Old 04-30-2012, 03:09 PM   #41926
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,744
Originally Posted by mcma111 View Post
Disconnecting the cables has been the ONLY way I could get the throttle assembled correctly. Otherwise it's hand to hand combat with one arm tied to your back.
That's the way it felt... "How the Fudge am I suppose to juggle all these parts while spoonin' it back together!"
Originally Posted by oremike View Post
West, I didn't see this until now but they are correct that the push cable needs more slack than the pull. If you're having trouble I can help after 2pm tomorrow.
I'm going to pull the tank and try again tonight.... if you see a giant fireball rise above Spencers Butte, you'll know I pushed it outside and dropped a road flare in the tank out of frustration!
West - "Oeste Sanchez"
RideAbout is online now   Reply With Quote
Old 04-30-2012, 03:29 PM   #41927
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Originally Posted by 1Bonehead View Post
OK-
tell me about the front light and fender?
Where did you get your tank decals? Did they stay on the plastic ok? Thanks.
2012 Honda XR650L Adventure Bike
Honda XR Fan for 30+ years!!!!!
Rider11x is offline   Reply With Quote
Old 04-30-2012, 04:56 PM   #41928
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Originally Posted by rzrob View Post
Hi Folks,
I really need the help of you seasoned XRL Xperts.
I'd like to power my GPS and my Cellphone Charger and before I start digging, thought I'd check with you guys first.
Do you think an iPhone 3GS charger and a Garmin Zumo draw a notable amount worth being concerned?
Do you think I can still power any heavy hitters such as a TourMaster Heated Vest?
Is there a convenient "switched power" source near the headlight I can easily tap?
Would also like an "Unswitched" source near the headlight for things like the vest, or a Battery Tender. Should I just go straight to the battery or is there already a beefy wire up near the headlight?
How about a reliable ground source?
Thanks in advance.
RZ Rob
Alternator output is 188W
The headlight is 55W low, 60W high.
Taillight is 8.3W, brake light is 26.9W.
Turn signals are 26.9 watt each.
Instrument light is 3.4W.
High beam indicator is 1.7W
I run everything back to the battery and fuse it. My tender connection is directly off the battery out the back of the box. Short heavy wires that can be used in a pinch to charge from another bike. I run a GPS and heated gloves with no problem. GPS isn't switched because I like to fiddle with it while I'm stopped. Gloves aren't switched because they disconnect as I get off the bike. I'm guessing the vest will pull 50-70 watts which will get you near the limit at speed. My guess at idle you will be draining the battery.
Get a battery monitor or voltmeter for the bike. If you run a lot of electrical crap it will save you. I've had this one on several bikes over the last 5 years with zero problems.
http://www.motorcycle-superstore.com...ery-Gauge.aspx
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 04-30-2012, 05:12 PM   #41929
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
Put the ole girl on a Shorai diet. I wonder if TSA will let me on a plane with the suitcase... my old Samsonite is getting tired.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 04-30-2012, 05:20 PM   #41930
Spud Rider
Spud Rider's Avatar
Oddometer: 3,801
Your beautiful bike looks even better with the "battery goiter" removed, Red!
Spud
Old 04-30-2012, 05:30 PM   #41931
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Looks good ThumpnRed!! I did the battery rellocation and I really like it. Haven't had a chance to take the bike out for a good ride yet... Did you do the zip ties for the CDI in the air box?
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 04-30-2012, 05:41 PM   #41932
Cumbacheech
XRated
Oddometer: 823
Dave's mod finally done
Hi Everyone,
So I finally finished doing the Dave's Mod... I drilled out the 2 5/32 holes on the bottom of the slide and put in new jets... I ended up using the 58/160. I took the bike out for a Rip and I was very nice!! Bike feels a lot more responsive. I haven't taken the bike for a good ride but based on the short ride the bike feels amazing!
Thanks to everyone who helped me out, Much appreciatedNow hopefully I can free up some time and head out for a nice long ride...
Cheers,
Cumbacheech
Old 04-30-2012, 05:50 PM   #41933
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,330
Some spiffy looking RED......plan on getting it dirty,or just gonna be a grage queen...
P.S. you got the CW adjusters upside down,,smatern up...
B
techforlife is offline   Reply With Quote
Old 04-30-2012, 06:24 PM   #41934
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
B
I had them flipped around the other way and they didn't look right... sticking straight up. My chain's too short...
Old 04-30-2012, 06:25 PM   #41935
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
Cheers,
Cumbacheech
Yep... CDI is in the airbox... ala Spud
Old 04-30-2012, 06:26 PM   #41936
chasbo
chasbo's Avatar
Oddometer: 1,676
Nice bike! What forks are those? Do they use the stock triples?
You can outdistance that which is running after you,
but not what is running inside of you
chasbo is online now   Reply With Quote
Old 04-30-2012, 06:42 PM   #41937
Spud Rider
Spud Rider's Avatar
Oddometer: 3,801
That's the best place for the CDI unit, Red. The CDI takes much less of a beating while resting in the middle of the bike. The air box offers good protection for the CDI unit, and the air flowing into the engine cools the CDI unit.
Spud
Old 04-30-2012, 07:10 PM   #41938
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,484
B
I put them on that way on my bike on purpose. When tightening up the axle they stay against the notch much better. the Yamaha's I have come that way.
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 04-30-2012, 07:29 PM   #41939
chipbl
chipbl's Avatar
Oddometer: 288
Spud
Spud, you're tempting me... ~6K on a stock battery, what should I expect from it before I have to make this decision? Cycle Racks combined with Wolfman side racks makes the left side cover impossible to remove (at least for me). With the hump gone I bet I could get the XRR cover off. Any thoughts?
2008 XR650L, tons of goodies.
chipbl is offline   Reply With Quote
Old 04-30-2012, 07:41 PM   #41940
Spud Rider
Spud Rider's Avatar
Oddometer: 3,801
The stock battery will last a long time, Chip. I bought my Shorai battery even though my stock battery was still good, and I'm glad I made the purchase.
Of course, the aftermarket side racks are designed for the stock bike, with the battery box installed. However, if one fabricates his own side racks, I don't doubt the XRR side cover will be easier to remove, and the load will be more centralized on the bike. However, one still needs to beef up the bike's subframe before he thinks about carrying significant loads back there.
Spud
Times are GMT -7.   It's 10:23 PM.
