Old 12-29-2011, 10:40 PM   #36076
hogdoc
Oddometer: 255
Originally Posted by Spud Rider View Post
Good for you, Doc! Thanks for the update.
Spud
Thanks spud , even though it was only a couple miles on a Rukus it felt good to ride!
hogdoc is offline   Reply With Quote
Old 12-29-2011, 11:49 PM   #36077
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 750
Originally Posted by michael.brat View Post
this is a great picture!
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 12-30-2011, 02:31 AM   #36078
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,330
Originally Posted by agspecialties View Post
yes everything is stock other then going one size bigger on the piston a couple months ago. I am not 100% sure, but i am thinking that the jets are Keihin.
check the side of the jets for the keihin symbol punched into them....if Keihin go down to 158 main...if you have the stock air filter you might need to go lower...do Daves mods.......shim the needle,,pull the snorkle..
You may have to go lower on the main...but this will get you close,,,55 pilot should be good..
B
techforlife screwed with this post 12-30-2011 at 02:36 AM
techforlife is offline   Reply With Quote
Old 12-30-2011, 03:11 AM   #36079
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Originally Posted by flatfender View Post
PM sent
Flatfender I'd like that info too. Or you could just post it for all if the shop doesn't mind.
thanks
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 12-30-2011, 05:28 AM   #36080
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,108
What is he doing. Making a huge dust cloud to disguise the number of bikes present so as to scare his emeny. Ever seen the movie " The Charge of the Light Horsemen".
How about this guy " breaking in " his new leather vest. I was out for a quick spin back behind the hood and came across him " doing his thing".
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 12-30-2011, 05:33 AM   #36081
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,108
B
Dose anybody else think just two turns out on the idel mix screw is not enough and could be the cause of the hard starting?
Maybe, but also check the choke plunger installition. It is easey to cross thread the cap and this would result in a vac leak.
Regards
Fritzcoinc
Old 12-30-2011, 06:47 AM   #36082
XR650L
XR650L's Avatar
Oddometer: 224
Info
thanks
John
Hi
Post me the contact info as well please
Busy creating a Monster XR
XR650L is offline   Reply With Quote
Old 12-30-2011, 07:51 AM   #36083
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,513
thanks
John
Originally Posted by XR650L View Post
Hi
Yup , +1
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 12-30-2011, 08:20 AM   #36084
agspecialties
agspecialties's Avatar
Oddometer: 1,159
My exhaust valves were tight. So i adjusted them.
I put new throttle cables and choke cables on. They didn't need to be replaced, but i did it anyway.
The old cables look good. The throttle cables are a little sticky. If anyone wants them chime in.
As far as my jets. The pilot had the star on it, but as far as the main, i can't make out the marks on the jet.
agspecialties screwed with this post 12-30-2011 at 08:26 AM
agspecialties is offline   Reply With Quote
Old 12-30-2011, 09:36 AM   #36085
techforlife
CDI REPAIR
Oddometer: 4,330
It is possible that adjusting the fuel screw may help,low idle can cause hard start,good point.depends on how hard to start it is..but 165 is alot of main jet,,should be addressed too...
B
Old 12-30-2011, 09:37 AM   #36086
techforlife
CDI REPAIR
Oddometer: 4,330
Does the needle have a clip,,if so it`s a Dynojet kit....
Did you adjust the enricher per manual specs?????
B
Old 12-30-2011, 10:12 AM   #36087
agspecialties
Oddometer: 1,159
B
Yes. .006 the manual calls for .004 to .008
Old 12-30-2011, 10:24 AM   #36088
Splittincreek
Splittincreek's Avatar
Oddometer: 77
Originally Posted by Drunk_Uncle View Post
I got my NX650 second gear from cheapcycles.com for like 40 bucks or so.
Link or item No. ?
Splittincreek is offline   Reply With Quote
Old 12-30-2011, 10:51 AM   #36089
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,668
Think its number 7 but I dont remember 100% and I gotta get to a job
http://www.cheapcycleparts.com/model...ssemblies/8583
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 12-30-2011, 01:14 PM   #36090
Splittincreek
Oddometer: 77
Honda NX650 1988
OEM Parts
GEAR, COUNTERSHAFT SECOND (28T) Price: $86.06
Is this the correct one for the NX 2nd Gear Swap? It also shows a 28T for the XRL.....
Times are GMT -7.   It's 09:25 PM.
