Old 12-06-2011, 09:34 PM   #35191
Zerg
Zerg's Avatar
Oddometer: 52
Well I guess im done riding my bike until I can get a jet kit for it.. Just took my plug out and it was all burned up. P/O had mods with no jet kit on it. hopefully the engine isn't too screwed up now after 6K. It raised a red flag when he told me it dident have a jet kit I should have done some more research. It ran okay for me... Never got hotter than 225F on the dip stick thermometer. Ill see how it runs when I fix it I guess...
1996 & 1991 XR 250L
Zerg is offline   Reply With Quote
Old 12-06-2011, 09:35 PM   #35192
mendoteach
mendoteach's Avatar
Oddometer: 1,616
As a matter of fact, I'm taking pictures of stuff to list so when my C-Dub bill comes due I can afford to pay him
mendoteach is offline   Reply With Quote
Old 12-06-2011, 11:30 PM   #35193
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 750
Originally Posted by RiverRatRider View Post
Ware do I get the power from? I have hooked a cig plug up for cell phone/GPS but I ran that straight to the batt
can I get power from a better sorce
depending on what brand you use (I'm using Gerbing heated glove liners and jacket liner), each item came with at least part of the wiring harness, as in: the part that you connect to your battery with a fuse holder to a plug that you plug your controller into, the controller is on my body so even though it's connected strait to the battery I have to unplug it to leave the motorcycle so I don't have to worry about draining the battery unless I decide to take a nap on top of it with the bike not running.
Originally Posted by Jud View Post
Heated grips
You can wire the grips straight to the battery but then inevitably, the grips will be left on one day resulting in a dead battery,,,,,,, usually at the worst possible time. Better to either run it off a relay triggered from a key-on source {what I did as I have other electrical accessories}. Alternatively, you could simply tap into the low beam headlight wire.
oh, don't do that...I thought I was being clever tapping into the low beam headlight wire for power when I hooked up my O2 sensor/reader, then I accidentally hit the high beam switch and my O2 reader went blank...for a second I was thinking what now!!!!,so I looked and saw I hit the high beam switch, switched it back to low beam and my O2 sensor started sensing again.
now I get to run it to a new power supply...not sure where yet.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 12-07-2011, 01:39 AM   #35194
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
Originally Posted by mendoteach View Post
Where are those blinged-out valve cover caps you had offered up? Did you ever decide to make those? I think you should create a whole parts line for the XR650L. I'll sell some on ebay to spread the word for you for free. I have over 1200 feedbacks at 100%. I get top dollar when I sell. CRFstuff started out that way and they grew nicely (factory Honda riders use their HRC rotor copy. Why? It's better!). Once the ball is rolling then you can have some set-up a website for you (someone on this list has to have that skill). Common' C-Dub, you can do it Get your CNC mills fired up!
You want some bling well heck we can do that......
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 12-07-2011, 01:49 AM   #35195
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,780
Originally Posted by hogdoc View Post
I am sure I'll be around A LOT as I have nothing to do 24 hours a day for the next 2 months.
Good luck! Lotsa interesting stuff on darkroastedblend.com
http://www.youtube.com/watch?v=lnICv12ViIU
katbeanz is offline   Reply With Quote
Old 12-07-2011, 02:06 AM   #35196
XR650L
XR650L's Avatar
Oddometer: 224
Talking IMS or Clark
I tried to find a discussion on this, but did not have any luck. I want to put a bigger tank on. I am looking at the IMS 4.0 or the Clark 4.7
Anybody out there with some advice, looking for pro's & con's
Places where I can find them will be appreciated as well, it seems Bajadesigns does not sell them anymore, did ask XR Only but up to now did not get a reply on the tank.
If I am posting in the wrong place, please move me or tell me where to post
XR650L is offline   Reply With Quote
Old 12-07-2011, 02:10 AM   #35197
thinknlive
thinknlive's Avatar
Oddometer: 70
Originally Posted by Spud Rider View Post
Your bike looks great! I'm sure the new fork oil made a big difference. What brand and weight of fork oil did you choose? I recently drained the old fork oil from one of my bikes, and installed Mobile1 Synthetic ATF in its place; I'm very pleased with the results.
Spud
Thanks! I used the same ATF With all the changes together... I am really happy with the way she rides now. Smooth at 75-80+ with excellent throttle response when I need it.
thinknlive is offline   Reply With Quote
Old 12-07-2011, 02:11 AM   #35198
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,666
http://justgastanks.com/index.php?cPath=4_12_26
I have the IMS often wish it was bigger
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 12-07-2011, 02:15 AM   #35199
cyclewizard
Oddometer: 4,814
The clarke 4.0 tanks fit and finish is excellent and so is the 4.7 tank, if you ever go with a big finned head the clarke tank clears the fins better.
I don't think IMS makes a red tank anylonger for the XRL do they?
C-dub......
Old 12-07-2011, 02:23 AM   #35200
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,666
just gas tanks is still showing it in red
Old 12-07-2011, 02:34 AM   #35201
XR650L
XR650L's Avatar
Oddometer: 224
Ims or Clark
Thanks for replies so far
Old 12-07-2011, 02:53 AM   #35202
cyclewizard
Oddometer: 4,814
I'm working on it...
The problem I'm having is finding good poeple who want to work, right now I'm doing 75% of the work myself and can't even begin to keep up.
For instance I hired a young lady a few weeks ago to answer phones place and write orders and start an E-bay store and website and other things like ship out packages, well to make a long story short she needed some money to pay her bills" I'm a sucker when it comes to women" so I gave her 2 grand and I haven't seen the "C word here" since. damn hookers anyway..
Don't hire hot chicks they will F you over..hire them fat old ugly ones, eye candy distracts your hired
helps thoughts.
I have two of my old employee's working for me again but there swamped right now...I have a couple contracts with two big manufactures and I have them dedicated to those clients right now.
Maybe I should give up the motor stuff and just make little blingie parts probably more profit in it too than building cams and pistons and doing machine and motor work and it would free me up..
Another thing is if I make 500 of these caps I would be left with 492 of them because you and Mike are the only ones who want them so far. You're right I need to get an e-bay store...to widen my base..
Thanks for the inspiration..
Free CW.
CW.
C-dub......
cyclewizard screwed with this post 12-07-2011 at 03:47 AM
Old 12-07-2011, 02:55 AM   #35203
cyclewizard
Oddometer: 4,814
Cool, I thought it only came in white now.
C-dub......
Old 12-07-2011, 03:13 AM   #35204
XR650L
XR650L's Avatar
Oddometer: 224
Ims or Clark
Thanks for reply, still like the look of the Ims, but maybe that extra 0.7 gallon on the Clark will make a difference.
Old 12-07-2011, 03:19 AM   #35205
cyclewizard
Oddometer: 4,814
I like the looks of the 4.0 clarke and IMS tank there darn neer the same, the IMS hangs down a tad farther though.
Here's a clarke 4.0 pic.
C-dub......
Times are GMT -7.   It's 06:22 PM.
