Old 10-15-2012, 07:30 AM   #47581
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Made it out for an amazing ride yesterday. Thought I would share a pic... this on one of my favorite roads!
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 10-15-2012, 07:36 AM   #47582
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Cheers,
Cumbacheech
Nice fall colors. Had any snow yet and when did you get a USD front end?
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 10-15-2012, 08:30 AM   #47583
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Originally Posted by mcma111 View Post
For a stock piston/compression ratio the 160 is going to be to rich.
The overflow is probably some dirt in the needle and seat. Open the float bowl drain screw and turn on the petcock. It may flush the debris away. If not then you'll have to open the carb for inspection.
2012 Honda XR650L Adventure Bike
Honda XR Fan for 30+ years!!!!!
Rider11x is offline   Reply With Quote
Old 10-15-2012, 08:31 AM   #47584
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Originally Posted by fritzcoinc View Post
Be specific about what hose. One is a vent and the other a bowl drain.
The vent lets the bowl breath and connects to carb. above the fuel level.
The drain comes from a drain valve at the very bottom of the bowl.
If fuel from the vent hose, the float needle is leaking for some reason.
If fuel from the drain hose, the drain screw is leaking for some reason.
Bowl drain hose. What is the screw on the bowl for?
Old 10-15-2012, 08:40 AM   #47585
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,615
Some nice fall pics guys. Walter, neat shot over the water.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 10-15-2012, 08:44 AM   #47586
mendoteach
mendoteach's Avatar
Oddometer: 1,576
Originally Posted by RZRob View Post
I agree 100%, however the XRR simply makes it easier. These hills were pretty rocky and rutted-up with lots of loose rocks dirt sand and gravel. I have to admit it was challenging stuff.
RZ Rob
Rob, could you measure the ground clearance between the R and L? I'm sure the L has more ground clearance. It sure appeared that way when I rode with a R recently. FWIW, the best way to make the L feel like a 'dirt bike' is to put on some upside down (the term has to be getting old now)/males slider forks on. If you are riding difficult terrain or charging hard it makes an amazing difference. When a bike holds a line it feels lighter. I'm sure the stiff frame on the R contributes much to that feeling of off-road prowess.
mendoteach is offline   Reply With Quote
Old 10-15-2012, 08:51 AM   #47587
Cumbacheech
XRated
Oddometer: 823
Thankfully no snow in my area, but there has been a little about 5 hour drive from me. I got the USD forks this year. I am noticing a big improvement over the stock forks with upgraded springs. These forks are off a newer (05 fwd) CR250R. I upgraded the springs and put in the RaceTech gold valves. I really like them,
Cheers,
Cumbacheech
Old 10-15-2012, 08:51 AM   #47588
elsalvadorklr
southern xr rider
Oddometer: 4,154
^^^^^^very well put
stiffness and holding line abilities make a bike a million times easier to ride
usds and a stiff frame do this...
nothing worse than a sloppy, heavy mushy, wallowing feel on a tight trail!
elsalvadorklr is offline   Reply With Quote
Old 10-15-2012, 10:20 AM   #47589
prince_ruben
prince_ruben's Avatar
Oddometer: 1,726
Originally Posted by Rider11x View Post
Man, I was hoping that was the issue, but not this time anyway. Good knowledge for down the road though.
So I pulled the carb, removed the bowl, and to be quite honest, I found nothing out of the ordinary. Not sure what to think. I bumped up the main from a 155 that I put in when new to escape the factory lean condition, and popped in a 165 main as I am removing the snorkel and doing a full exhaust while everything is opened up. Also finishing the Dave's mods, and doing a valve adjustment check. I'm at 4,500 miles, so it probably wouldn't hurt to have a look at them.
So, is there something I am missing on the overflow issue? Something to look for?
When removing the snorkel, and adding a full FMF exhaust, is going up 5 on the pilot from the 55 I put in to make it run good stock, to a 60 sound about right? And replacing the 155 I also put in it to run good stock with a 165 sound about right? Motor all stock besides these intake and exhaust mods running a stock air filter. I have a 170 but that might be too much. Please chime in!! Thanks!!
My bike has Dave's Carburetor mod's, Full FMF, Uni Filter, 55/160 jetting and it's still too rich. I will try 55/158 with OEM filter.
No worries in death, no worries in life.
prince_ruben is offline   Reply With Quote
Old 10-15-2012, 11:32 AM   #47590
EsconDeasy
Ectomorph
EsconDeasy's Avatar
Oddometer: 1,482
I don't have it in front of me but I'm pretty sure my brochure for the R says it has "A whopping 12 inches of ground clearance" Maybe 'whopping' is the sound it makes when you case it.
Anyway, the L has 13" or a little more
Is nothing scared!?
EsconDeasy is offline   Reply With Quote
Old 10-15-2012, 11:34 AM   #47591
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Cheers,
Cumbacheech
I assume you mean a CRF250R? Are there details of the conversion anywhere? What would be an approx. total cost to do one? May be my next mod.
Old 10-15-2012, 11:39 AM   #47592
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,537
The drain screw? It allows you to drain the gas out of the float bowl (after you turn off the petcock, of course).
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 10-15-2012, 01:21 PM   #47593
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 641
CR or CRF are basically the same. I too have a front end from a 1991 CR250R on my L and upgraded the springs with some from Progressive Suspension. There are threads on here that deal specifically with this.
Basically, I just bought a complete front end with triples, wheel, brakes, and then pressed out the stem and had it machined to match my XRL stem so I could use OEM bearings.
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 10-15-2012, 01:57 PM   #47594
elsalvadorklr
southern xr rider
Oddometer: 4,154
here is my swap on an xr...same thing
http://www.advrider.com/forums/showthread.php?t=774934
Old 10-15-2012, 01:57 PM   #47595
RZRob
RZRob's Avatar
Oddometer: 1,574
Size doesn't matter
Oh, my L is a notably bigger bike. That was the first thing I noticed when I saw the XRR. The XRR feels a lot more like my CRF. Since I steer a dirt bike around with the back tire, having the extra power of the XRR and the fact that it just wasn't as massive of a bike, made the XRR feel a lot more confidence-inspiring.
Still, the XRL is my choice for anything of sizeable distance or involving an overnighter.
RZ Rob
RZRob is offline   Reply With Quote
Times are GMT -7.   It's 12:13 PM.
