Old 06-03-2012, 10:21 AM   #43066
mcma111
mcma111's Avatar
Oddometer: 12,097
Originally Posted by katbeanz View Post
Cut 1/2" off a swiss army knife toothpick, worked like a champ.
When there is a will, there is a way.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-03-2012, 10:41 AM   #43067
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,715
Originally Posted by flyingwombat View Post
I hope you're talking about an XR250L and not an XR650L...
No 650l. If it was for single track it would be too big. As its for commuting and gravel road running the docile 650 with a touch higher gearing than I would prefer makes it quite mild. She's quite capable of handling it.
v8toilet is offline   Reply With Quote
Old 06-03-2012, 12:30 PM   #43068
prince_ruben
prince_ruben's Avatar
Oddometer: 1,726
Clark 4.8 gallon tank install with XR's Big Fins
Some i"m having some clearance issues with my install of the Clark 4.7 gallon tank with the XR's Big Fins. I've already bent the clutch bracket so the choke cable cleared the extra width of the Big Fins.
When I placed the tank on the frame, the clutch cable rubs against the head and binds under the tank.
What do you guys think about the fit? Should I install some foam to raise the tank? Do I need to order a longer clutch cable?
No worries in death, no worries in life.
prince_ruben screwed with this post 06-03-2012 at 06:30 PM
prince_ruben is offline   Reply With Quote
Old 06-03-2012, 01:01 PM   #43069
mcma111
mcma111's Avatar
Oddometer: 12,097
Originally Posted by prince_ruben View Post
Some i"m having some clearance issues with my install of the Clark 4.7 gallon tank with the XR's Big Fins. I've already bent the choke bracket so the choke cable cleared the extra width of the Big Fins.
When I placed the tank on the frame, the choke cable rubs against the head and binds under the tank.
What do you guys think about the fit? Should I install some foam to raise the tank? Do I need to order a longer chock cable?
I believe that is your CLUTCH cable.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-03-2012, 01:05 PM   #43070
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,316
This.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 06-03-2012, 01:46 PM   #43071
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,538
I would install the supports from the frame to the tank to get the tank spread back out, throw in some more foam under the tank and then see how your CLUTCH cable looks.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 06-03-2012, 01:55 PM   #43072
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,256
The XR600R CLUTCH cable is about 2 inches longer. It is What I use on my XR's big fin head and Acerbis tank.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 06-03-2012, 02:09 PM   #43073
zulusafari
E African ADVRDR
zulusafari's Avatar
Oddometer: 297
Anyone know where I can get good info on best operating oil temps?
Steve?
2006 XR650L - Nairobi, Kenya
zulusafari is offline   Reply With Quote
Old 06-03-2012, 02:21 PM   #43074
RZRob
RZRob's Avatar
Oddometer: 1,579
Steve?
I posted the link on your original request, but about 250 is kosher.
RZ Rob
RZRob is offline   Reply With Quote
Old 06-03-2012, 02:22 PM   #43075
mendoteach
mendoteach's Avatar
Oddometer: 1,578
I just ordered a 3" longer cable from Motion Pro as I had this exact same problem with my IMS tank and big fins. The 3" is a stock Motion Pro cable. Initially, CW told me to get a 4", but I mentioned Motion Pro stocks a 3"er. He said 3" would work fine as I don't have any risers or tall bars. It is perfect. That said, Motion Pro will make you anything you want. Here's the link:
http://www.motionpro.com/motorcycle/partno/02-0223/
mendoteach is offline   Reply With Quote
Old 06-03-2012, 03:39 PM   #43076
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,389
I got my OEM cable to work just fine, had to play with the routing a little bit, but it worked out. I had to get "liberal" with adjustment of the cable bracket that attaches to the starter as well to make the cable go directly into the center of the housing to avoid rubbing and such.
What's really gonna piss you off is that when you put the fuel valve back on the tank it won't fit with the big fins. Ask me how I know....
What I did was cut the corner out of one of the fins and it fits fine now. If you want pics let me know.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 06-03-2012, 04:01 PM   #43077
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
-Barron
I'm sorry I forgot what tank you had when I did the big fin head for you.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 06-03-2012, 04:47 PM   #43078
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,389
Absolutely, positively no problem at all. It was an easy fix.
Old 06-03-2012, 05:06 PM   #43079
MuscleGarunt
Oddometer: 107
Botom end racket at 4000 to 5000 rpm
Hi, what is this racket I hear now that I have a skid plate. I've been reading about counter balance gear noise from spur cut gears with excessive lash? The bike has 4500 miles and runs great but makes this racket kind of sounds hollow like clacking 2 spoons together in a carbboard box. Idle all I hear is valves ticking and normal idle sounds. Sounds great, valves are in perfect spec. I also hear this noise while engine braking in 2nd or 3rd gear mostly second probable cause I am going slower and there is less road/trail noise.
I've got the FCR
skidplate
IMS tank
Shorai battery reloaction
RSW triple clamp
Tusk hi bars
14/48 gearing going to try 14/50 when I wear this set out.
Uni filter
XR600 side plastics
XR600 rear fender
XR400 front fender
Kenda Trakmasters going to try Dunlop 606 next time.
XRs only chain guide and case guard
XRs only temp dipstick
FMF HI-Flo header and Q4 pipe
I get 38 MPG and weigh 230 sound about right?
That's about it, got an XR400 oil cooler getting rigged up right now, can't think of anything else to do to it now. Think I've done it all.
Any input on my bottom end noise would be great. Is it common? It's not that loud but you can hear it come on about 40 in 3rd gear. It gets more random if you rev it but it's still there.
MuscleGarunt is offline   Reply With Quote
Old 06-03-2012, 05:51 PM   #43080
Huskylove
Oddometer: 54
Brian,
Get in line bubba
Where do I sign up?
96 Xr600r, 644cc 10.5:1 Je, megacycle cam/rockers, fcr41 sudco, custom exhaust and a set of 17's <motor and frame for sale PM me
Huskylove is offline   Reply With Quote
Times are GMT -7.   It's 02:16 AM.
