10-31-2012, 04:38 PM
#48376 |
Oddometer: 2,364
10-31-2012, 04:47 PM
#48377 |
Oddometer: 43
Took my first real ride today and man, my new seat can't come in the mail soon enough. That plank of death is brutal.
10-31-2012, 05:08 PM
#48378 |
wannabe adventurer
Oddometer: 1,299
IMO, my stock XRL seat is much more comfortable than the stock seat was on the KLX400 I had previously.
#48379 |
Oddometer: 2,364
10-31-2012, 05:11 PM
#48380 | |
pistolero
Oddometer: 1,175
84 Honda Goldwing (GL1200) 03 XR650L |
10-31-2012, 05:15 PM
#48381 |
pistolero
Oddometer: 1,175
Wouldn't know why it wouldn't be good for your splines. It should have the wider spline area like your 14t. Little Honda molly or any molly 60 grease on the splines would help also.
10-31-2012, 06:04 PM
#48382 | |
Oddometer: 142
My next order of business is the tag mount and figuring out if I need to burn lights on the tag (I've never owned a motorcycle in NC). Currently it has a WPS tail light... much more recessed than stock... which I like. I don't think I can use a stock tag mount with a WPS light and a rear fender that has been trimmed/shortened? The previous owner left me with just 1.75" of fender remaining beneath the tail light. I was hoping to have a solid tag mount and not have to resort to "hanging" the tag off the edge of the fender... but will do what I have to. Thanks again for responding and helping a new XRL owner out! absoluteclint screwed with this post 10-31-2012 at 06:18 PM |
10-31-2012, 06:23 PM
#48383 |
10-31-2012, 06:47 PM
#48384 | |
Oddometer: 3,066
The amazing karnac says "The answer is, a goldwing" Lets open the envelope and read the question, hmmm, "What was your last bike?"
---->>Thanks for the rotor, guys!<<---- |
10-31-2012, 06:52 PM
#48385 |
Oddometer: 2,364
10-31-2012, 06:56 PM
#48386 |
Oddometer: 2,940
Yes, the stems are flexible.
These are very nice, sturdy turn signals; I like them a lot. Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
10-31-2012, 07:04 PM
#48387 | |
M0DAH0LIC
Oddometer: 1,943
For example look at the dudes with cruisers, some of them have their plate mounted on their swingarm with out a light. My point here is that it is required but rarely ever troubled with. Now with that being said... The way I fixed the problem you are describing was by wiring in 1/2 of one of these guys.... http://www.autozone.com/autozone/acc...ier=60049_0_0_ You can cut them on the marked spots and the 3M adhesive on the back of them lasted years. To hide and protect the wire have the fender off and cut thin strips of electrical tape to hold the wire in the desired location, then cover it (as neatly as possible) with the ultra black silicone that you can also get at autozone. Wire it into the same power as the tail light. It sounds like a lot, but it's pretty easy and those lights are BRIGHT! I had another one right above the tire to assist in night time repairs... -Barron
1996 XR650L with a couple mods If everyone brewed beer there would be no war. ![]()
10-31-2012, 08:50 PM
#48388 |
Ice Breather!
Oddometer: 639
anybody wanna talk to me about suspension settings?? specifically the rear. I have no experience working on suspension or setting it up etc.
i was fussing about with the little cylinder doo dad thats attached to the rear shock. has a little nub on the bottom to fill with air or nitrogen? i got out my pressure gauge it was at something like 30psi. i kept foolin and fussing with it and dropped it down to about 10 psi. now it feels springy. i put some air back in it up to 16psi. i really had no idea what i was doing so i decided to stop. bike still feels a little springy in the back. whats the ideal setting for someone who lives in flat sandy FL with lots of sand whoops who weighs 150lbs? Thanks! ![]() Edit: did a little research, apparently these little canisters can be filled all the way up to 150psi which i read seems to be normal for these shocks? filled the canister up to 150psi now (which is the max my air compressor can do). now it seems its back to how it used to be and the springyness has gone away (kinda stiff and not smooth and fluid like im hoping, but then again i dont know whats normal and whats not for these suspension settings)
1994 Yamaha WR250-Z "Great! What am I supposed to use now?! Harsh language?!?!?" - Duke Nukem Sub Zero screwed with this post 10-31-2012 at 09:04 PM |
10-31-2012, 09:01 PM
#48389 | |
10-31-2012, 09:05 PM
#48390 |
Ice Breather!
Oddometer: 639
I edited my first post. I added more air. 150psi is the max my air compressor can do. it seems like its back to how it used to be. the springiness has gone away.
1994 Yamaha WR250-Z "Great! What am I supposed to use now?! Harsh language?!?!?" - Duke Nukem |
