Old 04-26-2012, 05:35 AM   #41791
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,128
Originally Posted by cypert2 View Post
Have 2008 XRL that I haven't started in about a year. Started it yesterday[took a while] and it would run at idle but if you gave it any gas it would die. Any ideas what may be the problem.
The most likly cause is a plugged up carb.
Drain the tank and drain the carb with the screw on the bottom side of the float bowl. You need to lay the bike over on it's clutch side to get all the fuel out of the tank. Put a 1/2 gal of fresh fuel in and try again. The proper amount of Techron fuel system cleaner mixed in with the fresh fuel could work. Worth a try before you tear into it. The slide may be stuck from sitting so long as well. Pull back the air cleaner boot and spray it down with some light oil like RemOil.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 04-26-2012, 06:09 AM   #41792
3girlsdad
aka FiddyK
3girlsdad's Avatar
Oddometer: 387
your motor is bad. bike is shot. not worth a hundred bucks now. i'll be over in a bit to pick it up.
2008 Honda CRF450X - plated
2007 KTM 450 XCW - a little sip of the kool-aid (gone)
2011 Beta 450 RR - plated (gone. had my sexy italian fling)
2008 Honda XR650L - (gone)
3girlsdad is offline   Reply With Quote
Old 04-26-2012, 08:24 AM   #41793
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,700
Originally Posted by fritzcoinc View Post
The parts manual gives all fastener sizes.
5 x .8
Thanks, Brother.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 04-26-2012, 08:57 AM   #41794
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by malignity View Post
Sweet. thanks. I don't have the tall stalk mirrors.
Where did you get those mirrors from? I have been trying to buy a pair similar to those from Highway Dirt Bikes, but they wont sell them seperatly .
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 04-26-2012, 09:51 AM   #41795
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
Cumbacheech
Dude, how about this:
Go to your local autoparts store and get one of these
Then cut a piece of metal just big enough to stick one of the things to and run a bolt through, then spray it black stick on the mirror and bend the metal to where you want it.
Second thought, you might want to put two attachment points on the metal piece to keep it from rotating down from the vibrations or if it gets a little loose.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 04-26-2012, 10:17 AM   #41796
malignity
The Hurt Locker
Oddometer: 409
Originally Posted by JWhitmore44 View Post
Is that mirror from Highway Dirt Bikes?
Nope. HDB inspired. Made by me. :)
I used .90 thick Kydex, cut to shape, then put on blind spot mirrors on the Kydex. Shaved off the lip of the windguard so the Kydex would have something to recess into. I drilled holes through both the Kydex and the wind guard, put a rubber washer on there to cut down on vibration some, and tightened it with a white nylon wingnut. Tucks right into my hand guard when I'm on the trails.
'10 Yamaha WR250R , '93 Yamaha TW200, '03 Honda Foreman 450ES 4x4, '96 Yamaha Big Bear 350 4x4. www.gldsmc.org
malignity screwed with this post 04-26-2012 at 10:22 AM
malignity is offline   Reply With Quote
Old 04-26-2012, 10:22 AM   #41797
malignity
The Hurt Locker
Oddometer: 409
-Barron
This is essentially what I did. Also, cut the lip off in the wind guard so that when you rotate the Kydex, it snaps into place. This will keep it from rotating. It'll also fold under the lip if you want them folded down.
Also, get ADJUSTABLE ONES! The 360 degree kind.
You can order Kydex at knifekits.com
HDB makes good stuff, but no offense, if they don't want to sell crap individually and want to lose business cause of it, 'eff em. I'll make it my damn self.
Here's them folded down as well as the other side... oh, and do you see my Honda White nylon wing nuts? LOL
Old 04-26-2012, 10:29 AM   #41798
Dr.Z
6Sigma Knuckle Shflr
Dr.Z's Avatar
Oddometer: 10,423
Easy mirrors to bolt on to your handguards...
https://www.denniskirk.com/powermadd...prd/392537.sku
They work well on my XRR and they're cheap.
Stay half-assed, my friends. -- Mike West
He's got some of the basics down, but, in the end, that just has to create a bigger clusterfuck in that chinese fire drill of a cognitive thought he brought to the dog and pony show of his new found awareness. - Jack Goff
Dr.Z is offline   Reply With Quote
Old 04-26-2012, 10:30 AM   #41799
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
...HDB makes good stuff, but no offense, if they don't want to sell crap individually and want to lose business cause of it, 'eff em. I'll make it my damn self...
That's ingenious. You did a nice job, Mal.
Spud
Old 04-26-2012, 10:59 AM   #41800
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
Are they visable when riding? I ran a set of Acerbis mirrors on a previous bike and they vibrated so badly you couldn't see chit in them.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 04-26-2012, 11:06 AM   #41801
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,623
I just got some kydex the other day or making a couple sheathes. I just had a Duh moment
Thanks for the info
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 04-26-2012, 11:07 AM   #41802
JWhitmore44
pistolero
Oddometer: 1,623
nice find.
03 XR650L
Old 04-26-2012, 11:25 AM   #41803
mrazekan
mrazekan's Avatar
Oddometer: 1,357
Originally Posted by elsalvadorklr View Post
racetechs calculator is bonkers, it said I need 52 and I weigh with gear 170lbs...maybe its because their springs are rated differently but the last thing I would do is spring stiffer...
Springs are rated in load per distance. It would not make sense to rate springs in a different manner.
Originally Posted by Memnok View Post
The front forks are from a 2004 CRF250r and have been re-sprung for the heavier motorcycle. The rear shock was removed and sent to Race Tech where they installed a Gold Valve. I am running the stock spring on the rear. I weigh about 185 lbs with the gear you see in the photo.
The jump is not all that high, it is really just a berm meant to make a turn after the table top. Here is a photo of the berm I am jumping with me son in the background, and my nephew in the foreground. Basically, I am landing the table top, slamming on the brakes, then jumping this berm instead of making the turn.
[IMG]I am no expert, but I talked with a lot of suspension people before working on mine. My understanding is that the spring only supports the weight of the rider and motorcycle. Putting a heavier spring will not really prevent you from bottoming out, and will make your ride harsh, as you have described. What is really doing all the work in your suspension is the oil, which is moving from one side of the shim stack to the other. If you are bottoming out, your suspension is allowing the oil to move too freely, and the shim stack needs to be adjusted.
A heavier spring may prevent you from bottoming out. All other things being equal, a heavier spring will provide a higher restorative force for the same amount of compression observed.
I need to get back to repairing my two XRLs.
West/Wet, what the fuckx. Just different waypoints on the GPS for the same juvinile behaviors! -- Hells Alien
mrazekan is offline   Reply With Quote
Old 04-26-2012, 11:46 AM   #41804
malignity
The Hurt Locker
Oddometer: 409
They do vibrate some, but I put the rubber washer in there to help. They work as good as a blind spot mirror should, but I noticed at 70mph on pavement, the wind they catch causes the mirror to start to fold down a tad from wind resistance. I have to kinda squat down a bit to look out of them. They do vibrate more at that speed a bit too, but I'm also running brand new Kenda 760's on pavement -- EVERYTHING vibrates. Lol.
All in all, I only spent $15 or so to make them. I think they look badass, work well for what they are, are convenient and fold down when I need them out of the way. It's one of the better $15 investments I've made. I love them. Way better than the stalk mirrors on single track and have the badass look. I don't mind glancing over my shoulder from time to time.
Old 04-26-2012, 12:36 PM   #41805
Olderslowerguy
Olderslowerguy's Avatar
Oddometer: 425
Just popped up on Ebay!
http://www.ebay.com/itm/05-HONDA-XR6...7&vxp=mtr#shId
OSG
Clearwater, Fl.
Olderslowerguy is offline   Reply With Quote
Times are GMT -7.   It's 10:36 AM.
