Old 04-17-2012, 07:58 PM   #41476
Hound Dawg
Oddometer: 39
PDM60 v2
Originally Posted by beechum1 View Post
PDM60, not sold anymore?
They now have version 2 out with some nice upgrades including an integrated SAE battery tender plug. Aerostich is the only supplier. Here's the link.
http://www.aerostich.com/pressroom/d...108_pdm60.html
Hound Dawg is offline   Reply With Quote
Old 04-17-2012, 08:09 PM   #41477
Hound Dawg
Oddometer: 39
PDM60 v2
[QUOTE=purpledrake;18475229]
Originally Posted by Hound Dawg View Post
New to me. "07 with 4300 miles. Getting ready to install Michelin T63s with HD 4mil tubes. Bolting up the Wolfman Expedition Racks and SaddleBags this weekend. Has ACERBIS 5.8 tank, FMF Q4 exhaust, and tail rack. Just added the PDM60 for all the electrical farkles. 12 Volt Acc Plug, Heat Demon Grip Heaters, RoxSpeed 2 inch risers, Pro-Taper EVO bars, Moose Barkbusters, Slipstreamer Tombstone Windshield, Wolfman Enduro Tank Bag, Pivot Pegz on the way from down under, Eastern Beaver headlight relay kit, small DOT taillight, UNI air filter, Daves Mods and De-smogged. Looking to add a skidplate soon.
PDM60 Wired into Airbox:
Hey Hound Dawg,
Welcome, and the set up looks very nice. Tell us about the power module: What do you power off of it? (You eliminate the stock fuses, right? Does the CDI go or stay? Did you upgrade the alternator?)
Well done!
PD
I just left all the stock stuff alone. This unit wires direct to the battery and then connect up to 60 amps total capacity over 6 different circuits with a max draw of 15 amps (3 are 15 amps and 3 are 5 amps). Currently I'm running heat demon grip heaters, 12v power outlet, and Eastern Beaver headlight relay off of this unit. I'm also adding a small clock/temp/voltmeter unit. I'm probably going to hook up some extra led lighting and another accessory for a headed vest. It's a really simple unit. No need to every worry about fuses again. $129 at Aerostich.com. I did add three 1 inch uni air vents to the top of my box due to some diminished airflow from the wiring in the airbox. I havent's really noticed any hinderance from this however. Running just as it did before the mod. Hope that helps. This thread has a lot of information thanks to John Smallberries:
http://www.advrider.com/forums/showthread.php?t=638076
Old 04-17-2012, 09:31 PM   #41478
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,505
Thanks, couldn't find it on their site or google. My fu was weak.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 04-18-2012, 12:41 AM   #41479
mendoteach
mendoteach's Avatar
Oddometer: 1,635
Originally Posted by sc-razor View Post
Rocks, rocks, rocks! Hitting washes at speed is really the only place it is better. Flys straight and level and lands soft. I just don't see any way possible I am going to go heavier springs when it is beating the shit out of me now. I may have gained sag from the original springs but except for large loose rocks the originals were much plusher. Loose gravel roads and this:
Harshness can often come from being under sprung and/or under damped. You blow through the initial travel and then get avery steep rising damping rate causing a semi-hydraulic locking. This is how old orifice forks felt. Suspension tuning is often counter intuitive. Buy Race Tech's Suspension Bible. Best money you'll spend on many bikes!
mendoteach is offline   Reply With Quote
Old 04-18-2012, 06:17 AM   #41480
sc-razor
sc-razor's Avatar
Oddometer: 3,776
Thanks teach!
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 04-18-2012, 06:19 AM   #41481
XR650L_Dave
Oddometer: 3,758
Originally Posted by 1Bonehead View Post
Didn't someone here put a newer style CDI in recently where did they get it?
Only aftermarket CDI I ever hear about is the Megajolt.
Needs a custom reluctor on the crank, I think.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 04-18-2012, 06:46 AM   #41482
flyingwombat
frozen dead guy
flyingwombat's Avatar
Oddometer: 789
Cdi
I haven't tried it myself, but this is it:
http://www.motorbike-shop.de/index.php?a=2928
http://www.motorbike-shop.de/index.php?a=3154
http://www.motorbike-shop.de/index.php?a=3153
You'll need Google Translate unless you know German. I haven't bothered to translate it so I can't tell you the difference between the 3.
From what I've read on this very thread, it's a direct plug and play replacement.
Bad Medicine - White Rim Sandwich
Help keep our trails open, support COHVCO, AMA, BRC, TPA, etc.
flyingwombat is offline   Reply With Quote
Old 04-18-2012, 07:13 AM   #41483
XR650L_Dave
Oddometer: 3,758
The 124 pounder:
The CDI works on these vehicles:
Honda Dominator NX500 PD08 model years' XX to "XX
Honda NX650 Dominator of the years 'to XX' XX
Honda XR650L RD06 built between xx to yy
each with and without side stand switch.
They replaced the CDI-Type MN9 CI554
This was the Transalp CDI CDI (H003) further developed and adapted specifically for the Domi.
It was extensively in the vehicle and tested on a dynamometer.
The spark is triggered earlier in this model than in the original CDIs.
This improves power and torque and reduced fuel consumption.
Through the better fuel (minimum RON 95), the margin is for this improvement.
When you return to the models where this fits CDI,
further information or have additions,
then you can ask us happy.
We are open to it.
Installation instructions for vehicles with side stand off
First, check whether the engine is running properly on this hardware.
Side stand, clutch and gear before pulling - the engine will not start.
Make an extensive test drive, preferably over several kilometers.
If the CDI is not functioning properly, please contact us.
In most vehicles, a side stand switch is installed, which must now be activated.
For this, the wire loop is separated at the CDI and the experiment with the stator is repeated.
Old 04-18-2012, 07:15 AM   #41484
XR650L_Dave
Oddometer: 3,758
The 139 pounder:
Honda Dominator NX500 PD08 model years 'to'
Honda NX650 Dominator of the years 'to'
Honda XR650L RD06 constructed before yy
A new PCB improves Funkentsörung (EMC) significantly.
If you fit the models in which the CDI
further information or amendments have
We are open to it.
First, it is checked whether the motor is running properly on this hardware.
Side stand and pull clutch in gear - the engine will not start.
Make an extensive test run is best for miles.
If the CDI is not functioning properly please contact us.
In most vehicles is a side stand switch installed which now must be enabled.
It must start the engine then.
Old 04-18-2012, 07:17 AM   #41485
XR650L_Dave
Oddometer: 3,758
And the 99 pounder:
CDIs are used or second-choice defective CDIs have been repaired. These devices were all tested by Werner Moehrle. This CDIs as a 2 year warranty as new CDIs.
We are open to it.
Old 04-18-2012, 07:31 AM   #41486
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,519
I wonder which 1 this is , I got it from an Inmate a litte while back , havent tried it yet tho.
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 04-18-2012, 09:27 AM   #41487
Bell driver
Bell driver's Avatar
Oddometer: 345
It's a CDI from/for an NX650 Dominator, obviously tested by a German repair/manufacturer's station.
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Bell driver is offline   Reply With Quote
Old 04-18-2012, 09:38 AM   #41488
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,519
This is 1 of the ones Dave posted the translations about , Just dont know which one ,
the 99.99 or the 139.00
Marko
Old 04-18-2012, 10:10 AM   #41489
Bell driver
Oddometer: 345
If you want something really nice, get the programmable CDI from Ignitech.cz. Have one in my XLV, see signature, whole new beast.
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Old 04-18-2012, 10:46 AM   #41490
RonZacapa
RonZacapa's Avatar
Oddometer: 66
The 99 Euro job is a rebuilt unit that also carries a 2 year guarantee like the others. The 124 Euro is the original new unit. The 139 Euro unit is the evo model with better spark supression over and above the 124 variety. For me it would be the 124 or 139 version. Interesting to see that the timing is advanced slightly over original Honda part which according to the makers gives better performance, torque and fuel consumption - using 95 RON fuel.
RonZacapa is offline   Reply With Quote
Times are GMT -7.   It's 03:31 AM.
