Old 11-10-2011, 12:04 PM   #34456
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 2,114
Originally Posted by flatfender View Post
Oh okay, the DL has a 276mm rotor so you're just mounting it not changing the distance from the center of the axle. When I finally installed the XR650R forks my XR-L caliper didn't line up with the rotor on the stock XR-L wheel, I had to shim the axle spacer about an 1/8 inch to move the wheel insead of moving the caliper. I guess you had the same type of issue because you had to 'face' some of the stock DL bracket. I'm gonna give it a try, thanks for taking the time to post this mod and full instructions.
Flatfender - here's another picture that I've also added to my post. Notice how the caliper mounting plate bolts to the adapter. It sits on top of it - that's why I shaved the crap and bumps off of the back of it and drilled the threads out of the holes. If you decide to copy this you'll need to shorten the lower 10mm button head by about 2mm to ensure that it doesn't hit the heads of the rotor mounting bolts.
LexLeroy is offline   Reply With Quote
Old 11-10-2011, 12:48 PM   #34457
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,537
Originally Posted by AlpinaE24 View Post
Got my artificial day lights done today. The mount is solid, light output is great. Just gotta paint it and tape up all the wiring.
Lights look great...
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 11-10-2011, 09:10 PM   #34458
flatfender
flatfender's Avatar
Oddometer: 776
You were clear I just wrote it out wrong, it should have read "Oh okay, the DL has a similar diameter rotor so you're just mounting the caliper not changing its distance from the center of the axle." Which is what I thought was needed but this picture makes everything all clear on what you did and how you did it.
I'm going to call CRFStuff.com tomorrow and talk to them about their caliper bracket for a 280mm rotor for the CRF forks, if they make one for the earlier forks then it should bolt up to the XR forks.
This bracket is $88
$17 for the pins
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 11-10-2011, 09:59 PM   #34459
mendoteach
mendoteach's Avatar
Oddometer: 1,578
This bracket is $88
$17 for the pins
The guy who owns and started CRF Stuff, Scott (nice guy), has and a 650R so he may have something.
mendoteach is offline   Reply With Quote
Old 11-10-2011, 10:40 PM   #34460
flatfender
flatfender's Avatar
Oddometer: 776
sweat,
Old 11-11-2011, 05:37 AM   #34461
mcma111
mcma111's Avatar
Oddometer: 12,096
Happy Veterans Day to all you military type guys and gals both active and retired.
Thanks for your service.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-11-2011, 06:22 AM   #34462
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 2,114
This bracket is $88
$17 for the pins
Put up some pics if it all bolts together - but then there's always gonna' be some stubborn old fart like me that simply can't be dissuaded from turning $300 in time and materials into something inferior to a beautiful off-the-shelf product that could have been acquired for a third the price.
LexLeroy screwed with this post 11-11-2011 at 06:29 AM
Old 11-11-2011, 06:54 AM   #34463
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,305
+1.............Now I`m going back to bed and sleep all day
B
techforlife is offline   Reply With Quote
Old 11-11-2011, 08:17 AM   #34464
flatfender
flatfender's Avatar
Oddometer: 776
Normally that's me, I spent two weeks of spare time making a rear rack using a blow torch and tubing filled with sand. When it was done it was so ugly I had to throw it in a lake ..... sometimes it costs more to be cheap.
Old 11-11-2011, 09:02 AM   #34465
sc-razor
sc-razor's Avatar
Oddometer: 3,773
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 11-11-2011, 09:09 AM   #34466
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,388
Thank you, thank you very much!
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 11-11-2011, 09:22 AM   #34467
sc-razor
sc-razor's Avatar
Oddometer: 3,773
Same here. Thanks for posting Steve.
2009 XR650L
2009 KTM 300XC-W
Steve
Old 11-11-2011, 10:19 AM   #34468
mcma111
mcma111's Avatar
Oddometer: 12,096
-Barron
You are most welcome.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-11-2011, 11:19 AM   #34469
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Yes indeed!
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 11-11-2011, 11:36 AM   #34470
AlpinaE24
Oddometer: 561
AlpinaE24 - Both sweet and nasty. Can you give us some detail on the pieces and parts that it took to make this work? Thanks in advance.
Sure, I ran 3 new 12ga wires +/- on the battery and 1 to the frame ground under the seat for the relays. Fused the + after it came out under the triple, then split it and the ground into 2. Both positives go the the relays, and the grounds go to the lights. I used the stock Bl/W and BK wires for my switched 12v for the relay. I used two bosch 4 pin relays from a BMW. The hi beam relay 12v out is also on a spade connector, so I can quickly change it over to a cig lighter or any other things I add later.
The lights are one standard KC 6" spot currently with a 130w bulb, but I have a 100w on order. The lo beam is a Hella projector from a 90's bmw, I had to cut out the back of the bucket to fit the projector all the way through. It is running a 9006 51w right now, which I'll probably change out to a 55w. 181w plus the taillight is definitely to much for the stock output, I should be good at around 155w though since I don't have to run turn signals in the great state of arizona.
Also added a little backlit voltage gauge I had laying around the garage..I wish they would have just made the L's with back up kick starts. I spent like $40 on the whole project, so thats
2001 YZ250f - Plated
1995 Husqvarna WXE250
1985 XL600R - Sold
1994 XR650L - Sold
2000 XR650R - Plated - Sold
AlpinaE24 screwed with this post 11-11-2011 at 01:39 PM
AlpinaE24 is offline   Reply With Quote
Times are GMT -7.   It's 09:47 AM.
