Old 01-03-2012, 05:07 PM   #36271
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,286
Originally Posted by beechum1 View Post
It's part of the decel circuit. I don't know enough to explian it, but i'd like to. I guess it keeps a little fuel coming in to keep it from.... popping due to a lean condition.
SOund right experts?
sounds good to me,,let`s go with that
B
techforlife is online now   Reply With Quote
Old 01-03-2012, 05:14 PM   #36272
techforlife
CDI REPAIR
Oddometer: 4,286
Originally Posted by prince_ruben View Post
Hey guys I have a backfiring condition I'm trying to resolve. I have Dave's Mods in a stock carb. It only backfires on decel, nomatter the exhaust (FMF or stock). Where should I be making adjustments?
Did you put in a 55 pilot??????? if so try adsjusting the fuel screw out a little...
Next up is an exhaust leak can do this too...also a punctured decel diaphram like Beechum is refering too or the hose cracked...
B
Old 01-03-2012, 05:39 PM   #36273
agspecialties
agspecialties's Avatar
Oddometer: 1,153
Was cleaning the carb tonight and noticed a really small o ring. WTF does that go. Figured I would ask before going to the parts breakdown.
agspecialties is online now   Reply With Quote
Old 01-03-2012, 05:40 PM   #36274
Streaks
Gardener
Streaks's Avatar
Oddometer: 13
update
Ok thanks guys for the replies. I don't suspect the cdi but I banged, put it back, checked fuel, still plenty of flow, sprayed carb cleaner on boots, no vacuum leaks, and fooled with the idle speed, runs longer before stalling and no more back fire but still stalls after a minute or so and I have to wait a minute or so before it starts up. I'm going to check the valves but I don't have those fancy two way angled feelers and might have to order them. There is a ticking at idle (sounds like an exhaust leak but its not) that seems to go away as I rev the motor, Im not sure if its a bad plug wire or what
Streaks is offline   Reply With Quote
Old 01-03-2012, 05:44 PM   #36275
cyclewizard
cyclewizard's Avatar
Oddometer: 4,811
Originally Posted by katbeanz View Post
Paging Cdub!
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 01-03-2012, 05:46 PM   #36276
techforlife
CDI REPAIR
Oddometer: 4,286
Usually the small oring goes at the bottom of the spring/washer on the fuel mixture screw.......
What do i win??????
B
Old 01-03-2012, 05:48 PM   #36277
agspecialties
Oddometer: 1,153
Originally Posted by techforlife View Post
What do i win??????
B
A big THANK YOU.
Old 01-03-2012, 05:50 PM   #36278
techforlife
CDI REPAIR
Oddometer: 4,286
Put it at TDC on compression stroke,,line up the mark.......pull the adjustment covers..if you can grab the adjuster screw and can`t lift the arm up/down a tiny bit then the valves are tight and you found the problem...
Just make sure you read the manual,,turn the engine over in the proper direction and do not back up if you miss the mark,,or the decomp will activate and the right exhaust valve will show tight..
BUT........my bike would run,,,quit,then not restart and it was the CDI......that`s what got me started rebuilding them in the first place,,but i`d still check those valves first..
B
Old 01-03-2012, 05:51 PM   #36279
techforlife
CDI REPAIR
Oddometer: 4,286
A big THANK YOU.
Alright,,guess that`ll do
B
Old 01-03-2012, 06:04 PM   #36280
Streaks
Gardener
Streaks's Avatar
Oddometer: 13
B
Ok Ill do that check on the valves right now
Old 01-03-2012, 06:14 PM   #36281
bm3moose
bm3moose's Avatar
Oddometer: 168
Streaks
Mine is doing the same thing, backfires on decel pretty bad and then dies all the time at idle, conveniently at stop signs and green lights. I'm going to try the pilot screw but would valves do this as well?
08 XR650L
bm3moose is offline   Reply With Quote
Old 01-03-2012, 06:25 PM   #36282
Streaks
Gardener
Streaks's Avatar
Oddometer: 13
Well I think I found the source of the ticking, I checked the valves, intake seems ok, both exhaust valves were tight. Ill have to see tomorrow if crappy Cycle Gear sells the feelers. Man I hope I didnt wreck the motor
Old 01-03-2012, 06:25 PM   #36283
Streaks
Gardener
Streaks's Avatar
Oddometer: 13
Could be but I would look at your jetting
Old 01-03-2012, 06:33 PM   #36284
techforlife
CDI REPAIR
Oddometer: 4,286
Absolutely
B
Old 01-03-2012, 06:34 PM   #36285
techforlife
CDI REPAIR
Oddometer: 4,286
Cool,like i said on ThumperTalk..........what do i win
Valves are pretty tough,should be alright..
B
Times are GMT -7.   It's 03:03 PM.
