Old 01-01-2012, 07:13 PM   #36196
Spud Rider
Spud Rider's Avatar
Oddometer: 3,813
Originally Posted by beechum1 View Post
I remember seeing something somewhere about a bolt that is a quick release connection to drain the oil.... I did a change today and got oil all over the bash guard, which means, all of the F. I've found a few that are for cars specifically, but seen a bit too high profile and I'd be scurred to run them, like the fram sure drain and the Fumoto valve.
Want something lo-pro but easy as pie.
I'm personally unaware of such a bolt, Jeremy. However, I have good success turning the front wheel, and holding my drain pan up to the frame drain bolt. After the frame drains, I re-install the bolt, then move my drain pan under the crankcase. Using a 12mm socket, I break the engine drain bolt. Then I slowly loosen the bolt by hand, and support the bolt as the oil begins to flow through the hole in the skid plate, into the drain pan. After the oil flow slows down, I remove the bolt completely, and allow the rest of the oil to flow out of the engine. This method works very well for me, and doesn't create any mess when I change the oil.
Spud
Old 01-01-2012, 07:45 PM   #36197
GlockPointer
NachosRiflesAlchohol
GlockPointer's Avatar
Oddometer: 382
Mosfet RR
I have been spending my time on the SuperHawk forum learning my new bike and one of the achiles heels of it was the R/R. I read of the zx6r r/r being an easy swap to alleviate the cooking of the stock nonmosfet r/r. This I did and have no probs.
Would this cheap r/r be a good swap onto the XR. They be cheap on ebay, but don't go running the prices up! It is a fhsomethingsomething16something I got for 35 bones.:spla t:sha rk:jomo mma:ostr ich:r ad :lo bbyi zave : sick:kbo om
'03 SuperHawk 996, SP Engineering exhaust, Puig, Eastern Beaver, Full Bore USA tires(you've never heard of them)
09 XRL, Clarke 4.7, Uni, Yoshi RS2, Manrack, T63s, D2Moto pegs, Frazes Mod
'82 NightHawk 450, '71 CB350, '74 CL200, '82 CT110,'81 CT110, '75 XL175, '72 CT90, 2X '71 CT90S
GlockPointer is offline   Reply With Quote
Old 01-01-2012, 07:54 PM   #36198
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,212
Originally Posted by 3girlsdad View Post
is there a case saver/guard for the xr650l to keep the shifter from doing it's damage? i can't seem to find one...
The only one I've found is one on eBay. A fellow rider of mine bought one and after seeing it, it is really small.
A fellow inmate, lasercustoms, was making these for a while but I'm not sure he's around anymore. Every time I try to PM him, he doesn't reply.
I attached mine with JB Weld and then duct taped in on until the JB Weld Hardened. Lasted 2 years before I had to glue it on again.
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 01-01-2012, 07:55 PM   #36199
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,514
the fram sure drain is what I was thinking of.
stays behind the case and keep the mess to the oil filter cover only now.
and what's the thread on the engine drain bolt? 12x1.25?
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 screwed with this post 01-01-2012 at 08:03 PM
beechum1 is online now   Reply With Quote
Old 01-01-2012, 08:47 PM   #36200
Spud Rider
Spud Rider's Avatar
Oddometer: 3,813
Here's a photograph of the stator cover saver I bought from forum member AKARob.
I attached the guard to my stator cover with JB Weld. If Rob is no longer selling these guards, you can make something similar from a small piece of aluminum plate.
Spud
Old 01-01-2012, 09:11 PM   #36201
Grover6
Oddometer: 183
Fellas,
I recently picked up a front end off a cfr250 (Thanks Marko!).
One thing I need is to retain the mounting points on the stock upper triple. So I am curious, can the OEM triples be machined out to accept the larger forks from the crf, without impacting the structural integrity of the triple?
This would save alot of hassle. If not I may have to put out the money on the Emig racing setup.
Grover6 is offline   Reply With Quote
Old 01-01-2012, 09:16 PM   #36202
mendoteach
mendoteach's Avatar
Oddometer: 1,636
Originally Posted by cyclewizard View Post
Every since my camera fell in the river crossing it's never been the same..
Anyone up for chipping in to buy C-Dub a new camera? This crappy pictures of all this bling are killing me. He could be making a lot more money selling to rich GS tools (did I just say that? many aren't, a lot are though). Anyway, the only way he could make less money off parts is by selling to KLR riders (yes, I'm on a roll tonight).
mendoteach is offline   Reply With Quote
Old 01-01-2012, 09:19 PM   #36203
mendoteach
mendoteach's Avatar
Oddometer: 1,636
Originally Posted by Grover6 View Post
Fellas,
No. Stock CRF triples are cheap of ebay. You can get some for less than $50. The emig stem is expensive(around $200). I have it, and it works well. RSW Racing also offers a nice setup, especially if you would like to keep the stock speedo and ignition switch. Steve has the full monty. /he'll post pictures of it shortly There are some machining the stock CRF stem options too.
Old 01-01-2012, 09:20 PM   #36204
mendoteach
mendoteach's Avatar
Oddometer: 1,636
We should buy Steve a couple of kegs and Spud some new tires and...
Old 01-01-2012, 09:32 PM   #36205
Grover6
Oddometer: 183
Mendoteach,
Thanks for the reply. Just to clarify, I have the entire front end already (upper/lower triples, steering stem, forks, wheel/axle). I am trying to keep the swap over as easy as possible. So I was curious if I could keep the stock triples and machine them to accept the crf forks. I need the stock mounting points because I have a Lynx fairing on the bike, which I love and won't get rid of.
The only place I have to have is the two holes where the oem speedo bracket mounted to the triple. But I may be able to tap new holes in the crf triple to make it work.
I'll keep you posted.
Old 01-01-2012, 09:35 PM   #36206
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,514
Fellas,
http://advrider.com/forums/showthread.php?t=656073
Old 01-01-2012, 09:38 PM   #36207
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,752
You can not machine the stock triple to fit the crf forks. You can machine the crf stem to fit the xrl
The RSW triples have the factory speedo mount holes and ignition switch hole
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is online now   Reply With Quote
Old 01-01-2012, 10:12 PM   #36208
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 769
Made my own and included a tether in case it ever popped off, the high temp silicone is holding so far.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 01-01-2012, 10:39 PM   #36209
mendoteach
mendoteach's Avatar
Oddometer: 1,636
Speaking of tethers, has anyone else had the kick stand spring go south? Last year a friend's did, and this fall mine did. I thought the first time was a fluke but perhaps not. I have been thinking about wiring mine. We didn't find his, so he leaned his bike against trees for four days. Safety wire to the rescue!
Old 01-01-2012, 10:59 PM   #36210
ID XR600
ID XR600's Avatar
Oddometer: 245
I squeeze the spring with pliers to make the spring fit tight on both ends.
"Endeavor to persevere."
ID XR600 is offline   Reply With Quote
Times are GMT -7.   It's 07:06 AM.
