Old 06-19-2012, 08:54 PM   #43666
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
It works!
hotstart cable in the choke hole
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed screwed with this post 06-19-2012 at 09:42 PM
ThumpnRed is offline   Reply With Quote
Old 06-19-2012, 09:23 PM   #43667
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,169
Originally Posted by JWhitmore44 View Post
The XR4 is an awesome trail machine, I miss mine from time to time. I had an 05 WR450 for awhile and the only thing it did better was the electric start :) There was nothing wrong with the WR, but I thought the XR just handled the tighter stuff better.
Yeah, I'm looking forward to it. My old XL250 is kick-start... the 400 may be a bit stiffer, but I'm in pretty good shape.
Stretch67 is online now   Reply With Quote
Old 06-19-2012, 10:43 PM   #43668
EpHu
XRL-Rider
EpHu's Avatar
Oddometer: 52
Send a message via ICQ to EpHu
Originally Posted by ThumpnRed View Post
It works!
what are the settings
the level of fuel
jets?
2006 XR650LMy favorite motorcycle!
EpHu is offline   Reply With Quote
Old 06-20-2012, 01:16 AM   #43669
KyoXR
KyoXR's Avatar
Oddometer: 411
It works!
details please...
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
KyoXR is online now   Reply With Quote
Old 06-20-2012, 05:13 AM   #43670
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,312
Originally Posted by tjrockit View Post
Hello gents,
I am debating removing the tank decal and putting something else on it. Any ideas on how best to remove the OEM decal? I was thinking about a heat gun then wondered if it would cause the gas fumes to explode.
Thoughts?
Try the stuff on the right.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM,
fritzcoinc is offline   Reply With Quote
Old 06-20-2012, 06:07 AM   #43671
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
Originally Posted by KyoXR View Post
details please...
The stock XRL choke cable exits the carb straight which would make it stick out way too far if you used it on a FCR (plungers are the same though). The hotstart cable from a CRF250 or CRF450 come out of the carb and do a 90 degree bend. The plungers (on my FCR) for the hotstart and choke are the same diameter, but one is a tad bit longer than the other.... but they seem to be interchangeable (I have swapped them around with no ill effects). So... I eBayed a CRF450 hotstart cable and screwed it into the choke port on the FCR and connected the other end to the stock choke lever on the bars. I now have a bar mounted choke for the FCR.
I have tried the "give it a squirt" and hit the starter method and it doesn't always work great when the bike's cold. I get better results using the choke (keeps the idle up also). This makes the morning drill much easier.
Old 06-20-2012, 06:12 AM   #43672
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
the level of fuel
jets?
NJGR needle (clip in top slot)
Main: 165
Pilot: 42
A TT member uses the following with good results (actually a better solution than mine as this needle is a straight taper so it has no "bumps" in fuel delivery)
Needle: NCVT (Second from the top)
Main: 158
Pilot: 40
Old 06-20-2012, 06:15 AM   #43673
xj750guy
on the Baja 7yr plan
xj750guy's Avatar
Oddometer: 97
THANK YOU EVERYONE!!!!
Thanks all for the vids, and hints on changing Tube Tires.
Went out last night with 3 tire spoons, baby powder, soap and water, and a better attitude.....
No problems........MT21 Front D952 Rear........Mountains here I come.
Do not go where the path may lead, go instead where there is no path and leave a trail
xj750guy is offline   Reply With Quote
Old 06-20-2012, 06:23 AM   #43674
elsalvadorklr
Oddometer: 3,963
awesome dude! pics and ride reports on the tires is all we ask in return! jajaja
ride safe
elsalvadorklr is offline   Reply With Quote
Old 06-20-2012, 06:36 AM   #43675
xj750guy
xj750guy's Avatar
Oddometer: 97
Yeah....it does look good......and will definitely "get me there" now........but.......pics will have to wait
.....at least XR pics
I leave first thing tomorrow morning on a 5 day sportbike trip through some of the best twisties Montana, Idaho, Oregon, and a smidge of Washington have to offer.
I just bought a new Canon S100, so I might try my hand at a "Mini" ride report (but on road).
Regards
Darryl
Old 06-20-2012, 07:23 AM   #43676
XR650L_Dave
Oddometer: 3,092
Now do a 140-series MT-21 or a terrorflex, just remember to wipe the blood of the keyboard when you're done!
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 06-20-2012, 07:35 AM   #43677
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
It works!
Hold the presses! The ride to work this morning revealed that more work needs to be done. The bike starts great, but doesn't seem to carberate quite right once it gets up to temperature. The choke is not closing all the way. I have to see if I can adjust the cable enough to get it right. It might be the plunger length. More to follow.
Old 06-20-2012, 07:38 AM   #43678
xj750guy
xj750guy's Avatar
Oddometer: 97
I'm sure that would be very true........
Old 06-20-2012, 09:08 AM   #43679
ShooterDave
Oddometer: 1,380
Good thing it wasn't a MT21 REAR. Those things are a BITCH. Both times I've run one in the rear I've had to run over it with my truck in order to break the bead. Not a good thing if you get a flat out in the middle of nowhere. Never running a MT21 rear again.
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350
ShooterDave is offline   Reply With Quote
Old 06-20-2012, 09:34 AM   #43680
xj750guy
xj750guy's Avatar
Oddometer: 97
I'm sure you're right, but have trouble thinking that the MT21 could be much stiffer than that D952......wow!
Truth be known, the bead breaking and removal was the easy part. The issue I had was getting the opposite side bead to stay "down in the rim" as I was installing the new rubber. The big fresh lugs on the 952 sure can cut up knees! I need to try a Bead Buddy
Times are GMT -7.   It's 02:40 PM.
