the West that just makes me yearn for it...
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 06-14-2011, 10:54 PM   #29537
farrington300
No wait....What?
farrington300's Avatar
Oddometer: 518
Acerbis tank hardware.
Looking for mounting hardware for the Acerbis 5.8 tank. One piece or a whole set, what ever you've got.
I have the 5.8 on my xr4 and plan to switch it over to the L, acerbis wont sell me the kit so I am going to fab / piece the kit together.
Any help would be great, links, pics, etc. Thanks.
TE610
TLR200
farrington300 is offline   Reply With Quote
Old 06-14-2011, 11:49 PM   #29538
flyingwombat
frozen dead guy
flyingwombat's Avatar
Oddometer: 769
Wow with the 5.8 on an XR400 you must be able to ride from here to Yokohama without refilling. The hardware that comes with that tank isn't real great and has to be tweaked to fit properly anyway. If it takes a lot of effort to aquire it you might be better off creating it from scratch and you might just end up with a better solution. The rear mounting point is just a piece of metal bent kind of like a Z, and the front is a couple of tubes with ends crimped at 90 degree angles from each other. Sorry I don't have a pic handy.
By the way, does anyone know if any Honda petcocks will fit on the Acerbis 5.8?
Bad Medicine: Baja October 2011 - White Rim Sandwich (with Kokopelli bread) - Please help support COHVCO!
flyingwombat screwed with this post 06-15-2011 at 12:00 AM
flyingwombat is offline   Reply With Quote
Old 06-15-2011, 12:31 AM   #29539
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 735
Originally Posted by Spud Rider View Post
My new camera arrived yesterday, so here is the first photograph of Rubicon's replacement, in his natural habitat.
Spud
Hey Spud, what kind of camera did you end up with? I am (was) using a Kodak DX4330 (just died) so I am searching for a replacement on the cheap with a DC plug-in like the old Kodak, meanwhile I scavenged the old DC plug-in from the DX4330 and grafted it to a Kodak C530 but the C530 doesn't have any sound on video (unacceptable)
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is online now   Reply With Quote
Old 06-15-2011, 12:46 AM   #29540
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,696
There should be a middle mount that straddles the frame and attaches to the rear bolt of the top rocker cover bracket. I made some plastic bumpers that slip on and match up to recesses in the tank. I used some old rubber shock bumpers to keep the existing frame pins for the stock tank from rubbing. The rear mount's not hard to make.
I made front brackets out of 1/8" aluminum that bolt to all three theaded inserts in the tank figuring it would be better to spread the load among them in a biff. They hang down almost to the stock air deflector mounts, then two small lengths of 3/4 alum angle bolt to the wing mounts and the brackets. You can use a 12 pack carton to make "paper dollies" patterns, and don't use closed cell blue camp pad foam over the frame backbone. It melts and makes a big mess.
katbeanz is offline   Reply With Quote
Old 06-15-2011, 12:52 AM   #29541
Spud Rider
Spud Rider's Avatar
Oddometer: 3,771
I was using a Canon Powershot A590IS, until it finally died on me about a week ago. My new camera is a Fujifilm Finepix S2950, and I am just learning how to operate it. In part I chose both cameras because they employ AA batteries; I use rechargeable, NiMH batteries. I'm afraid I don't know much about DC plug-ins.
Spud
Spud Rider screwed with this post 06-15-2011 at 12:58 AM
Old 06-15-2011, 06:31 AM   #29542
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,537
I'm more traditional; I prefer burial. This afternoon I shipped Rubicon's remains back home to Lodi, via Priority Mail. My new camera arrived yesterday, so here is the first photograph of Rubicon's replacement, in his natural habitat.
Spud
I took a different approach to enjoying the local trails yesterday. A great way to scout new trails:
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 06-15-2011, 06:50 AM   #29543
Haywood
Haywood's Avatar
Oddometer: 397
PM sent.
Haywood is offline   Reply With Quote
Old 06-15-2011, 07:03 AM   #29544
Haywood
Haywood's Avatar
Oddometer: 397
I am in the process of getting my Acerbis 5.8 gallon tank replaced. It developed a leak at the lower right mount and is still under warranty so Acerbis is replacing it for me, which is nice. I will use their mounts again, but I plan on making a small plate or bracket to pick up those three mounting points also.
At certain RPM's you can actually see the sides of that tank vibrating so some strengthening of that mounting location is in order I believe.
I got the tank originally from Just Gas Tanks in northern San Diego county and they have been excellent to work with throughout this. It's nice to see that there is still some great customer service out there. Many thanks to them and Acerbis USA.
Old 06-15-2011, 07:10 AM   #29545
rrittner
SometimesY
Oddometer: 251
Just did a nice ride
Rode a nice loop from NW Colorado up thru Wyoming and back. The XRL ran like a champ.
Great Basin
Photobucket
Browns Park
Photobucket
My ride report
http://www.advrider.com/forums/showthread.php?t=697201
rrittner is offline   Reply With Quote
Old 06-15-2011, 08:14 AM   #29546
farrington300
No wait....What?
Oddometer: 518
I bought the tank for a special trip where I needed 200 mile range. It worked great. Now Im just luggin extra weight. I also have a clark tank that will go on after I put the Acerbis on my xrL.
The Honda L petcocks will not work on the Acerbis tank.
TE610
TLR200
Old 06-15-2011, 08:17 AM   #29547
farrington300
No wait....What?
Oddometer: 518
The middle mount is what I am most concerned about making. The rear mount and two front mounts should be pretty easy. But I dont know what the middle mount looks like or what it does. Does it just add to stability?
PS does anyone know if the Acerbis tank will work with a USD fork conversion?
TE610
TLR200
Old 06-15-2011, 08:39 AM   #29548
flatfender
flatfender's Avatar
Oddometer: 776
ah, Colorado
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 06-15-2011, 08:47 AM   #29549
flatfender
flatfender's Avatar
Oddometer: 776
I don't have access to a helicopter to scout trails (you lucky bastard) google maps works good too!
Old 06-15-2011, 10:06 AM   #29550
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,314
I'll be taking the bike apart tonight to work on the carb. If my shoulder allows. I've got a wicked pull under the shoulderblade that's been there since last thursday, even through my SF trip. I'll take some dims and send them your way.
The acerbis worked wtih my USD convert. CRF 250x, entire front end, trips down.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Times are GMT -7.   It's 01:14 AM.
