Old 11-12-2012, 11:59 AM   #48916
mcma111
mcma111's Avatar
Oddometer: 7,981
Originally Posted by Drunk_Uncle View Post
Or you can do what I did. I broke the sprocket cover and discovered the price of a replacement, so I just left it off. I always wear boots on the bike so not worried about part of me going into the couter sprocket.
How good a job are your boots gonna do should your chain decide to jump ship and punch a hole in the engine case?? They'll just shrug and say Not My Job.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-12-2012, 12:25 PM   #48917
ShooterDave
Oddometer: 1,380
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350
ShooterDave is offline   Reply With Quote
Old 11-12-2012, 12:35 PM   #48918
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,299
Or you can do what I did:
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM,
fritzcoinc is offline   Reply With Quote
Old 11-12-2012, 12:50 PM   #48919
XR650L_Dave
Oddometer: 3,070
For not wadding the chain up should it jump off the rear sprocket or break, should the countershaft chain guard be as close as possible from the sprocket, as far as possible, is there some optimum in-between?
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 11-12-2012, 12:54 PM   #48920
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,564
I would say cLose... You dont want enough space for the chain to get wadded up in between the case saver and the sprocket.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 11-12-2012, 01:31 PM   #48921
bwalsh
Oddometer: 7,711
Just got new steering stem bearings installed...
Does anyone have a slick way to snug up the steering stem to the proper preload setting of 1.1-1.6 kg(2.4-3.5flbs)? I need to snug it down so I can continue to put my 04 back together. I can probably wing it but if I can get it presice then so much the better.
On another note, I remember reading (here?) someone mentioned using PVC pipe as a steering stem bearing driver instead of buying some over priced tool.
I just got finished changing steering stem bearings. I used a hammer and chisel to remove the lower bearing like these guys did.
http://www.garagenight.tv/ep-5-repla...head-bearings/
Piece of cake!
I used an old Carlisle canoe paddle blade I found at work to drive the lower bearing into position! A perfect(snug) fit around the stem and the same diameter as the inner race(so it wasn't bending the bearing cage).
Took the stem/lower Triple Clamp out of the freezer, placed the grease seal and bearing on the stem and placed the paddle blade onto the stem,, against the bearing. Turned the whole thing upside down and about ten easy taps later, on a piece of wood on the bottom of the stem and the bearing was home!
I didn't think to take any pics as I was doing this but this is what I'm talking about...
The paddle blade shaft...
You know what they say about one mans junk!
2004 XR650L
1992 Specialized Stump Jumper FS
NWVA TAG
NWVA TAG MAP
RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 11-12-2012, 02:01 PM   #48922
XR650L_Dave
Oddometer: 3,070
You said 'Shaft', and 'Junk', uh-huh-huh-huh-huh-huh
Old 11-12-2012, 02:10 PM   #48923
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,299
You can torque the nut with a stack of adaptors to get to the equvilent inch pounds. You need to fab a socket. What I do is tighten up the nut with channel locks while swinging the triple side to side. Tighten till is very difficult to swing the triple. Then use a large rubber hammer and drive the stem up into the head and then down into the head again while swinging the triple side to side. This is to get absolutely all the slack out of the bearing installation and seat them completely. Back off the nut and tighten with your fingers only till you can feel no slack or play at all. No matter how you do this job there will be the need for a readjustment after some amount of riding, then you will be good to go for a long time. Don't forget grease!
Regards
Fritzcoinc
Old 11-12-2012, 02:13 PM   #48924
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,299
You want the guide as close to the chain as possible. The broken chain will feed through the gap and fall out.
Regards
Fritzcoinc
Old 11-12-2012, 02:17 PM   #48925
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 516
Bob, snug the "nut" until it is "all the way in" and "withdraw" till it feels nice and smooth.....
'02 XRL '95 K11RS
ecubed is offline   Reply With Quote
Old 11-12-2012, 02:31 PM   #48926
bwalsh
Oddometer: 7,711
But not in the same sentence thank doG. I'd never hear the end of it!
Yeah, I don't know if I have that many adapters!
I did know I will have to re-seat them after about 4-500 miles but thanks for the reminder!
That's how I've done it on my Mtn. bike in the past.
I read somewhere, somebody said they tighten the nut as tight as possible with leather gloves on...and it usually is pretty darn close to the correct spec. 3'lbs isn't a whole lot.
This has to be done, or is easier to do correctly, with the forks in the lower triple clamp correct?
Thanks for the help guys!
2004 XR650L
NWVA TAG
NWVA TAG MAP
Old 11-12-2012, 03:18 PM   #48927
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,112
Originally Posted by taco250 View Post
Near Bend, OR???
Yep, riding with those 'tards in your sig line.
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 11-12-2012, 03:57 PM   #48928
Helipilot
Helipilot's Avatar
Oddometer: 159
Starting Issue
Thanks for the replies to my initial post. To clarify, I did not adjust the valves, just noticed the difference in contact while checking for a stuck valve; also, when I did the Dave's Mod this Spring, I totally cleaned the carb and checked the fuel flow. The bike ran like a sewing machine after the mod and produced a better power to the rear wheel. Has been ridden on trails twice since the carb mod although not to say a piece of crud could have floated around and plugged a passageway in the carb.
I will check the kill switch although the bike produces spark when the plug is removed and grounded while cranking. I will also check the starting fluid trick and flush out the carb again.
Thanks again for all the ideas and suggestions gents. I appreciate you guys.
Helipilot is offline   Reply With Quote
Old 11-12-2012, 04:26 PM   #48929
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 706
Originally Posted by RideAbout View Post
Only photo I could find while at work. I have them installed over Cyra-Probend barkbusters. They cover just enough to keep your hands warm but dont intrude on the fore-arm.... and they make the bike wheelie easier!
Thanks! I hope to do some riding over on that side of the state next summer....
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is online now   Reply With Quote
Old 11-12-2012, 08:00 PM   #48930
mendoteach
mendoteach's Avatar
Oddometer: 1,083
+1. So long is there isn't any notchy-ness, or any free play, it can actually be used as a tuning tool.
mendoteach is offline   Reply With Quote
Times are GMT -7.   It's 09:01 PM.
