Old 10-16-2012, 07:47 AM   #47626
blitheringidiot
Regurgitated User
blitheringidiot's Avatar
Oddometer: 301
Originally Posted by 3girlsdad View Post
this one is popular and works great. i also put an led bulb in it that i got off flebay. although i hate motorcycle-stupidstore.com, here's the link.
Have you had any trouble with the wiring, problems with the brake light not being bright enough or burning out bulbs, like the reviews mentioned in your link? Or did the LED bulb take care of the intensity/burnout problems?
blitheringidiot is offline   Reply With Quote
Old 10-16-2012, 08:00 AM   #47627
cms81586
Oddometer: 258
I've gone through about 3 bulbs per year. The WPS brake light does not have the same shock absorbing capability as the stock light...so on rocky/rough terrain the bulb takes a beating. The worst part is they're a pain in the ass to find. I have a few extras that a forum member here gave me...but I've yet to find any spares. The lense will also start to get brittle and crack if you tighten it down too much after a year or so...but at the price I don't care. Anything looks better than the antenna hanging off of the back as it comes stock.
Black 08 Duc HYM 1100S, 04 Honda XR650L, Specialized TriCross...
cms81586 is offline   Reply With Quote
Old 10-16-2012, 08:01 AM   #47628
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by elsalvadorklr View Post
here is my swap on an xr...same thing
http://www.advrider.com/forums/showthread.php?t=774934
Very good source! Make sure you read it fully, lots of good things in there that I missed... I also had a thread that I put up questions etc and have some info for reference...
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 10-16-2012, 08:05 AM   #47629
Cumbacheech
XRated
Oddometer: 823
Originally Posted by KyoXR View Post
Cool picture, looks like some nice riding weather there,
The thermometer on the porch is reading 90 degrees right now , I like to ride in the upper 50's lower 60's...
Fall is my favorite riding season, nice and cool, amazing colors!! I can get lost for hours and not even realize it.
Cheers,
Cumbacheech
Old 10-16-2012, 08:13 AM   #47630
3girlsdad
aka FiddyK
3girlsdad's Avatar
Oddometer: 385
the led bulb has taken care of the intensity (i find that it is brighter) and burnout problems (so far after 3-4 months of use mostly offroad).
2008 Honda CRF450X - plated
2007 KTM 450 XCW - a little sip of the kool-aid (gone)
2011 Beta 450 RR - plated (gone. had my sexy italian fling)
2008 Honda XR650L - (gone)
3girlsdad is offline   Reply With Quote
Old 10-16-2012, 09:06 AM   #47631
pngaudioguy
Just...one...more...
pngaudioguy's Avatar
Oddometer: 517
Originally Posted by Ben99r1 View Post
I been running the xrr type of brake light for the past few years. But I always break them when I do some serious dirt riding. I am thinking of trying a different type or brand of light. can you guys suggest a LED type that might work. i am thinking of ordering one of these. has anyone ever tried this one? http://www.ebay.com/itm/160897125341...84.m1423.l2649
If you're not afraid of a soldering iron, or dremel, and like making stuff, check out my DIY version in my signature. If you wanted an even brighter version, you could drop to 2 rows of 5 instead of 2 rows of 6 to increase the forward voltage. The LED's I used can definitely handle it - see my blinkers...
It's held up to a decent amount of abuse (no collisions), and the LED's are definitely bright / directional enough that people seem to stop further behind me when I hit the brakes.
pngaudioguy is offline   Reply With Quote
Old 10-16-2012, 09:58 AM   #47632
Cumbacheech
XRated
Oddometer: 823
Just looked at your DIY thread... WOW!!
I found some other led taillight over here. Think this may work, may need a little modification.
Cheers,
Cumbacheech
Old 10-16-2012, 11:01 AM   #47633
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
The LED tail light shown in your link should work fine, Ben. All LED bulbs are highly resistant to vibration, and will withstand the punishing vibrations associated with trail riding.
I like the WPS tail light shown by 3GirlsDad; I have ridden my XR650L about 30,000 miles with this tail light installed. The original, incandescent bulb installed in my WPS tail light was extinguished by vibrations, so I installed a Trail Tech LED bulb in my WPS tail light. This LED bulb has been working great for 22,200 miles.
http://www.rockymountainatvmc.com/p/...trail+tech+led
I'm sure you can find brighter LED bulbs on eBay, as did 3GirlsDad. Any decent LED bulb with a sufficient number of LEDs will work well with the WPS tail light. I haven't had any problems with my WPS tail light. The WPS tail light will work superbly after you install an LED bulb in it.
Spud
Spud Rider screwed with this post 10-16-2012 at 11:42 AM
Old 10-16-2012, 11:41 AM   #47634
Ben99r1
Ben99r1's Avatar
Oddometer: 3,090
The wps light
The wps light is what I have been using for about 3 years. I do break 1157 short bulbs all the time. I also break the red lens covers about twice a year. I know they are cheap but I am getting tired of breaking and changing them.
Ben99r1 is offline   Reply With Quote
Old 10-16-2012, 11:55 AM   #47635
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
The WPS tail light is quite small, and is well protected. How are you breaking the red lens?
After you install the Trail Tech LED bulb you won't need to replace it very often. Therefore, you will be less likely to break the red lens of the WPS tail light by tightening it too much. You certainly can't beat the price of the WPS tail light; at a cost of $12.99, it's a great deal.
http://www.motorcycle-superstore.com...ail-Light.aspx
Spud
Spud Rider screwed with this post 10-16-2012 at 12:00 PM
Old 10-16-2012, 12:14 PM   #47636
3girlsdad
aka FiddyK
3girlsdad's Avatar
Oddometer: 385
one thing you don't see in the pic for the WPS tail light is the small clear portion on the bottom that serves as the license plate light, fyi...
Old 10-16-2012, 12:51 PM   #47637
Wikedhd
Wikedhd's Avatar
Oddometer: 47
2008 XR650L rear shock needed
Have a blown out rear shock, looking to have rebuilt or replace it.
Any ideas?? Not wanting to pay dealer price!;(
Wikedhd is offline   Reply With Quote
Old 10-16-2012, 12:57 PM   #47638
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,215
How much brighter is the led? Was it plug and play or did you need to make some mods?
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 10-16-2012, 01:08 PM   #47639
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 815
whats wrong with motorcycle superstore? ive been rather happy with them but ive only used their site to buy tires. sometimes they have deals on there for some new rubber even better then what i can find anywhere else! including ebay!
1994 WR250-Z | 1997 KX500 | 1998 KLX300 | 2004 CRF450R (Motard) | 2009 KX450F | 2001 XR650R | 1992 WR200R | 1992 WR500-Z | 1986 GPZ900 | 2005 RMZ450 | 1986 CR500AF in a 1998 CR250R frame | all street legal
"Great! What am I supposed to use now?! Harsh language?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 10-16-2012, 01:29 PM   #47640
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
The Trail Tech bulb has 20 LEDs facing the rear, and is quite bright. Whether you buy an LED bulb from eBay or Trail Tech, the most important factor is the shape of the bulb. The WPS tail light will only accept shorter bulbs, so choose a bulb which has an LED portion which is shorter than 7/8-inch (23mm). Also, make sure the LED portion of the bulb is not too wide. If the bulb is short enough, it fits easily without any modifications, whatsoever. The Trail Tech LED bulb fits easily, so you can use it as a model to compare other LED bulbs.
Spud
Spud Rider screwed with this post 10-16-2012 at 01:54 PM
Times are GMT -7.   It's 09:09 AM.
