04-05-2012, 06:43 PM
#41026 |
Oddometer: 2,774
KatBeanz
Katbeanz..... Who's your buddy???
![]() Here is bike pron for ya!!!! Lookin' badass my brother! ![]() Another view..... ![]() And... Another!!!!
04-05-2012, 06:46 PM
#41027 | |
Oddometer: 2,774
Now, we just need a super duty oil pump, a larger feed line to the head and some high RPM testing to monitor oil flow and pressure.... Getting the oiling and rocker rollers, in my opinion will finish this out into a really long, long life motor. Still gonna do my best to blow the shit out of them!!!!! ![]() |
04-05-2012, 06:48 PM
#41028 | |
Oddometer: 3,974
hey fritzco... The manual clearly states to USE a 9range plug for prolonged high speed use, to counter these exact issues.... if your commuting everyday at "highspeed" its our obligation to at least change to this plug. I have been told too that if you only ride slow tough singletrack a 7 range plug is good to prevent too much fouling... ???????? anybody else? cheers |
04-05-2012, 07:00 PM
#41029 |
Oddometer: 44
What does this mean?
While coming to a stop and downshifting, I will sometimes miss Neutral and downshift all the way to 1st gear. When I come to a complete stop and try to shift to Neutral from 1st, the bike doesn't want to cooperate. Is this a sign of anything? What should I be saving money for?
Thanks for any input.Jesse |
04-05-2012, 07:03 PM
#41030 | |
Oddometer: 55
I did adust it before and after. Maybe I missed it. |
04-05-2012, 07:05 PM
#41031 | |
Oddometer: 2,435
04-05-2012, 07:13 PM
#41032 | |
Oddometer: 3,974
the first thing I notice after changing oil is how buttery smooth and precise each gearshift is... also whenever I get false neutrals or have notchy gear shifts I plan on doing an oil change... clutch adjust helps too... good luck |
04-05-2012, 07:14 PM
#41033 | |
Oddometer: 55
So I'm clear, I rotate slowly until the click, then immediately set the valve to .004. Then run to the 46 coupe to complete the dash wiring so I can fire it up for the first time. |
04-05-2012, 07:24 PM
#41034 |
Oddometer: 2,999
![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
04-05-2012, 07:31 PM
#41035 |
Crash test dummy
Oddometer: 5,228
Like I said earlier I am a chain Uber n00b. What is the difference between the 500, 520, 525 etc? Or I guess a better question is what chain do I need and what kind master link? Obviously that will dictate what kind of masterlink tool that I need.
Where am I? "I love the wild spaces above the border, takes some work to get here, ain’t a Starbucks run." jdrocks F*CK Cancer |
04-05-2012, 07:42 PM
#41036 | |
Oddometer: 8,145
Time for a new clutch. BTDT.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
04-05-2012, 07:58 PM
#41037 |
frozen dead guy
Oddometer: 620
Yup I sure do want to try one!
04-05-2012, 08:15 PM
#41038 |
Oddometer: 469
Also... If the clutch plates have worn into the basket, file the indentations out...
My clutch never felt right, it never fully disengaged, it was always grabbing a bit, even though the previous owner put new plates in it... When I pulled it apart I found the steel and fiber plates were as good as new but there was decent indentations in the basket: (they were fairly deep even though they dont look it in the photo) ![]() (I assume the indentations hindered the plates separating as they should) I de-greased it and sealed up the back with duct tape so I wouldn't have to clean all the specs of aluminum out of the springs later: ![]() Filed the indentations out: ![]() The clutch feels great now :)
*** Tasmania - Gods own adventure playground *** Tasmania on a Dominator .... Tasmania on a Tenere FLICKIT screwed with this post 04-05-2012 at 08:35 PM |
04-05-2012, 08:29 PM
#41039 | |
M0DAH0LIC
Oddometer: 1,953
-Barron
1996 XR650L with a couple mods If everyone brewed beer there would be no war. ![]()
04-05-2012, 08:37 PM
#41040 | |
Oddometer: 3,974
if you wheelie a lot or hammer the engine on the street this is probably what you have going on too... i did this on my xr...shifting is butter, sill has the oem clutch pack...24 years old cheers |
