Old 01-03-2012, 05:34 PM   #36286
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 3,312
Originally Posted by Streaks View Post
Well I think I found the source of the ticking, I checked the valves, intake seems ok, both exhaust valves were tight. Ill have to see tomorrow if crappy Cycle Gear sells the feelers. Man I hope I didnt wreck the motor
Cool,like i said on ThumperTalk..........what do i win
Valves are pretty tough,should be alright..
B
01 XR650L,102mm JE 11.25:1..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
techforlife is online now   Reply With Quote
Old 01-03-2012, 05:35 PM   #36287
jgas
Stoogely Adventurerer
Oddometer: 794
XRL compression?
I'm looking at an 07 650 L, I know the compression is fairly low compared to the old 600, and I've been looking for solid info on it. I've read in various places that it is 8.5-10.5 for the L. Did they change it over the years? Or is it possible that they vary by country?
I recently rode a modded DRZ 470, and it ran like a scalded redneck on steriods, but when it was hot the starter/battery would barely crank it. I have a DRZ 400 and was considering a big bore kit, but I want total reliability and don't think a built DRZ will be that. I raced XR 600s from 92-99 and loved them.
My thinking is that a 650L with only hot cams and high compression piston would be bulletproof and quite a bit more powerful than any DRZ-anything? I've considered just going nuts with a KTM 950 Superenduro, but 400+ lbs loaded with camping gear just might be a bit much. And I looked at one recently, working on it didn't seem too fun of an idea. They put a big block twin in a little bitty frame. Fixing that monster on the trail might just be beyone me.
Thank you guys for this thread. I've been lurking here quite a while.
Jeff.
jgas
Question of the century: "When the little Singletrack remaining is gone, and we can't ride on the existing Two-track, will you be nhappy riding only on a few dirt roads and pavement? If not, what are you going to do about it"?
Certified JB Welder.
Certified 3M Duct Tape installer.
Certified Farmer's Co-Op bailing wire expert.
Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
02 KTM 520 exc
DRZ 400
95 XR 250
2001 KLR 650
jgas is offline   Reply With Quote
Old 01-03-2012, 05:36 PM   #36288
techforlife
CDI REPAIR
Oddometer: 3,312
Jeff.
OE piston is low compression 8.5 or lower........8.3-1 i think..all years....unless modified by owner..
Bump the comp to 10.5-1 and get a decent cam......and no..a Hotcam is NOT a decent cam,it has fried a pile of XR650l top ends..
It seems it`s a hit/miss thing in these engines,,,some are user error not setting the lash to HotCam specs,,,some appear to just eat the rockers for no apparent reason...
As Steve says ... "YOU HAVE BEEN WARNED"
Oh,i was riding with a guy with a modded DRZ last summer.....nice bike,,but not getting anywhere near me with a modified XR650L..
not even close...
B
techforlife screwed with this post 01-03-2012 at 05:46 PM
Old 01-03-2012, 05:39 PM   #36289
Streaks
Gardener
Streaks's Avatar
Oddometer: 13
B
If you were closer, BEER
Streaks is offline   Reply With Quote
Old 01-03-2012, 05:43 PM   #36290
techforlife
CDI REPAIR
Oddometer: 3,312
NOW YOUR TALKIN
B
Old 01-03-2012, 05:52 PM   #36291
agspecialties
agspecialties's Avatar
Oddometer: 1,028
I tried the pinesol trick cleaning the carb. It worked great. When i was done, i left the pinesol in the bucket. I can't believe how it seperated and got all gummy.
If you clean your carb, don't let it sit in there to long. That would be a mess to clean.
agspecialties is online now   Reply With Quote
Old 01-03-2012, 05:54 PM   #36292
techforlife
CDI REPAIR
Oddometer: 3,312
Hmmmm,,that`s good to know..
B
Old 01-03-2012, 05:58 PM   #36293
agspecialties
Oddometer: 1,028
I figured out that it started to break down and seperate around the third day or fourth day.
Old 01-03-2012, 06:00 PM   #36294
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 6,591
Jeff.
Jeffro!
katbeanz is offline   Reply With Quote
Old 01-03-2012, 06:08 PM   #36295
beechum1
beechum1's Avatar
Oddometer: 4,806
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Originally Posted by bm3moose View Post
Mine is doing the same thing, backfires on decel pretty bad and then dies all the time at idle, conveniently at stop signs and green lights. I'm going to try the pilot screw but would valves do this as well?
Could be a dirty pilot jet also.
Sent from my LG-P509 using Tapatalk
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
beechum1 is online now   Reply With Quote
Old 01-03-2012, 09:03 PM   #36296
flyingwombat
frozen dead guy
flyingwombat's Avatar
Oddometer: 619
Originally Posted by Grover6 View Post
Fellas,
I recently picked up a front end off a cfr250 (Thanks Marko!).
One thing I need is to retain the mounting points on the stock upper triple. So I am curious, can the OEM triples be machined out to accept the larger forks from the crf, without impacting the structural integrity of the triple?
This would save alot of hassle. If not I may have to put out the money on the Emig racing setup.
Personally, I think you'd be nuts to modify the triples, just because that's a critical part. If it fails, it's a faceplant.
Bad Medicine: Baja October 2011
Please help support COHVCO!
flyingwombat is offline   Reply With Quote
Old 01-03-2012, 09:08 PM   #36297
flyingwombat
frozen dead guy
Oddometer: 619
Anyone using Highway Dirt Bikes folding morrors and barkbusters?? Are they worth the money?
The mirrors are decent and the bash guards are the best there is. I crash tested the hell out of them in Moab and I don't think they are even bent. The top clamp with switches and powerlet outlets is sweet also. Worth the money? I guess that depends if you ride it like a dirtbike a lot and/or want switches and outlets without doing fab work. It made a bit more sense for me since my L didn't come with mirrors.
Old 01-03-2012, 09:22 PM   #36298
farrington300
No wait....What?
farrington300's Avatar
Oddometer: 448
Hey Guys,
I stripped out one of the two 10mm bolts that hold the valve cover on. Its the front right one. It goes through the valve cover, the head, and into the jug. Is there a way to repair it (helicoil, etc.) with out disassembling the motor. I have put in helicoils, but never into a hole that is 4-5 inches deep. Any help would be greatly appreciated.
KLR685
XR650L
TE610
farrington300 is offline   Reply With Quote
Old 01-03-2012, 09:37 PM   #36299
michael.brat
michael.brat's Avatar
Oddometer: 459
Originally Posted by ThumpnRed View Post
I fabbed my own as well. I went "full wrap" to make it look less like a patch.
Wanna make some more for us? I'll take one!!
Mike B
michael.brat is offline   Reply With Quote
Old 01-03-2012, 09:41 PM   #36300
beechum1
beechum1's Avatar
Oddometer: 4,806
Originally Posted by farrington300 View Post
Hey Guys,
Pull the motor, and cover the piston. Or pull the part. Only two options.
Times are GMT -7.   It's 04:24 PM.
