Old 04-24-2012, 07:51 AM   #41716
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,128
Originally Posted by cyclewizard View Post
To get the motors potential buy the HSR48, I've done all the testing on my bike at first I tried the stock carb which worked fine but was lacking topend so I went to a FCR41 thinking the stock carb was junk it ran great on the bottom and mid but same problem no top...
So then I tried a HSR42 and gained 14 mph by 1mm larger throat body size so I was on to something..
Tried a HSR45 and then a HSR48 and gained 25mph with the 45mm and 40mph with the 48mm carb and it still needs more carb like a 52mm....
What you can do is bore an FCR41 to a 45mm and it's a bolt on or just get it over and buy a HSR48mm and be done with it.
What affect if any did the larger than 41 have on the bottom. I am running the FCR41 and am very happy with its performance. But I am not looking for more top end speed.
Thanks for all of your work on the L. Amazing!
Mike
When in doubt, give it Gas!
Center Stands, XR650L/XR600, NX650, TE/SM610, TE630, XR400, XR250 and XT225.
http://www.advrider.com/forums/showthread.php?t=537336
http://www.cigarmikes.com/
Cigar Mike is offline   Reply With Quote
Old 04-24-2012, 08:18 AM   #41717
XR650L
XR650L's Avatar
Oddometer: 208
Question Oil Temperature
Hi Gents
I am not sure what the reason is.
I have installed the XR400 oil cooler that Mike has made me with an temperature sensor in the line that comes out the engine going into the cooler. I still have the meat sensor temperature sensor in my Oil tank cap.
My overall temperature has dropped on the Oil tank sensor from 137c or 278F on the same road, almost same conditions to 102c or 215F, now this is great but I am confused with the readings I get on the Oil Cooler line
The sensor goes into a Vapor Instr
When ~I am idling or riding a single track in 1st gear the 2 temperatures come close together, like in 95c or 203F on the meat oil tank sensor and 88c or 190F on the oil line sensor
But if i drive at 100km/h or 62Mph I get a reading of 105c or 221F on the oil tank sensor but the oil line sensor drops to 65c of 149F
Surely the oil out the engine must be hotter than the oil on the tank after the oil cooler?
The sensor sits in the line right in between the exhaust pipes right below the Spark plug
Could it be cooled so much by air, that quickly? out the engine?
Any suggestions here??
Regards
Jaco
Rum is the bad boy of booze. The pirates of the Caribbean weren't drinking vodka. The British navy wasn't run on "amaretto, sodomy and the lash." The smugglers who risked death to bring in illegal alcohol to the thirsty citizens of the U.S. during Prohibition weren't called "spritzer runners."
XR650L is offline   Reply With Quote
Old 04-24-2012, 09:02 AM   #41718
cyclewizard
cyclewizard's Avatar
Oddometer: 4,789
Mike
The 41 FCR is perfect for a 650/675cc motor..after that you need to go bigger..
There were no loss in bottom end on the big block motors is was actualy better.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 04-24-2012, 11:15 AM   #41719
zulusafari
E African ADVRDR
zulusafari's Avatar
Oddometer: 226
Originally Posted by ThumpnRed View Post
How big of a tool tube are you wanting to install? I have seen some pretty good sized units hanging off of the skidplate of XRLs. That's where I have mine... a small one though. I scatter my stuff around on the bike. The few heavy tools and a rag go in the tube. Spare inner tube on the front fender. Lightweight stuff such as JB Weld, tire irons, tire pump and zip ties go in the rear fender bag.
I've been thinking I'd get the agrisupply manual tube. I'd like to be able to find a good way to lock it. I live in a place where it always needs to be secured. I also go on trips that are very far from help. I've considered mounting to the skid plate but worried it would get hit there with some of the riding I do. I definitely plan to lay it down occasionally, so it can't stick out anywhere.
2006 XR650L - Nairobi, Kenya
zulusafari is offline   Reply With Quote
Old 04-24-2012, 01:17 PM   #41720
RZRob
RZRob's Avatar
Oddometer: 694
Big Jugs
So like I'm planning a big adventure on my XR and feel a need to carry an extra gallon of water and an extra gallon of gas stradling on the back behind my saddlebags along with my sleeping bag, cot, bedroll, tent etc. I'm worried about subframe support and just how I'm going to carry these [Anti-freeze size] jugs.
Anyone here have any experience handling large jugs?
RZ Rob
RZRob is offline   Reply With Quote
Old 04-24-2012, 01:35 PM   #41721
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,128
RZ Rob
I think Manracks will have the "Spud Struts" ready pretty soon. If I would have put the right house number on the package he would probably already have a working set to test out.
Cheers,
Mike
Old 04-24-2012, 02:07 PM   #41722
elsalvadorklr
Oddometer: 3,974
damn whos that?
elsalvadorklr is offline   Reply With Quote
Old 04-24-2012, 03:05 PM   #41723
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 6,636
Will HSR48 throttle wheel clear the frame, and use the stock airbox?
katbeanz is offline   Reply With Quote
Old 04-24-2012, 04:11 PM   #41724
beechum1
beechum1's Avatar
Oddometer: 4,931
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Originally Posted by elsalvadorklr View Post
damn whos that?
if you want to know her name, you don't need to know.....
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 04-24-2012, 04:17 PM   #41725
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,801
Cheers,
Mike
Just sitting here waiting Mike
http://www.manracks.com
jungleplant is offline   Reply With Quote
Old 04-24-2012, 04:34 PM   #41726
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,128
I put in the change of address and they should straighten it out. I was lazy and did not put your contact information in. The would have called you when they discovered there was an error.
Cheers,
Mike
Old 04-24-2012, 04:41 PM   #41727
elsalvadorklr
Oddometer: 3,974
i really do, she looks like that blonde from forgetting sarah marshall! jajaja
anyways hijack over
Old 04-24-2012, 05:10 PM   #41728
bp_josh
bp_josh's Avatar
Oddometer: 88
clarke fuel tank
Put the Clarke tank on my bike, noticed that the tank is basically resting against the radiator fins on the side of the frame just below the dipstick hole...do I need to do anything there to keep the tank from melting, or is it fine resting there? There are no mounting instructions and I want to be sure. Also looking closely at the lip where the cap screws on, the plastic is full of tiny bubbles, chips, and defects, basically throughout the entire screw portion of the tank (not the cap). I guess it's not going to affect the tank at all, but you'd think they could mold plastic without leaving defects like that in there.
XRL rider in east San Diego county
bp_josh is offline   Reply With Quote
Old 04-24-2012, 05:22 PM   #41729
kenny61
I'm Going Racing!!!
kenny61's Avatar
Oddometer: 18,868
Radiator???
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Originally Posted by kjclark7 View Post
my thighs are still sore from sunday but it was worth it.
Originally Posted by the kawasaki kid View Post
I'll show you my favorite dirt roads if you show me yours.
kenny61 is online now   Reply With Quote
Old 04-24-2012, 05:37 PM   #41730
purpledrake
No Pretensions
Oddometer: 293
Hey Josh,
Jaco Smith did a nice gallery of his install--you can see it here. https://picasaweb.google.com/1161725...eat=directlink
Your tank should have come with some foam pads; wrap them around the frame, and zip-tie them onto the frame. The tank will fit snugly with the foam, the single bolt, and using either the coat hanger (or homemade cross members) to hold the tank in the front. Your tank should not rest against the fins. (You do still have the Front Fuel Tank Rubbers, right? Part #17611-MG2-000. If so, the Clarke tank should be nice and snug.)
I can't comment about the bubbles, &c. in the plastic moulding. My tank is very well made.
PD
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is online now   Reply With Quote
Times are GMT -7.   It's 07:20 PM.
