Old 04-23-2012, 10:00 AM   #41686
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,408
Originally Posted by xj750guy View Post
Hey guys,
As some of you may know, I had decided to do a "Shorai Battery Relocate", as well as many other things over the winter.
Recently, I decided to not relocate the battery, but instead to use the smaller/lighter battery in the stock box, and also add some small storage, and a power outlet.
My problem is that I had drilled out the rivets on the stock fender clip (the one on the airbox), and cannot find the clip anywhere in my garage. Any chance anyone has an extra they might be interested in selling?
Regards,
XJ
if no one has it, and I suspect they won't, http://www.southco.com/browse/dzus-q...ners-7345.html should get you closer.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 04-23-2012, 10:18 AM   #41687
xj750guy
on the Baja 7yr plan
xj750guy's Avatar
Oddometer: 99
Thanks for the link.........Interesting
I'm still searching.....has to be there somewhere.
I still have the DZU's portion, as I had riveted it onto the airbox when I removed the "perch". I might have to get inventive with the metal brake, and try to build the "perch" myself.
Thanks,
XJ
Do not go where the path may lead, go instead where there is no path and leave a trail
xj750guy is offline   Reply With Quote
Old 04-23-2012, 12:32 PM   #41688
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
Barrons engine failure
The main reason Barrons motor failed was he didn't have the oil pumps metal oil line in the oil pump sockets all the way and the line was sticking up to high and the oil pump drive gear rubbed a hole through it..
That explains way the motor went 400 miles and then failed, the gear was rubbing against the line until it rubbed a hole through it and puffffff....... I know it's not funny but all you guys need to make sure the line is seated in the sockets properly and the o-rings are good also so it doesn't happen to you.
I also found the crank seal was pinched and the o-ring was missing between the case and pump.
I have a picture of the hole in the line if someone wants to post a picture for me...
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 04-23-2012, 12:39 PM   #41689
mcma111
mcma111's Avatar
Oddometer: 12,390
Doh...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-23-2012, 12:48 PM   #41690
cyclewizard
Oddometer: 4,814
Originally Posted by mcma111 View Post
Doh...
........poor fellar......
C-dub......
Old 04-23-2012, 12:53 PM   #41691
mcma111
mcma111's Avatar
Oddometer: 12,390
Well at least my worries about over cooling the engine oil with the big fin head has been put to rest.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-23-2012, 12:59 PM   #41692
JT
JT's Avatar
Oddometer: 350
Originally Posted by Johnnyboxer View Post
Less than 150kgs, fully fuelled
Did a 720 mile pure road trip on the XChallenge over Easter and measured 66mpg (UK gallons) over the whole trip and the bike was mainly 70mph and above, most of the time
The motor will smoke most over 600cc+ bikes (bar the 690 Katoom) and will easily see over 100mph+ on the clocks, even on a MT21/D908RR tyre mix
I doubt any of that would be possible on a XR650L.................sadly
Try the mileage math again using US gallons instead of UK gallons. No wonder you claim 20% more mileage. Then you lie about the weight.
"BMW G650XMoto, 363 lbs, Motorcyclist, April 2008
Honda XR650L, 347 lbs, Motorcyclist, Sept. 1992, Nov. 1993" from: http://www.advrider.com/forums/showp...&postcount=104
Why not just stay on the XChallenge thread and tell your lies?
JT is offline   Reply With Quote
Old 04-23-2012, 01:14 PM   #41693
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,408
boobs.
Old 04-23-2012, 01:24 PM   #41694
cyclewizard
Oddometer: 4,814
Same here......
C-dub......
Old 04-23-2012, 01:26 PM   #41695
103M 95G
Oddometer: 29
The front brake pads need to be changed on my XRL,
Brand, and material recomendation please.
Prays this question is not like a "what oil to use"
103M 95G is offline   Reply With Quote
Old 04-23-2012, 01:47 PM   #41696
mcma111
mcma111's Avatar
Oddometer: 12,390
OE or EBC sintered metalic.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-23-2012, 02:12 PM   #41697
Idaho_XR
Idaho_XR's Avatar
Oddometer: 259
I have heard good things about Galfer pads and may try them out soon. They come in three varieties. Black(semi-metallic carbon). Green(kevlar ceramic organic). Gold(sintered HH advanced ceramic compound). I think the black is closest to oem. Maybe someone will chime in who has used these as an option.
http://www.happy-trail.com/Suzuki-Ho...rake-Pads.aspx
Idaho_XR screwed with this post 04-23-2012 at 02:18 PM
Idaho_XR is offline   Reply With Quote
Old 04-23-2012, 03:55 PM   #41698
mcma111
mcma111's Avatar
Oddometer: 12,390
I tried the EBC Carbon/Kevlar whatever the hell they are and I may as well have had a piece of Oak floor board in the caliper. Bought front and rear pads. They are TERRIBLE. Absolutely no feel, don't grab worth a dam. I got a return authorization but they are still on the tool box. I did buy EBC sintered metallic and they are the ones that are closest to OE in my opinion.
EDIT...And this was with a set of BRAND NEW EBC rotors.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-23-2012, 04:00 PM   #41699
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
yup.sintered metal seems to work/last the best.....if you do any offroad wet/mud they are a must,,,,,,,,the other types get eaten in the dirt...
B
techforlife is offline   Reply With Quote
Old 04-23-2012, 06:07 PM   #41700
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,779
Ebay, semi metallic, two sets front and rear, $30-ish, that was my experience with the EBC gee whiz pads too.
katbeanz is offline   Reply With Quote
Times are GMT -7.   It's 11:53 PM.
