05-26-2012, 10:51 PM
#42691 | |
Oddometer: 1,083
05-27-2012, 05:08 AM
#42692 |
Oddometer: 92
CDI - I don't know what is wrong with it
Hi All
My XRL wouldn't start. I checked everything and in the end I put a used CDI instead of mine (which is 2 years old) The bike started imidiatly I opened the CDI but I see nothing wrong ![]() ![]() ![]() Any hints ? |
05-27-2012, 05:38 AM
#42693 | |
M0DAH0LIC
Oddometer: 1,943
-Barron
1996 XR650L with a couple mods If everyone brewed beer there would be no war. ![]()
05-27-2012, 05:48 AM
#42694 |
Oddometer: 92
Thanks a lot - Barron.
I took magnifing glass and found no cracks in the soldier on the contacts. I will take it to work, to the electronic lab. Do you think that Techforlife will agree to take a look at it, and maybe to fix it ? |
05-27-2012, 05:53 AM
#42695 | |
M0DAH0LIC
Oddometer: 1,943
-Barron
05-27-2012, 06:22 AM
#42696 | |
CDI REPAIR
Oddometer: 3,312
There is a chance that the CDI is garbage....and resoldering will not help...out of about 50 CDI`s if had sent to me........3 were not repairable.. B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
05-27-2012, 06:44 AM
#42697 |
Oddometer: 92
Wow.
This was fast. Thanks a lot. I will try to ask at work if they see something, and if they can't help I will PM you. Thanks a lot, again, and have great day. |
05-27-2012, 06:45 AM
#42698 |
CDI REPAIR
Oddometer: 3,312
Failure points
Here`s the MAJOR failure points........there can be others,,but these are the ones to really look at carefully...
The blue spots are the worst by far.. The red are the next worst spots The yellow spots are the next ones to look at.. Like i said these are the most common......but a really good magnifier is need to find them all.....i just remove all the solder now and do the whole board...... ![]() Here`s my repair thread at TT... http://www.thumpertalk.com/topic/881...lp-cdi-repair/ B
05-27-2012, 07:02 AM
#42699 |
Oddometer: 92
Great
(Actually, I got the idea to open the CDI from your post at TT, which I found while looking at the index of this thread :)) |
05-27-2012, 07:04 AM
#42700 |
Oddometer: 92
BTW: I saw in your signature that you have FMX650 fifth gear.
Why is that ? (The NX second gear I know why) |
05-27-2012, 07:06 AM
#42701 |
Oddometer: 7,981
He is trying to achive trans warp speed. Space, the final frontier...
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
05-27-2012, 07:07 AM
#42702 |
Wisconsin Dual Sporter
Oddometer: 503
Jetting
Maybe Mendo or CW or someone else could weigh in on my question. I rebuilt my engine last year with a JE 102mm piston and since then I have increased my main jet up to a 170 trying to eliminate the slight ping I get on the highway at 55-60 mph. Stock gearing and Daves mods done to the carb. The pinging occurs under a slight load like a heavy head wind or a slight uphill.
I have not checked the plug yet, but I tried a 160, 165, and then the 170 main with a slight improvement I think. I believe what Mendo was experiencing was a ping at lesser throttle than what I am hearing at the upper range around 3/4 to WOT.
1994 XR650L farkled 1985 XL600R (sold!) 1985 XR600R tagged 1983 XL100S 1985 ATC250ES mrfixit54016 screwed with this post 05-27-2012 at 07:19 AM |
05-27-2012, 07:17 AM
#42703 | |
Oddometer: 4,790
What's your cam specs? Jetting won't eliminate the ping ping by its self.
C-dub...... Powered by CW-Pistons/cams Wizard manufacturing.... |
05-27-2012, 07:20 AM
#42704 | |
Oddometer: 4,790
#42705 |
Oddometer: 503
Stock cam CW.
1994 XR650L farkled 1985 XL600R (sold!) 1985 XR600R tagged 1983 XL100S 1985 ATC250ES |
