Old 03-22-2012, 11:15 AM   #40426
Haywood
Haywood's Avatar
Oddometer: 402
Originally Posted by hanksmybuddy View Post
L is really hard starting. Turns over for quite a while prior to firing. When it finally fires have to hold down on the starter to fire it up. Any ideas? Once running, it's fine and fires right up after it's warm.
I had the same problem. For my bike it was the side stand safety switch. I disconnected it and jumpered the wires at the plug conection. Problem solved. I took the switch and the wire off the bike completely. Others have had problems with the starter button also. I disassembled that and cleaned it before I did the side stand switch. The bike fires right up now.
Haywood is offline   Reply With Quote
Old 03-22-2012, 11:15 AM   #40427
elsalvadorklr
southern xr rider
Oddometer: 4,154
all this back and forth about stems and whatnot...
yeah the xrl has more doses of sickness than the xr600 thread, so I get to fart around here too!
peace!
elsalvadorklr is offline   Reply With Quote
Old 03-22-2012, 11:18 AM   #40428
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
Originally Posted by Barron View Post
Sir, you are one sick, sick puppy. At least you're in the right place!
welcome back
www.manracks.com
jungleplant is offline   Reply With Quote
Old 03-22-2012, 11:21 AM   #40429
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
Originally Posted by Brtp4 View Post
Dude is senile....he's probably pushing the horn button.....
BP
Funny story...
I was riding down the highway one dark morning on my way to work when I used my horn... I lost everything except my head light. Turned out one of my horns had filled with water and shorted out... Luckily I don't trust fuses and had spares with me, I replaced it had a LONG crappy day at work totally forgot about the short, got cut off by some dude on my way home, hit the horn and killed it all again... I put in another fuse and disconnected that horn until I replaced it with a siren.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 03-22-2012, 11:22 AM   #40430
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
Originally Posted by jungleplant View Post
welcome back
Thank you!
Old 03-22-2012, 11:57 AM   #40431
AZ TOM
Oddometer: 4,074
Funny story...
-Barron
Pretty Horney post
AZ TOM is offline   Reply With Quote
Old 03-22-2012, 12:52 PM   #40432
XR650L
XR650L's Avatar
Oddometer: 225
Ride Report - Buffalo, South Africa
Well, Day 1's report is posted
Buffalo Trip - South Africa
Busy creating a Monster XR
XR650L is online now   Reply With Quote
Old 03-22-2012, 02:19 PM   #40433
Rocket_Rookie
Learning the ropes!
Rocket_Rookie's Avatar
Oddometer: 54
Guys, check out XR650L's ride report.
It looks promising!
Two wheels good, one wheel better.
'92 Honda XR600R
Rocket_Rookie is offline   Reply With Quote
Old 03-22-2012, 02:27 PM   #40434
sc-razor
sc-razor's Avatar
Oddometer: 3,776
It looks promising!
Pretty neat stuff!
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 03-22-2012, 02:50 PM   #40435
mchester
Honda Cult Member
mchester's Avatar
Oddometer: 1,466
Originally Posted by purpledrake View Post
I saw your previous notes about the Velcro, and I look forward to your future reports and photographs. PD
I wrapped the CDI in industrial bubble wrap, attached it to the airbox wall with 3M Dual Lock,then zip tied it in place. It hasn't moved in 3 years and it's still alive.
"I intend to live forever. So far, so good" Steven Wright
"If you choose not to decide, you still have made a choice" Rush
2004 XR650L & 2003 ST1300
mchester is offline   Reply With Quote
Old 03-22-2012, 07:59 PM   #40436
Spud Rider
Spud Rider's Avatar
Oddometer: 3,813
Originally Posted by fritzcoinc View Post
Glad you thought that funny! Getting your patches to animate might be a trick.
Spud
Old 03-22-2012, 08:34 PM   #40437
hanksmybuddy
hanksmybuddy's Avatar
Oddometer: 408
Maybe you're choking it too much, or your carb might be dirty. Has the bike sat with gas in the carb for a while?
-Barron
No, gas should be fine. I put non-ethanol in it about a month ago. Shouldn't go bad in 3 to 4 weeks I wouldn't think but what the hell do I know. Damn thing is a pain when it's cold. Could it possibly be my CDI going bad?
hanksmybuddy is offline   Reply With Quote
Old 03-22-2012, 08:48 PM   #40438
Idaho_XR
Idaho_XR's Avatar
Oddometer: 259
I have a similar problem sometimes and my bike does not want to start like it is not getting spark. My CDI is relatively new so I do not think this is the problem. Sometimes when the temp. rises I still pull the choke out of habbit and I think this may get the spark plug too wet with gas to fire (or not enough air). Of course I am just speculating here. Once I let it sit for a couple of minutes it usually fires right up. I can smell gas when this happens, so I think it is due to a flooded condition.
Idaho_XR is offline   Reply With Quote
Old 03-22-2012, 08:57 PM   #40439
hanksmybuddy
Oddometer: 408
Exactly what mine does. Just doesn't seem to be getting spark. Eventually it sparks and then I seem to get it going. Problem is I get out there sometimes and am solo. Headed to Death Valley for 7 days of solo riding and I want the damn thing to start.
Old 03-22-2012, 09:04 PM   #40440
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,286
Try draining the carb. Gas won't go bad in the tank in 3 to 4 weeks, but it sure will in the float bowl.
Mine also starts a lot easier if the side stand is retracted.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is online now   Reply With Quote
Times are GMT -7.   It's 11:20 PM.
