Old 06-24-2012, 09:29 AM   #43756
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 812
Originally Posted by mcma111 View Post
If you notice the 11:25 CR pistons take a different ring package. They are thinner.
Footnote
Thinner? The top 2 rings on both the 11.25:1 piston and stock piston are identical. its the oil ring on the 11.25:1 piston that's thicker and wider then the others. 4mm thickness vs 2mm and .128in width vs .160in
1994 WR250-Z | 1997 KX500 | 1998 KLX300 | 2004 CRF450R (Motard) | 2009 KX450F | 2001 XR650R | 1992 WR200R | 1992 WR500-Z | 1986 GPZ900 | 2005 RMZ450 | 1986 CR500AF in a 1998 CR250R frame | all street legal
"Great! What am I supposed to use now?! Harsh language?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 06-24-2012, 09:48 AM   #43757
mcma111
mcma111's Avatar
Oddometer: 11,904
Actually the 9.1 and 10.5 compression pistone use the 1.2/1.5/4.0 rings and the 11.25 uses the 1.2/1.5/2.0 rings. I just went through all of this last week as I re-ringed a fellas XRL that has a JE piston in it. Ended up buying two sets of rings because of the web site. The JE site is WRONG. Where did we ever hear this from before???
The bike I worked on has a JE piston that has 102 JE cast into the bottom of the piston but it measures 101mm !!!!!
I needed a set of rings so at first I grabbed my new JE 102 piston that I got from CW only to find that JE included a totally WRONG ring pack. Not even close to correct. Multiple calls to CW and him to JE finally resulted with CW sending me a proper set of 102 rings and me returning the incorrect rings to CW.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-24-2012, 10:06 AM   #43758
my6
my6's Avatar
Oddometer: 344
What am I Missing?
Well, I finally got some time to trouble shoot my No Spark Issue...
1-replaced the cdi = no spark
2-check coil primary = reads .2
3-check secondary coil = reads 9.3
4-check pulse generator = .500 (the manual says 423-517) hhhmmm?
5-clutch assy wires = modded by a previous owner (the two wires are spliced together)
6- check side stand switch = continuity when up/down=no
7-kill switch- took it a part and cleaned it. Dialectic grease was/is present and I roughed up the contacts as much as possible. It looks to be functioning as designed.
Have I missed something? If not I guess a complete wiring Harness is next huh?
Check your Six
04/625 SXC,
my6 is offline   Reply With Quote
Old 06-24-2012, 10:10 AM   #43759
mcma111
mcma111's Avatar
Oddometer: 11,904
Replace the handle bar start switch assy. It's not the kill, on/off portion of the switch it's the red start button that you can't get in to. My bike was giving me no start headaches and I hosed both the on/off and start button with electrial cleaner and all is well now. I will eventually buy a new switch assy. Or just for shitz replace the pulse generator. This is my guess from many miles away.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-24-2012, 10:16 AM   #43760
mcma111
mcma111's Avatar
Oddometer: 11,904
Kubiak's XRL is for sale:
http://fresno.craigslist.org/mcy/3093982931.html
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-24-2012, 10:28 AM   #43761
my6
my6's Avatar
Oddometer: 344
Did your on/off switch show to be working properly with a meter? Mine does....
Check your Six
04/625 SXC,
Old 06-24-2012, 10:35 AM   #43762
mcma111
mcma111's Avatar
Oddometer: 11,904
I never bothered to check it with a meter. I just hosed it out with cleaner and it's been working fine since.
I'd throw my dart at the PG
BTW... Have you had the parts off of the crank shaft on the clutch side?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 06-24-2012 at 10:42 AM
Old 06-24-2012, 10:39 AM   #43763
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,227
Wish you were here
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 06-24-2012, 10:41 AM   #43764
my6
my6's Avatar
Oddometer: 344
I'm thinking the same thing. The manual says to look for 423-517. My reads .500 I'm guessing it's not a typo in the manual. lol Lord I wish I could lol about now..
Check your Six
04/625 SXC,
Old 06-24-2012, 10:41 AM   #43765
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,227
This must be the guy that bought it from him?
Old 06-24-2012, 10:43 AM   #43766
mcma111
mcma111's Avatar
Oddometer: 11,904
Unless he built two of them.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-24-2012, 10:58 AM   #43767
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,286
Went through the same issue a few months ago.....the 11.25:1 oil rings are 4mm wide due to a wider spacer.,the 10.5:1 ring set uses a 2mm oil ring spacer...........i ordered for a 10.5:1 piston and the oil ring set was too narrow..........CW sent me a 11.25:1 piston is why.........and the oil ringet is wider on the 11.25:1 piston..
B
techforlife is online now   Reply With Quote
Old 06-24-2012, 11:11 AM   #43768
flyingwombat
frozen dead guy
flyingwombat's Avatar
Oddometer: 767
Originally Posted by seth0941 View Post
Reusable Oil Filter, who uses them and what do you think? Looks like it will pay for itself in 4 oil changes.
Booooooogus. I think there is a thread here on ADVrider showing the holes you can clearly see through the metal mesh, compared to paper filters. They are probably better than no filter at all but oil filters are made to collect stuff and be thrown out. Not a good area to try to save a buck in my opinion because it'll just cost you more in the long run. Besides, you don't need to clean a paper filter- just replace it.
Bad Medicine: Baja October 2011 - White Rim Sandwich (with Kokopelli bread) - Please help support COHVCO!
flyingwombat is offline   Reply With Quote
Old 06-24-2012, 11:22 AM   #43769
mcma111
mcma111's Avatar
Oddometer: 11,904
Reusable Oil Filters
For the life of me I have never been able to figure out what the deal is with reusable oil filters. Yeah they sure look neat being made of stainless steel but HOW IN THE HELL DO YOU CLEAN ONE??? Take it to your dentist and drop it in his ultrasonic cleaner???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-24-2012, 11:22 AM   #43770
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
uSE $20 of brake cleaner
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Times are GMT -7.   It's 09:09 PM.
