Old 09-02-2011, 01:28 AM   #32221
Memnok
Fly high, go far.
Memnok's Avatar
Oddometer: 374
Originally Posted by Grayjet View Post
Proof that pigs can fly:
Nice! Always fun to push the limits of sanity!
Clint >>> 2007 XR650L <<<
Good government is no substitute for self-government. Mahatma Gandhi
That government is best which governs least, because its people discipline themselves. - Thomas Jefferson
Memnok is offline   Reply With Quote
Old 09-02-2011, 05:58 AM   #32222
robs400
no time
Oddometer: 57
^ PIC ABOVE ^ is great HA!. I finally got some decent rubber mounted on the bike the other night. It had strictly street tires on it. Ended up putting Michelin T63's front and back and so far I have around hundred miles on them and I really like them. Much smoother on the road than I thought they would be and did well on a rocky trail into work this morning.
I played around with the adjustments as you guys suggested on the suspension front and rear. My front still feels pretty stiff even with the adjusters backed out. No air pressure in the forks either. Seems to make for a rough ride on trails with roots, but maybe thats just how these things are.
07 DRZ400
00 R1
86 Honda Interceptor 500
79 CX500 Custom
robs400 is offline   Reply With Quote
Old 09-02-2011, 07:32 AM   #32223
Gregster
Gregster's Avatar
Oddometer: 991
Originally Posted by mcma111 View Post
Short of taking the shock off of the bike and working at a vise adjusting the spring on the XR/XRL is a royal PITA...
I have about every ring spanner there is and NOTHING fits in there. Even taking the carb off. Unload the rear suspension by raising the rear off the ground and use either the biggest screw driver you have or a long, sharp drift and go for it. A liberal amount of lube above and below the lock rings helps. Mark a starting point so you know where your at as it takes a while to get some turns of the adjuster ring.
Thanks, I'm going to try the lube and tapping the lockring with a long screwdriver/deadblow hammer and then try to rotate the spring and adjuster ring together. If I get frustrated I'll just take the shock off and adjust it on the bench. I just don't want to buger up the lock rings, the ones on my CR250 are trashed from the previous owners and I would rather keep the ones on my XR in good shape.
Gregster is offline   Reply With Quote
Old 09-02-2011, 07:45 AM   #32224
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
SCREWDRIVER!!! youre a shock butcher!!!!
Well try a long brass or aluminum rod and a metal hammer. Tap one one direction and then tap the other the other direction till they seperate. If that dosent work gat an assisant to tap one ring while you tap the other.
Here's two assistants I would recomend:
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 09-02-2011, 08:23 AM   #32225
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
They look like they can straighten out any spring!!!!!
1Bonehead is offline   Reply With Quote
Old 09-02-2011, 08:44 AM   #32226
Gregster
Gregster's Avatar
Oddometer: 991
Just working with what I've got (no brass or aluminum rods hanging around) Probably easier and quicker to just take the shock off then to make a trip to Home Depot for some softer aluminum or brass rods. By the way, your assistants look like they could stiffen up almost any rods.
Old 09-02-2011, 09:37 AM   #32227
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Can ya believe I got them to pose like that with my bike???
WHY couldnt I do that when I was YOUNG?????????????????????
Regards
Fritzcoinc
Old 09-02-2011, 10:10 AM   #32228
shreds
Oddometer: 61
can ya believe i got them to pose like that with my bike???
Why couldnt i do that when i was young?????????????????????
because they know you are now harmless.
shreds is offline   Reply With Quote
Old 09-02-2011, 10:12 AM   #32229
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Thanks pal. Just what I n eeded to hear. Thanks again.
Regards
Fritzcoinc
Old 09-02-2011, 10:22 AM   #32230
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,611
If they only knew.....
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 09-02-2011, 10:25 AM   #32231
N7XW
N7XW's Avatar
Oddometer: 264
Originally Posted by Barron View Post
roughly 1/4 of the Navy's budget for maintenance goes for paint.-Barron
I can certainly believe it!
I spray her down or wipe her down with WD-40 on the regular and have very few problems.-Barron
That's not a bad idea. I might have to start doing that. Whenever I get back from riding in the rain, I put the bike in front of the heater to dry it out as quickly as possible to prevent rust.
"It wasn't broke until I tried fixing it"
N7XW is offline   Reply With Quote
Old 09-02-2011, 10:27 AM   #32232
N7XW
N7XW's Avatar
Oddometer: 264
Old 09-02-2011, 01:04 PM   #32233
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,626
Might change your fork oil, maybe previous owner put some heavy weight oil in. Most folks complain that the forks are way too soft on the L's
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 09-02-2011, 01:11 PM   #32234
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,412
I use a drift and hammer to seat or unseat the rear shock locking ring, then use a brake spoon from back when we used to manually adjust automotive drum brakes on the adjustment nut. Watch out you don't pinch any important stuff at the hinge point. A small pry or crowbar will work as well.
Ride what makes you giggle in your helmet
oremike is online now   Reply With Quote
Old 09-02-2011, 01:18 PM   #32235
elsalvadorklr
southern xr rider
Oddometer: 4,154
THATS EXACTLY WHAT YOU DONT WANT TO DO!
the reason is the same as why you dont pressure wash with HOT WATER or hot water at all..
heat aids in corrosion and what you think you are doing is actually worse..
Im a sailor and have had my fair share of wood boats, fiberglass, steel and have worked on numerous marine environments...
logic is sometimes a double edged sword.,
Next time...dry it off manually with a towel, then spray with wd40 or some other "protectant"
heat and water kill, add salt and you have death...
cheers
christian
elsalvadorklr is offline   Reply With Quote
Times are GMT -7.   It's 10:04 AM.
