04-25-2012, 06:52 PM
#41776 |
Oddometer: 1,380
Especially with the stock bars. Ya you will be fine. Or you could just unload it like this from a truck:
http://www.youtube.com/watch?NR=1&fe...&v=Mnvm5HTprCg ![]() ![]()
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350 |
04-25-2012, 06:59 PM
#41777 | |
Mad Scientist
Oddometer: 3,156
I'll post an illustrated write-up soon.
04-25-2012, 07:09 PM
#41778 |
pistolero
Oddometer: 1,174
Is that mirror from Highway Dirt Bikes?
84 Honda Goldwing (GL1200) 03 XR650L |
04-25-2012, 07:20 PM
#41779 | |
Oddometer: 404
As far as how much extra wattage the Mosfet provides...I'm not really sure mainly because I put in a 300W stator in at the same time, so I had to up-grade the R/R. I think that Jack Fleming at Roadstercycle has a page that explains his findings?
2007 XR650L, Looking to acquire a stock XRL choke plunger. |
04-25-2012, 07:30 PM
#41780 | |
Oddometer: 130
![]() Sent from my LG-P999 using Tapatalk 2 |
04-25-2012, 08:38 PM
#41781 |
Mad Scientist
Oddometer: 3,156
A Little Help?
I lost my Metric thread pitch gauge. What is the thread pitch of the brake lever-to-handlebar / turn signal mount-to-handlebar / throttle assembly-to-handlebar screws? I'm replacing mine with stainless and don't know exactly what to ask for online. M6- ? x20 It looks finer than 1.0.
0.75 perhaps? Thanks Stretch67 screwed with this post 04-25-2012 at 08:58 PM |
04-25-2012, 09:01 PM
#41782 | |
frozen dead guy
Oddometer: 619
I like the FH012AA reg/rect. It runs nice and cool and puts out a very steady voltage (14.7v if I remember correctly). It is a little larger and will not mount in the same location. I put mine above the airbox under the seat. I would only recommend switching to the FH012AA if you: a) upgraded your stator and/or b) have a variable electrical load (such as the ability to turn off the lights, which would make a shunt type regulator run hotter) Otherwise, as long as the reg/rect is sized correctly for the bike's electrical system, why bother? If you just want to relocate the stock unit, I think you can do that without cutting any wire. If you're trying to squeeze some more juice out, then going to thicker wires from the stator all the way to the battery, or shortening them up will probably help a bit. The Shorai batteries are simply awesome- if you're in need of a battery replacement you can't go wrong with one of them. |
04-25-2012, 09:23 PM
#41783 | |
No Pretensions
Oddometer: 275
Thanks for the notes. My real issue is to squeeze more wattage out of the system, to power heated gear. IF I had more capacity after that, I might add a 12V adapter plug (for cell phone and/or GPS charger), but that would really be on the long term fantasy list. And, in addition, I do want to dump the steel cage stock headlight assembly (to lighten up, and to get more lumens). I don't need to change the Reg/Rec for the relocation effect (the stock unit fits just fine under the Clarke 4.7-gallon unit). My older XL250's used to have On/Off switches for the headlights, but the constant ON suits me just fine. At the end of the day, maybe I don't need to swap out the Reg/Rec??? Spud, where are you with advice when we need you?? PD
The Good Lord gave most of us 10 digits; mine are all thumbs. |
04-25-2012, 10:22 PM
#41784 | |
frozen dead guy
Oddometer: 619
People do power heated gear with the stock electrics... maybe not a whole lot at once but you can do it. If you want more you can upgrade the stator to a larger Honda unit (and reg/rect also). If you want a really slick power outlet, check out HighwayDirtbikes. flyingwombat screwed with this post 04-25-2012 at 10:32 PM Reason: I felt like it |
04-25-2012, 11:14 PM
#41785 |
Oddometer: 162
Well, it is finally done. Got my USD swap finished. I had to change the fork seals, and oil today, but I got it buttoned back up and went for a ride to my buddies, to help him decide between a DR650 or KLR650 (he's to short to even get on my XR)
![]() Last thing to do is install the Vapor w/dash, and I will be set. I also have a set of pivotpegz to put on. The forks and wheel are from a CRF250R. Got them and the Corbin from Therealbigman, thanks again Marko . I went with a set of RSW triple clamps, which made this a pretty easy swap.Here are some pics: ![]() ![]()
04-25-2012, 11:36 PM
#41786 |
I'm Going Racing!!!
Oddometer: 18,425
Ive seen pink bikes before, but man even your equipment? Thats awesome
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died. |
04-26-2012, 12:08 AM
#41787 |
Oddometer: 162
Man, I had to go look at the bike just make sure it didn't get spray bombed by my wife
!It is definitely red. That is why I am not a photographer. Thanks for pointing that out Kenny!
04-26-2012, 12:12 AM
#41788 | ||
Oddometer: 2,940
However, I like this pink motorcycle better. ![]() ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
04-26-2012, 12:43 AM
#41789 |
Oddometer: 162
Thanks Spud!
I would have to agree, that is one of the best looking Katoom Adventures I have seen. |
04-26-2012, 03:23 AM
#41790 |
Oddometer: 3,066
It's not awesome, its..... FAAAAAAABULOUUUUUUUUUUS!!!
---->>Thanks for the rotor, guys!<<---- |
