Old 03-22-2012, 08:57 PM   #40441
hanksmybuddy
hanksmybuddy's Avatar
Oddometer: 264
Originally Posted by Idaho_XR View Post
I have a similar problem sometimes and my bike does not want to start like it is not getting spark. My CDI is relatively new so I do not think this is the problem. Sometimes when the temp. rises I still pull the choke out of habbit and I think this may get the spark plug too wet with gas to fire (or not enough air). Of course I am just speculating here. Once I let it sit for a couple of minutes it usually fires right up. I can smell gas when this happens, so I think it is due to a flooded condition.
Exactly what mine does. Just doesn't seem to be getting spark. Eventually it sparks and then I seem to get it going. Problem is I get out there sometimes and am solo. Headed to Death Valley for 7 days of solo riding and I want the damn thing to start.
hanksmybuddy is offline   Reply With Quote
Old 03-22-2012, 09:04 PM   #40442
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,025
Originally Posted by hanksmybuddy View Post
No, gas should be fine. I put non-ethanol in it about a month ago. Shouldn't go bad in 3 to 4 weeks I wouldn't think but what the hell do I know. Damn thing is a pain when it's cold. Could it possibly be my CDI going bad?
Try draining the carb. Gas won't go bad in the tank in 3 to 4 weeks, but it sure will in the float bowl.
Mine also starts a lot easier if the side stand is retracted.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 03-22-2012, 09:15 PM   #40443
Idaho_XR
No complaints
Idaho_XR's Avatar
Oddometer: 238
Walter
Good point Walter, but mine does this sometimes after I have ridden to somewhere and the gas is in the bowl is fresh when I go to start it. This leads me to believe in a "over choke" condition. When ever this happens I do bang on the battery box sometimes just in case it's the CDI, but I don't think this is the case as it has only got a couple thousand miles on it.
Idaho_XR screwed with this post 03-22-2012 at 09:21 PM
Idaho_XR is offline   Reply With Quote
Old 03-22-2012, 11:18 PM   #40444
purpledrake
No Pretensions
Oddometer: 277
Zip Tie
Originally Posted by mchester View Post
I wrapped the CDI in industrial bubble wrap, attached it to the airbox wall with 3M Dual Lock,then zip tied it in place. It hasn't moved in 3 years and it's still alive.
Hey Mchester,
How did you Zip Tie your CDI into place? Please share a photo if you have one.
I have finished my tie-down job, and will post a picture soon. I also zipped the unit inside the air box, and used Velcro as well (following Mr. Spud's advice). I don't like my zipping method, however, and am looking for a better idea.
PD
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 03-23-2012, 02:02 AM   #40445
KyoXR
KyoXR's Avatar
Oddometer: 407
L is really hard starting. Turns over for quite a while prior to firing. When it finally fires have to hold down on the starter to fire it up. Any ideas? Once running, it's fine and fires right up after it's warm.
also check to make sure your spark plug hasn't loosened up, It appears that the BRP likes to sometimes slowly spit them out.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
KyoXR is offline   Reply With Quote
Old 03-23-2012, 03:30 AM   #40446
jesse_a29
jesse_a29's Avatar
Oddometer: 7
I just got my 84 xl350 running. Its at 7000 miles does anyone know any of the milestone maitenance i should be coming upon? It been sitting since 94. I had the carbs redone and changed oil.
jesse_a29 is offline   Reply With Quote
Old 03-23-2012, 05:17 AM   #40447
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 1,943
Have you cleaned the plug? It might be partially fouled... Good time to make sure it's tight and the connection into the boot is good and make sure the boot is tight too.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 03-23-2012, 05:21 AM   #40448
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 516
gas gas
Hi All,
I try to put a splash of STABIL in the tank every once in a while.....
When my bike sits for a few weeks it is hard to start...I either drain the carb or put the bike on it's side until gas comes out the overflow...always fires right up.
Q: why does XR650L and others in ZA run YELLOW headlight covers?
E3
'02 XRL '95 K11RS
ecubed is offline   Reply With Quote
Old 03-23-2012, 05:35 AM   #40449
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 1,943
E3
What's ZA?
Zebras Anonymous?
Zambia Avalanches?
Zoo Administration?
Zoro's ADV bike?
Zinkerpop Aperstein?
Zumba Aerobics?
I'm really at a loss here....
-Barron
Old 03-23-2012, 05:50 AM   #40450
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 639
my L after its annual bath just need to put on a black seat cover that i ordered off ebay and ill finished spending $$ on it for a while. (though I might put on an aftermarket head pipe or some kind. any suggestions on that?)
1994 Yamaha WR250-Z
2005 Gas Gas FSE450
"Great! What am I supposed to use now?! Harsh language?!?!?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 03-23-2012, 05:52 AM   #40451
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 1,943
I just put on an FMF power bomb and I like it a lot. Gotta figure out that sweet heat shield/hose clamp thing though... unless someone would be so kind as to re-post it
-Barron
Old 03-23-2012, 05:59 AM   #40452
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,299
Park,
Are you sure you're jetted for the elevation? My '94 used to act the same way when I lived in Redmond but now that I'm in low country GA it's better. Also, if you're going to let it sit for a while, like over night, shut the gas off before turning the engine off. A new plug might be in order too. Post pics from you trip OK?
Stuart
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 03-23-2012, 06:01 AM   #40453
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 516
Originally Posted by Barron View Post
What's ZA?
Zebras Anonymous?
Zambia Avalanches?
Zoo Administration?
Zoro's ADV bike?
Zumba Aerobics?
-Barron
Country code for South Africa......what the heck is Zinkerpoop Aperstein??
'02 XRL '95 K11RS
Old 03-23-2012, 06:05 AM   #40454
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,299
My $.02: skid plate & brush guards/hand guards
What kind of chain is that and is it red?
Prov 3:5 & 6
Old 03-23-2012, 06:07 AM   #40455
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 516
FORK BRACE!! sorry for yelling (and a SS front brake line)
'02 XRL '95 K11RS
ecubed screwed with this post 03-23-2012 at 06:10 AM Reason: added brake line
Times are GMT -7.   It's 11:52 PM.
