Old 10-12-2012, 04:27 PM   #47506
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 639
Originally Posted by Sierra Thumper View Post
I think with a few mods the xrl makes a great dirt-oriented dual-sport. When you dump all the restrictive emmissions, and let the bike run to its full potential by opening up the carb/slide/airbox+filter and exhaust (which made a huge diff on my bike), plus a suspension revalve and some minor weight loss, I think it becomes an awesome super low maintainence and very reliable long running machine.
What could honda do to improve it, without taking away the good or raising the price a ton?
in todays economy and bike sales.... nothing.
1994 Yamaha WR250-Z
2005 Gas Gas FSE450
"Great! What am I supposed to use now?! Harsh language?!?!?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 10-12-2012, 07:39 PM   #47507
Spud Rider
Spud Rider's Avatar
Oddometer: 2,946
You're correct; the XR650L is a great motorcycle. However, Honda should (but won't):
Redesign the countershaft and/or countershaft sprocket
Install a "cush" drive on the rear wheel
Reinforce the subframe
Dump the battery box, and redesign the air box to incorporate one of the smaller batteries
Move the CDI unit into the airflow, and locate the CDI unit near the center of the bike to minimize punishing vibrations
Remove the air shrouds and add an oil cooler
Install a larger fuel tank
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Spud Rider screwed with this post 10-12-2012 at 07:46 PM
Old 10-12-2012, 07:47 PM   #47508
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 639
Spud
wow spud! for once someone with intellengent suggestions for a new/updated big bore honda dual sport! I always see idiots (including myself) make suggestions like "it should be bigger, faster, newer, cheaper, and sparkly!!"
1994 Yamaha WR250-Z
2005 Gas Gas FSE450
- Duke Nukem
Sub Zero screwed with this post 10-12-2012 at 08:30 PM
Old 10-12-2012, 08:17 PM   #47509
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 706
I think that everything that Spud suggested is right on the money!
Sure, more power and fuel injection might be cool, but also probably make it weigh more and be more of a pain to work on.
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is offline   Reply With Quote
Old 10-12-2012, 09:15 PM   #47510
Lonestar2112
Crash test dummy
Lonestar2112's Avatar
Oddometer: 5,202
I just fell in to an very reasonably price fork set from a 450f. Once you do the transformation how do you guys mount the speedo, ignition key, and the headlight and mask?
Where am I?
"I love the wild spaces above the border, takes some work to get here, ain’t a Starbucks run." jdrocks
F*CK Cancer
Lonestar2112 is online now   Reply With Quote
Old 10-12-2012, 09:54 PM   #47511
beechum1
beechum1's Avatar
Oddometer: 4,818
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Reasonable prices vapor or vector and LED lights with homemade brackets and wiring. Did you get cleared for riding?
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 10-12-2012, 09:58 PM   #47512
Lonestar2112
Crash test dummy
Oddometer: 5,202
Not really, They said another couple of weeks. I have a Sanjon mask and two LED lights. Just trying to figure out how to get it all mounted after I do the conversion. Also trying to figure out how much it is going to cost after I buy the forks.
Where am I?
F*CK Cancer
Old 10-12-2012, 10:04 PM   #47513
BigStick
Discovering
BigStick's Avatar
Oddometer: 42
Spud
Perfect, Spud! But...didn't you just describe your XRL?
Besides, I love your mods and half the fun is customizing a bike no one else has! Dare I say, these things are kinda like Harleys!
"A motorcycle is whatever you want to make it. Turn it on and you can give yourself a real thrill!"
~ Bruce Brown, On Any Sunday
AMA Lifetime Member
BigStick is offline   Reply With Quote
Old 10-12-2012, 10:13 PM   #47514
beechum1
beechum1's Avatar
Oddometer: 4,818
You need the stem turned?
Old 10-12-2012, 10:26 PM   #47515
Lonestar2112
Crash test dummy
Oddometer: 5,202
I have no clue what I am getting myself into. I have the forks, the top and bottom triples and the hub with the brake brackets.
Where am I?
F*CK Cancer
Old 10-12-2012, 10:43 PM   #47516
Sierra Thumper
Oddometer: 641
Spud
Those are good, cost-effective and reasonable improvements I wish Honda would pay attention
I'd also like to see higher compression, and maybe a better performance carb stock........and there's got to be a way to meet emmissions requirements without needing to restrict it so badly off the show room floor. BMW is able to meet U.S. EPA regs with their S1000R, and the thing still makes 13 or so hp more than the zx-10...but when you derestrict the 10 it matches the beemer. I guess maybe some companies aren't as good at meeting U.S. regs as others
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-12-2012, 11:55 PM   #47517
RZRob
RZRob's Avatar
Oddometer: 661
Improving the XRL
Add plate, rack and taller gearing and I'll sign-up.
RZ Rob
RZRob is offline   Reply With Quote
Old 10-13-2012, 12:18 AM   #47518
no66
Oddometer: 7
I did this conversion on my XR600 this summer. I opted for the http://www.emigracing.com/ stem convertion. Worked well.
As for lights etc, I have a baja kit. You will probably have to make up some brackets.
I think there is a CR450 hub (X ?) that works with the speedo cable. I run a Vapor so no problem there.
Enjoy the forks. Great improvement.
XR600R, 1995
no66 is offline   Reply With Quote
Old 10-13-2012, 05:55 AM   #47519
mcma111
mcma111's Avatar
Oddometer: 7,986
RSW Racing upper triple clamp. No other set up that I know of allows the use of the OE ignition, fork lock. Speed-o mounts right up. If you get his lower triple the OE stem is a direct fit. No fuss, no muss.
You say you got a HUB. Don't expect to use your OE rim with that hub. XRL wheel has 32 spokes and the CRF has 36. Ask how I found that one out... Need a wheel built? Send me the parts.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-13-2012, 07:32 AM   #47520
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,177
I would think that most the development cost for USD forks have been paid off, so adding those should not raise the price that much. Move the gearing gap between 3rd and 4th gear. You wouldn't need the 6 speed if 4th and 5th were geared to higher, and you still have 1st through 3rd for the slow speed stuff. Like Spud, it needs a factory option for an oil cooler and a cush drive. It would be easy enough for them to use the XRR counter shaft sprockets by milling just a little more of the shaft. Those little batteries are kind of high priced, not sure I would want to add that to the bikes price, my WR battery cost more than the one in my pickup A bigger tank is nice, but I'm not sure if manufactures can use plastics tanks on street legal bikes (although it seems KTM does?). I'm not sure I want a bigger steel tank (if I wanted a KLR I would have got one of those ). Myself, I wouldn't be against an XRR with E-start in street legal trim either.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is online now   Reply With Quote
Times are GMT -7.   It's 08:06 AM.
