Old 04-25-2012, 06:00 AM   #41746
XR650L
XR650L's Avatar
Oddometer: 208
Originally Posted by kenny61 View Post
if your sensor is after the tank and after the oil cooler it should be lower than the tank when air is passing through
Hi
The problem is the sensor is in the line that comes out the engine before it goes into the cooler
Rum is the bad boy of booze. The pirates of the Caribbean weren't drinking vodka. The British navy wasn't run on "amaretto, sodomy and the lash." The smugglers who risked death to bring in illegal alcohol to the thirsty citizens of the U.S. during Prohibition weren't called "spritzer runners."
XR650L is offline   Reply With Quote
Old 04-25-2012, 06:07 AM   #41747
kenny61
I'm Going Racing!!!
kenny61's Avatar
Oddometer: 18,873
Are you sure you are correct in what is in and out? If it is that just dont make sense
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Originally Posted by kjclark7 View Post
my thighs are still sore from sunday but it was worth it.
Originally Posted by the kawasaki kid View Post
I'll show you my favorite dirt roads if you show me yours.
kenny61 is online now   Reply With Quote
Old 04-25-2012, 06:16 AM   #41748
XR650L
XR650L's Avatar
Oddometer: 208
Yes, The sensor is in the long line that comes out the bottom of the engine, it goes up and into the cooler, then out the cooler is a short pipe that goes into the frame just below the filler cap,
As I then see it there is a short line near the bottom of the frame that goes into the engine
There are 2 pipes that go into the engine, the long one and a short one, my understanding is that the short one feeds from the frame tank into the engine
I am as confused here with the temperature readings as can be
Unfortunately I am not close to the bike now, so will get some pictures later
Old 04-25-2012, 08:04 AM   #41749
Brtp4
Yea, its a friggin L
Brtp4's Avatar
Oddometer: 1,765
Originally Posted by purpledrake View Post
Soooo, what is the collective wisdom on this modification (relocating and/or resizing the Regulator/Rectifier)? Especially considering the Shorai Battery Relocation, has this modification taken hold??
I get it that the rectifier changes the 3-phase AC signal into DC (the opposite of an inverter, right?), and the regulator ensures that the proper voltage gets sent to the battery for recharging. By installing a more efficient unit, would that simply reduce the amount of resistance sent to the Reg/Rec unit (thus both reducing heat discharge as well as making make more wattage available for other uses)? What I am wondering is whether a more efficient Reg/Rec would free up some wattage, to power some more heated gear.
I know that somebody is going to pile onto me with a lecture about volts, watts, and amps. I am all ears--please instruct.
PD
Like.
The reason I want to do this is to make room to add XR600R style fuel tank mounts.
BP
BP
Atomic Moto.com
Bend, OR
Brtp4 is offline   Reply With Quote
Old 04-25-2012, 08:17 AM   #41750
selkirkswamper
hellbilly
selkirkswamper's Avatar
Oddometer: 116
new Honda owner
well after 15 years I sold my BMW R100GS PD, it was time for a change, after searching the web and comparing cycles, with the help of the dealer giving me a price I wanted I am now the owner of a 2012 XR650L, I just wanted to introduce myself as I get more into dual sport riding (taking it easy at first). So anyone in the Albany, NY area that could suggest some rides I'd appreciate it.
thanks
selkirkswamper is offline   Reply With Quote
Old 04-25-2012, 08:22 AM   #41751
XR650L
XR650L's Avatar
Oddometer: 208
thanks
Welcome to the XRL, you will enjoy it
Old 04-25-2012, 08:34 AM   #41752
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 1,475
As far as Lex's rewiring the R/R in a more direct fashion, he is not the only one. It is a big mod for Triumph Tiger pre 07s for more watts. I haven't done it to my 06 Tiger because at it last service I had the dealership test it and said it was well within specs. I know electrical parts don't slowly die out, but usually work perfectly until you are in the middle of now where and just go puff. But didn't see the need at the time. It very well may get done on the Tiger and XRL when I electrical skills get better.
"I refuse to tiptoe through life only to arrive safely at death"
2009 Buell XB12X(sold), 2006 Triumph Sprint ST, 2006 Tiger 955i, 01 XR650L replaced by a KLR, and now a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 04-25-2012, 08:47 AM   #41753
kenny61
I'm Going Racing!!!
kenny61's Avatar
Oddometer: 18,873
thanks
make friends here
http://advrider.com/forums/showthread.php?t=672160
here
http://advrider.com/forums/showthread.php?t=752912
and here
http://advrider.com/forums/showthrea...8256&page=1249
we're a quirky bunch but harmless (well most of the time).. You will find plenty of rides and events throughout the year
Old 04-25-2012, 09:01 AM   #41754
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,212
Originally Posted by XR650L View Post
Hi
You might want to compare with Spud's set up and readings
http://www.advrider.com/forums/showt...=781962&page=5
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 04-25-2012, 09:28 AM   #41755
Lonestar2112
Crash test dummy
Lonestar2112's Avatar
Oddometer: 5,229
thanks
Strong suggestion, spend a week and read the entire thread!
Where am I?
"I love the wild spaces above the border, takes some work to get here, ain’t a Starbucks run." jdrocks
F*CK Cancer
Lonestar2112 is online now   Reply With Quote
Old 04-25-2012, 09:32 AM   #41756
XR650L
XR650L's Avatar
Oddometer: 208
Best Advice ever, I am actually going through it again and making a file with links for myself for future reference
Old 04-25-2012, 10:56 AM   #41757
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,413
Sounds like a calibration issue. Put both sensors in boiling water and see what the difference is. They may read claose at a lower temp.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, Google: TX7
fritzcoinc is offline   Reply With Quote
Old 04-25-2012, 10:58 AM   #41758
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,413
WTF happened to the index several of us helped make???
Regards
Fritzcoinc
Old 04-25-2012, 11:03 AM   #41759
XR650L_Dave
Oddometer: 3,163
PD
The alternator always puts out max power (since the L has a permanent magnet alternator), what the bike doesn't need gets dumped by the regulator as heat.
A smaller regulator would just cook itself trying to dissipate the power.
The upside to a permanent magnet alternator is you can bump-start with a dead battery or no battery.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is online now   Reply With Quote
Old 04-25-2012, 01:21 PM   #41760
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 1,834
http://www.advrider.com/forums/showthread.php?t=451212
It died when Raven sold her bike. She was the driver and only one who could edit it. I seem to remember some upset/dispute she got into and then disappeared.
It would be a big help to new folks but a huge undertaking to accomplish.
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon screwed with this post 04-25-2012 at 01:31 PM
Sourjon is offline   Reply With Quote
Times are GMT -7.   It's 10:05 AM.
