10-30-2012, 09:29 AM
#48331 |
I wish I was cool
Oddometer: 214
Die Living. My brother stole my XR to go the South America so I stole his HD to piss off hippies in Corvallis. His ride report http://advrider.com/forums/showthrea...2#post19932112 |
10-30-2012, 12:29 PM
#48332 |
Oddometer: 7,711
My first XRL had a 140 Metzeler enduro on it. No problems with it. I got close to 8000 miles out of it, twice the mileage I get with a D606...at twice the price though. I put another set on a couple years back but I usually like to run knobbies. The Metzelers work well in most terrain except mud. They suck in mud...
I usually run a 130 D606. I have had zero problems with any of them. The only thing I don't like about D606's...the front tires always wear real funny so I've been a cheap skate and have been running Michelin T-63's up front.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST bwalsh screwed with this post 10-30-2012 at 01:10 PM |
10-30-2012, 01:00 PM
#48333 |
Oddometer: 7,711
Speaking of new bikes...
My 04 needs some work which will entail tearing it apart and I assume it will take awhile to get it back on the road(based on my slow ass). So, I had been looking for something different to buy and ride while the 04 was in pieces. I came home with this a few weeks back...
Hey, It's different! It's an 08 with 2,717 miles. It had been rode hard and put away wet...quite a bit of mud all over it! Came with what looks like a TCI Borrego luggage rack, Cortech bag on the rack, D606's F&R, FMF Q4 slip-on, Skid plate(don't know which brand), Pro Taper 1" risers, Pro Taper CR-high bend bars and Moose bark busters. The carb has a dyno-jet kit installed. I took it apart to see what had actually been done. It had a 50s pilot jet and a 165 main jet and the DJ needle with the clip in the third slot. The slide had not been drilled so I did that and while I was in there I replaced the needle with the stocker and a washer. I bought that Acerbis 5.8 tank and installed it(what a bitch!) and moved the IMS pegs over from my 04. I have the RSW fork brace off the 04 and intend to install it on the 08 but wanted to see the difference in handling without running one. It was on the 04 when I bought it. My first tank of gas resulted in 37.4 mpg's. Definitely not running lean! It has an ever so slight bog on acceleration form say 30 mph up. I'm going to replace the jets with a 58/160 combo and see if I can get a few more mpg's out of it. I'm hoping to at least get it up to what the 04 was getting, ~44 mpg.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST bwalsh screwed with this post 10-30-2012 at 01:07 PM |
10-30-2012, 01:04 PM
#48334 |
Oddometer: 7,711
Now I need a little help please...
The bar risers on the new bike are...
A: too short and... B: hit the new tank. So far I've just been dealing with it but it is nice to be able to use the whole range of motion. The 04 had a 3" RSW racing triple clamp(dropped for a Kouba lowering link) and the stock cables work fine. I'd just switch out triple clamps but the RSW risers are for a 7/8" bar, not the 1 1/8" bar I have now. What I'm thinking I want are the Rox 3 1/2" risers. So... Is anyone running the 3 1/2" risers on a stock bike, stock cables, no lowering link. Do the stock cables work with the 3 1/2" riser? If they don't reach, I can probably make due with the 2" risers for the time being as I'd rather deal with a little slouching then replacing all the cables at this time.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST bwalsh screwed with this post 10-30-2012 at 01:11 PM |
10-30-2012, 01:31 PM
#48335 |
Crash test dummy
Oddometer: 5,197
I did the 3.5" rise. I also added ATV high bend bars. The results.....new cables +3" and +4" to keep things clean. Motion pro has the clutch and choke cables at +3". I went with +4" Barnes for the throttle cables.
I did not try with the Rox and a regular bend bar.
Where am I? "I love the wild spaces above the border, takes some work to get here, ain’t a Starbucks run." jdrocks F*CK Cancer |
10-30-2012, 02:12 PM
#48336 |
Oddometer: 2,364
Moose fat bar adaptor, risers, tallest 50mm & Protaper Pastrana FMX/ATV High bars. Stock cables, maybe a little rerouting & works great.
10-30-2012, 02:14 PM
#48337 | |
CDI REPAIR
Oddometer: 3,312
![]() My grammar and spelling is supposed to suck,,i was a mechanic for 25 years and sniffed alot of chemicals ![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
10-30-2012, 02:24 PM
#48338 | |
Oddometer: 7,711
Just an FYI...got off the phone with Motion Pro. They have 3" longer push, pull(throttle) and clutch cables in stock(not in their cataloge yet) for the XRL. They don't have a 3" replacement for the choke yet... Prices given to me... Pull cable =28.19 Push cable =27.23 Clutch cable=15.99 Choke cable=35.00(custom build) Who is this "Barnes" you speak of? Got a link?
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
10-30-2012, 02:27 PM
#48339 | |
CDI REPAIR
Oddometer: 3,312
wtf............. ![]() B
10-30-2012, 02:30 PM
#48340 | |
Crash test dummy
Oddometer: 5,197
I did Rox rizers. They are the only ones that I will use. The Barnes cables are spendy. It cost me $40/cable. Those prices seem reasonable. I bought my bcables 8 months ago and MP said that they were going to make the choke cable a standard....I gues they are a bit slow. I miss typed. Barnett. http://www.barnettclutches.com/ They are local to me. If you order it will be a special order. Yes they do cables also.
10-30-2012, 02:39 PM
#48341 |
Enjoying my last V8
Oddometer: 5,299
Yeah, me too, WTF? I only counted one comma. Must be a Hillbilly thing???
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
10-30-2012, 02:47 PM
#48342 | |
CDI REPAIR
Oddometer: 3,312
![]() B
10-30-2012, 02:50 PM
#48343 |
Oddometer: 3,430
2009 XR650L Steve |
10-30-2012, 03:01 PM
#48344 |
Oddometer: 641
I have a Big Gun slip-on on my xrl, just wondering how much noticeable benefit I'll get from adding an aftermarket header to go with it? I really don't want to lose any of the awesome torque I have now, but wouldn't mind a little more power for higher speed highway cruising at my 5000 to 8000+ft of elevation. In my experience with other bikes, you almost always lose some low end to gain up top with aftermarket exhausts. Just wondering how the xrl is affected, and if its worth doing?
Thanks in advance for any feedback given
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack Sierra Thumper screwed with this post 10-31-2012 at 11:21 AM |
10-30-2012, 03:09 PM
#48345 | |
Enjoying my last V8
Oddometer: 5,299
I have the White Bros. E3 system, header and muffler. The low end does not seem to be affected by this combination. If highway cruse seems sluggish, you may be jetted too rich for your altitude. For 5000 to 8000 feet you should be at 48 pilot and 145 to 147 main. Check with a dealer at your altitude.
