Old 11-11-2012, 10:33 PM   #48886
Helipilot
Helipilot's Avatar
Oddometer: 192
Help with starting issue
Rode my 2004 XR650L (537 Original Miles) last weekend on a mix of trails and pavement. It ran great with no issues and averaged 42 MPG on the 135 mile ride. Went to start it yesterday and it briefly fired up and then died. Would not restart after many attempts. New battery last month. Switched out the CDI fwith a factory new unit, have good spark but will not start. Checked fuel flow and carb is not plugged. Gasoline in tank is fresh from the Shell station. I did notice the valve rockers were all well oiled and not binding during cranking; however, the right front valve taps twice during it's cycle and the other valves only tap once. Is this an important clue?
Have done Dave's mods, and the Uni filter is clean and oiled. Anybody have any ideas? This bike is like new and has been kept in a temperature controlled shop since I bought it new in '05. Haven't had a chance to ride much due to work. I just bid a job that starts in December and goes through March so no riding during that period. Would like to ride a little more before kicking off the project.
Thanks for your ideas.
Helipilot is offline   Reply With Quote
Old 11-11-2012, 10:49 PM   #48887
Ben99r1
Ben99r1's Avatar
Oddometer: 3,043
If you have that low miles on a 04. It could be a dirty or gummed up carb. Take it out and clean it.
Ben99r1 is offline   Reply With Quote
Old 11-11-2012, 10:52 PM   #48888
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,577
try a burst of starting fluid. if its fires its a fuel problem
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 11-12-2012, 02:59 AM   #48889
Sierra Thumper
Oddometer: 641
Ouch!!!
Originally Posted by beechum1 View Post
Working on whoops when this happened. Not surprised, but the last 10 miles on the trail and the other 20 on the street were a bit nerve racking. The only thing holding it on was the battery bracket and one of the seat bolts.
Who's making and selling the gussets ? I don't have time before I move to make them myself I don't think.
It looks like you pushed the top of your tank in too.....plus the subframes bent up pretty healthy. You musta really flipped that poor bike good. hope you're ok
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 11-12-2012, 03:44 AM   #48890
Sierra Thumper
Oddometer: 641
Originally Posted by Wattner View Post
Take 5 minutes and by-pass that fucker.... Millions of miles have been ridden on these motors with no cooler at all. Your ambient temps are ok, not like racing in Baja in August. Keep your ride of a lifetime going and forget about the cooler. I'm WAY jealous of your ride, BTW!!!!
EDIT: Man your in mexico.... Zip tye, wire tie, or use a coat hanger inside a piece of fuel line. Wrap it all the way around the cooler and tie it off to the cooler frame. Improvise... Maxicanize!!!!! Just keep on riding!
Yep xrl's are wonderfully simple, hassle free low maintainence machines, perfect for trips like you're taking. But bolting on complexity adding additions that arent really needed just defeats the purpose. Take that pita tiny little oil cooler off of there and make your adventure that much simpler. Like Wattner said simplify your ride and maximize your pleasure
Old 11-12-2012, 04:00 AM   #48891
Sierra Thumper
Oddometer: 641
Like somebody else said you need to clean the carb.....carbs don't like to sit, and yours has been sitting alot. As little as you ride, you need to shut off the fuel while the bike is running and run the carb dry when you park it. Or drain the carb float bowl. And definately run SeaFoam or another good fuel stabilizer/carb cleaner with your fuel.
Old 11-12-2012, 04:26 AM   #48892
Wattner
Wattner's Avatar
Oddometer: 5,290
Sounds like the kill switch on the handlebars... Turn it off and on a couple of times, and when you turn it on for the final time, make sure it's pushed way down. These damn switches have stranded a few (me included more than once) If that's it, you can disassemble, clean the contacts with emory cloth, add a little electric grease and be good to go.
Best of luck!
Wattner is offline   Reply With Quote
Old 11-12-2012, 05:26 AM   #48893
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,961
Could be!
Bad gas.
RED CAT is offline   Reply With Quote
Old 11-12-2012, 05:44 AM   #48894
mcma111
mcma111's Avatar
Oddometer: 12,089
Reading is an aquired skill
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-12-2012, 06:38 AM   #48895
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,314
Nah, just riding along. The rear subframe is broken off. The only thing keeping it on the whole ride was the battery box bracket and a seat pan bolt. I'm going to dowel the frame a few inches in each direction, drilling holes in the existing frame every 1/2", spot weld the dowel in those holes and around the crack until I can get up to cutout the gussets and weld them on.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 11-12-2012, 06:44 AM   #48896
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
So you adjusted the valves? If so from your description the right front exhaust valve was adjusted incorrectly. You must rotate nthe engine past TDC to get the decompression cam that holds that valve open during starting to fall out. Run the engine around to about 10 deg ATDC and re check the valve clearance.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 11-12-2012, 06:53 AM   #48897
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
Originally Posted by flyingwombat View Post
Yeah, these are pretty cheap and will heat your seat up pretty nicely:
You can get them here.
Tell me, have you ever seen a Taco Bell Taco that looked anything like these in the photo above? I didn't thionk so. You f__Ken yankees. Posting Taco Bell for something that will light your a__ on fire. You don't EVEN know what Mexician Food is all about. Here's a little lunch the gals in the office whiped up.
Regards
Fritzcoinc
Old 11-12-2012, 07:27 AM   #48898
RZRob
RZRob's Avatar
Oddometer: 1,575
Party's Over
Originally Posted by Spud Rider View Post
I just installed a Tusk Grip Heater Kit, which was an excellent bargain at $20. However, I just checked the RM ATV/MC website, and the Tusk Grip Heater Kit is now on sale for $9.99! Trust me, you can't go wrong at that price.
http://www.rockymountainatvmc.com/p/...rip+heater+kit
Spud
Bummer, I had to work yesterday and when I went to RM's website the deal was over. Not that $19 is bad, but $9 is better. Let me know if you see it come back to life. I need at least a couple sets.
RZ Rob
RZRob is offline   Reply With Quote
Old 11-12-2012, 07:37 AM   #48899
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Very true. Taco Bell doesn't serve REAL mexican food. Best I ever had was at an old house in Yuma, AZ that had been converted to a restaurant.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 11-12-2012, 08:06 AM   #48900
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,537
I do miss Texas for the food. The best Mexican food in San Anton was in which ever little dive you stumbled into. You couldn't hardly go wrong.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Times are GMT -7.   It's 04:23 AM.
