Old 04-25-2012, 01:21 PM   #41761
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 1,816
Originally Posted by fritzcoinc View Post
WTF happened to the index several of us helped make???
http://www.advrider.com/forums/showthread.php?t=451212
It died when Raven sold her bike. She was the driver and only one who could edit it. I seem to remember some upset/dispute she got into and then disappeared.
It would be a big help to new folks but a huge undertaking to accomplish.
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon screwed with this post 04-25-2012 at 01:31 PM
Sourjon is offline   Reply With Quote
Old 04-25-2012, 01:31 PM   #41762
malignity
The Hurt Locker
malignity's Avatar
Oddometer: 276
Originally Posted by thatdirtykid View Post
Explanation of what you've done?
Digital oil temperature gauge!
I got a bolt the same size as the stock dipstick screw, drilled a hole through it, and used a high range digital meat thermometer as the dipstick. I used JB Weld to secure it there and threw on an o-ring on the bolt, and poof. I now can tell how hot my bike is running at all times.
2005 KTM 300 EXC - Titled and plated.
gldsmc.org
malignity is offline   Reply With Quote
Old 04-25-2012, 02:15 PM   #41763
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,175
Originally Posted by selkirkswamper View Post
well after 15 years I sold my BMW R100GS PD, it was time for a change, after searching the web and comparing cycles, with the help of the dealer giving me a price I wanted I am now the owner of a 2012 XR650L, I just wanted to introduce myself as I get more into dual sport riding (taking it easy at first). So anyone in the Albany, NY area that could suggest some rides I'd appreciate it.
thanks
Here's a link to a bunch of websites and such that I've collected in modding my XRL
http://ridedualsport.com/forum/index.php?topic=2038.0
2007 Honda XR650L, 2004 Honda XR250R
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 04-25-2012, 02:17 PM   #41764
kenny61
I'm Going Racing!!!
kenny61's Avatar
Oddometer: 18,456
haha I jus googled that up last night
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Originally Posted by kjclark7 View Post
my thighs are still sore from sunday but it was worth it.
Originally Posted by the kawasaki kid View Post
I'll show you my favorite dirt roads if you show me yours.
kenny61 is offline   Reply With Quote
Old 04-25-2012, 02:20 PM   #41765
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,306
Like this too:
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM,
fritzcoinc is offline   Reply With Quote
Old 04-25-2012, 03:24 PM   #41766
RZRob
RZRob's Avatar
Oddometer: 661
I got a bolt the same size as the stock dipstick screw, drilled a hole through it, and used a high range digital meat thermometer as the dipstick. I now can tell how hot my bike is running at all times.
And now you know when your motor is fully cooked too.
RZ Rob
RZRob is online now   Reply With Quote
Old 04-25-2012, 03:57 PM   #41767
KyoXR
KyoXR's Avatar
Oddometer: 407
Originally Posted by purpledrake View Post
Soooo, what is the collective wisdom on this modification (relocating and/or resizing the Regulator/Rectifier)? Especially considering the Shorai Battery Relocation, has this modification taken hold??
I get it that the rectifier changes the 3-phase AC signal into DC (the opposite of an inverter, right?), and the regulator ensures that the proper voltage gets sent to the battery for recharging. By installing a more efficient unit, would that simply reduce the amount of resistance sent to the Reg/Rec unit (thus both reducing heat discharge as well as making make more wattage available for other uses)? What I am wondering is whether a more efficient Reg/Rec would free up some wattage, to power some more heated gear.
I know that somebody is going to pile onto me with a lecture about volts, watts, and amps. I am all ears--please instruct.
PD
there are a few of use who have switched over to a Mosfet R/R, it's supposed to be more efficient and run cooler, one of the reasons I switched to it, I run heated gear and wanted more power,
Originally Posted by XR650L_Dave View Post
The alternator always puts out max power (since the L has a permanent magnet alternator), what the bike doesn't need gets dumped by the regulator as heat.
A smaller regulator would just cook itself trying to dissipate the power.
The upside to a permanent magnet alternator is you can bump-start with a dead battery or no battery.
"A smaller regulator would just cook itself trying to dissipate the power." true but It turns out that the heavier the load, the cooler it runs which makes sense because the power is going to the draw rather then getting turned into heat.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
KyoXR is offline   Reply With Quote
Old 04-25-2012, 05:12 PM   #41768
purpledrake
No Pretensions
Oddometer: 277
Thanks to both of you.
I already run Gerbings heated gloves during the cold months (October to June....), and would like to also power a heated liner. I am close to the bubble on this. I have toyed with changing the headlight assembly to some smaller load aftermarket, to free up some watts. How much extra wattage did the Mosfet R/R provide?
Your point about the higher load going to the extra heated gear is correct only for cold weather rides; unless you load the system with other equipment, the fixed power output from the alternator (186W if memory serves) would indeed fry a smaller R/R. Do I have this right?
PD
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 04-25-2012, 05:34 PM   #41769
malignity
The Hurt Locker
malignity's Avatar
Oddometer: 276
Question
I'm looking for a vehicle to haul my XR long distances. While I could simply ride those distances, for those that are hardcore hare scramblers, driving 300 miles one way to hare scramble for 14 hours, then drive 300 miles back is a lot of wear and tear on a person.
The vehicle I'm looking to get is a work van; in specific, something about the size of a Ford E-350. I'm thinking I may go this route so I can pull my bike out at night and chain it up while I sleep in the back of the van.
Does anyone by chance know if an XR650L will fit in the back of one of these big ass conversion work vans?
gldsmc.org
Old 04-25-2012, 05:44 PM   #41770
ShooterDave
Oddometer: 1,380
I had a 15 passenger Ford Econoline van. The bike just barely fit as long as I took off the mirrors. That was with ATV high bars too, so with lower bars it should fit fine. Its fun getting it in there too being as it has a roof on it. Not a problem though. Although I don't know how the size compares to a Ford E-350.
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350
ShooterDave is offline   Reply With Quote
Old 04-25-2012, 06:01 PM   #41771
Brtp4
Yea, its a friggin L
Brtp4's Avatar
Oddometer: 1,759
Apologize for the remedial questions, as I am not much of an electrics person.
OK, starting to get the basics. Bummer that it is not possible to reduce physical size, it would give me more flexibility in mounting. As I am still finding my way, if anyone has suggestions for how to choose a replacement, specs, etc. that would be great. FWIW it seems Shindengen builds most of the OEM ones.
I did find a good layman's summary here: http://www.superhawkforum.com/forums...why-how-25117/
BP
BP
Atomic Moto.com
Bend, OR
Brtp4 is offline   Reply With Quote
Old 04-25-2012, 06:34 PM   #41772
Brtp4
Brtp4's Avatar
Oddometer: 1,759
BP
Good info:
http://www.triumphrat.net/speed-trip...r-upgrade.html
This gentleman seems to be a great resource:
http://www.roadstercycle.com/Easy%20...%20Install.htm
BP
BP
Atomic Moto.com
Bend, OR
Old 04-25-2012, 06:43 PM   #41773
truck6driver
The Fireman
truck6driver's Avatar
Oddometer: 5,796
Yes it will. and as stated without the mirrors so it will clear the rear door roof line.
Or you can load it like this:
http://www.youtube.com/watch?v=lYeu5...yer_detailpage
truck6driver screwed with this post 04-25-2012 at 07:29 PM
truck6driver is offline   Reply With Quote
Old 04-25-2012, 06:46 PM   #41774
malignity
The Hurt Locker
malignity's Avatar
Oddometer: 276
Or there is this:
Sweet. thanks. I don't have the tall stalk mirrors.
gldsmc.org
Old 04-25-2012, 06:50 PM   #41775
XR650L_Dave
Oddometer: 3,076
Heh, just don't turn anything off.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Times are GMT -7.   It's 10:56 PM.
