Old 01-31-2012, 04:51 PM   #37726
Dadster
I'd rather be ridin
Dadster's Avatar
Oddometer: 211
How's that. I know its not a direct link on this page but im navigating the web from my phone.
99 CR 250
06 XR 650L
03 KDX 50 Bacon Boy's
07 Hawkeye 300 4x4 Margarita Momma's
Dadster is offline   Reply With Quote
Old 01-31-2012, 05:11 PM   #37727
mcma111
mcma111's Avatar
Oddometer: 11,865
Hard to tell with all of the exhaust noise. How about trying again outside the garage?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-31-2012, 05:12 PM   #37728
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,280
Originally Posted by Dadster View Post
Does the overhead sound noisy? I move from one side to the other.http://static.photobucket.com/player...-21-51_199.mp4
Can`t pick anything out there that sounds bad.........but a recording is hard to tell most times.......should sound like a well lube sewing machine...no joke,really........
B
techforlife is offline   Reply With Quote
Old 01-31-2012, 05:31 PM   #37729
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Originally Posted by mcma111 View Post
Part #7 is part of a anti kick-back/back fire assy. It is different than the decom assy. The whole set up is explained in my OE XR600 service manual that is at home. Can't see it from work...
Thank you, Steve. If you have time after you arrive home, please explain how part #7 works.
Spud
Old 01-31-2012, 05:33 PM   #37730
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Originally Posted by elsalvadorklr View Post
Tusk rotor, great value...good feel too, cheapcycle parts, motorcycle supertsore or rocky mountain atv are your best bets...
In my humbe opinion ebc's are WAY overpriced...
cheers
I like Tusk products, and I was going to recommend a Tusk brake rotor, but I couldn't find one manufactured for the XR650L.
Spud
Old 01-31-2012, 05:34 PM   #37731
mcma111
mcma111's Avatar
Oddometer: 11,865
I'll have to bring the XR600 service manual to work tomorrow. The home computer took a dirt nap yesterday.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-31-2012, 05:36 PM   #37732
elsalvadorklr
southern xr rider
Oddometer: 4,154
Spud
aja forgot I was on the xrl thread...geez these bikes and their similarities...
I also forgot that the xrl rotor IS bigger...I do think the mounting points/holes are the same though...
in any case sorry for stirring the pot!
elsalvadorklr is offline   Reply With Quote
Old 01-31-2012, 05:37 PM   #37733
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Thank you, Steve. I will happily wait until tomorrow for the answer.
Spud
Old 01-31-2012, 05:39 PM   #37734
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
No problema, senor. I thought perhaps Tusk previously made a rotor for the XR650L, but discontinued it.
Spud
Old 01-31-2012, 06:00 PM   #37735
Dadster
I'd rather be ridin
Dadster's Avatar
Oddometer: 211
Ok. Maybe this is more clear.
http://static.photobucket.com/player...-40-04_343.mp4
Does that sound noisy?
99 CR 250
06 XR 650L
Old 01-31-2012, 06:02 PM   #37736
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,035
For the big guys out there 230+ lbs, are you running .47 or .50 KG spring rates in the front. I am ready to pull the trigger and I want to make sure that I only do this once. I don't do single track. Fire roads and street sometines fast in the dirt mostly reasonable.
I'll have a 12.5 in the rear courtesy of Steve.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is online now   Reply With Quote
Old 01-31-2012, 06:04 PM   #37737
mcma111
mcma111's Avatar
Oddometer: 11,865
Better. Doesn't sound bad. Can you do it again in daylight so we can see the bike better?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-31-2012, 06:06 PM   #37738
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Apparently part #5 partially opens the exhaust valve to decrease engine compression to 92 psi as the starter motor turns the crankshaft at 400 rpm. I reach this conclusion from reading page 1-7 of the XR650L Service Manual.
I have read you must loosen the right exhaust valve to at least 0.82 mm clearance before you can measure the actual engine compression with all valves closed. Is this correct? If so, part #5 must either be shorter than the adjacent cam lobe, or part #5 contacts a different part of the rocker.
Spud
Spud Rider screwed with this post 01-31-2012 at 09:29 PM
Old 01-31-2012, 06:11 PM   #37739
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
It's tough to tell from a video soundtrack, but your engine doesn't sound bad to me, Dadster. Did you verify oil flow to the cylinder head?
Spud
Spud Rider screwed with this post 02-01-2012 at 12:12 AM
Old 01-31-2012, 06:13 PM   #37740
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Different part of Rocker
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Times are GMT -7.   It's 12:20 PM.
