Old 11-19-2012, 06:36 AM   #49111
Sierra Thumper
Oddometer: 641
Question I have a question about how different tire sizes affect gearing?
I'm going to be switching from a 120/90/18 Sedona rear tire to a 120/100/18 Pirelli Scorpion XC Mid Hard. There seems to be a big diff in sizing between the 2 brands, the Pirelli looks substantially wider and taller than the Sedona.....how much will that affect my gearing? I'm also going from stock 15/45 gearing to 14/45......I hope the bigger tire doesn't eat up all my gearing change and put me back at stock , that would kinda defeat the whole purpose of the sprocket change.....
Any feedback from you guys who have played with tire sizes would be great
Thanks in advance for any info
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper screwed with this post 11-19-2012 at 06:50 PM
Sierra Thumper is offline   Reply With Quote
Old 11-19-2012, 08:35 AM   #49112
elsalvadorklr
Oddometer: 3,964
tires wear down fast, especially knobs...so you have a "gearing change" by the time you wear out the life of the tread...since its gradual you dont notice it immediately
by the time I wear out my knobs I lose some topspeed...thats all I notice as well as the obvious loss of traction...
I would just compare how the bike feels before the gearing swap...then change front sprockets
lastly
not all tires are labeled or sized equally meaning a 110 maxxis might be the same size as a 130 t63 for example...
cheers
elsalvadorklr is offline   Reply With Quote
Old 11-19-2012, 09:38 AM   #49113
mendoteach
mendoteach's Avatar
Oddometer: 1,083
Originally Posted by 3girlsdad View Post
let me preface by saying i'm a fan of mendoteach, and follow his advice word for word, typically; however, my experience was much different in the aftermarket exhaust realm. i put the vance and hines xcr exhaust on (with a ceramic coated stock header), and it made a HUGE difference to me. i'm 250 lbs, and it will pull wheelies much easier now, even in third with a good yank of the bars and a little clutch. power over all is much better through the whole curve, with quite a bit more top end than before. my exhaust is definitely on the loud side, fyi. just my $0.02.
First, thanks for being my first ever fan. Second, I don't think the FMF Q is the power monger of aftermarket exhausts. The one thing I was very disappointed with was the weight. You hear all these stories of how pounds get shed with them. I was hoping for something substantially lighter. It made a difference, mostly on top, but pretty subtle compared to the nearly free Dave's mods. My stock exhaust also had the welds ground on the header for whatever that's worth.
mendoteach is offline   Reply With Quote
Old 11-19-2012, 09:46 AM   #49114
mendoteach
mendoteach's Avatar
Oddometer: 1,083
Originally Posted by Barron View Post
+2 on the JB weld. I used a dremel to rough up the case surface and the back of the saver then taped off the area that I wanted the JB weld on as Steve advised me in the past . It worked out great. I wouldn't trust the silicone to hold up either, just doesn't seem like the right tool for the job.
Here's a pic of mine...
-Barron
NEVER underestimate the power of silicone on a clean surface!
Old 11-19-2012, 10:04 AM   #49115
mendoteach
mendoteach's Avatar
Oddometer: 1,083
Originally Posted by ReferJohn View Post
Hey Prince-- is that the stock front rotor?
Bike looks Great in SUMO form, might get a new SUMO front fender.
I just ordered 17's on saturday
John, I have a BRAND NEW in the package Honda Red Acerbis Sumo Fender. Was about $45, yours for $25 shipped (should be cheap since you are 50 miles away).
Old 11-19-2012, 10:09 AM   #49116
mendoteach
mendoteach's Avatar
Oddometer: 1,083
I know this is not the spot for this, and that this little spun crack monkey is the polar opposite of our "dirt couches", but Wednesday I picked up this. Couldn't resist, I love my '99 RM250; it is very trick and in great shape, but the '06 was pretty much the last major revision the bike saw. God save the smokers! This thing had a few hours on it and was basically new. Hell yeah!
Old 11-19-2012, 10:28 AM   #49117
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
I recognize the forks!
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 11-19-2012, 10:40 AM   #49118
mendoteach
mendoteach's Avatar
Oddometer: 1,083
You have the 49mm Showas, I think these are 47s. They only used those beasts for a couple years. Not sure there is a better fork for our beasts than those RM forks you have.
Old 11-19-2012, 11:06 AM   #49119
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
It holds together great on the fish tanks I've built. My largest was 150 gallons.
That said I still use JB weld.
I can remove silicone on parts and clean up is easy. JB weld won't just come off.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 11-19-2012, 11:14 AM   #49120
ReferJohn
Behind Bars 4 Life
ReferJohn's Avatar
Oddometer: 198
Mendo---please hold this for me. pm will be sent. I am at work on my tablet- kind of a PITA
to do.
Stand by for details this evening
John
BTW. - KICK ASS RM YOU PICKED UP
'01 XR650L
'06 NPS50
'12 FLTRU
ReferJohn is offline   Reply With Quote
Old 11-19-2012, 11:16 AM   #49121
mendoteach
mendoteach's Avatar
Oddometer: 1,083
FWIW, my JB welded one fell off eventually. I used silicone this time. Time will tell. One great advantage to silicone is that it is far more tolerant of vibration and flexing. JB weld will and does crack. Essentially, it is just epoxy. That said, I don't leave home without it. There's nothing better in the field for fixing a myriad of problems.
Old 11-19-2012, 11:17 AM   #49122
mendoteach
mendoteach's Avatar
Oddometer: 1,083
to do.
John
It's yours. I wasn't going to sell it to anyone until I heard from you. You're the one who wanted it
Old 11-19-2012, 01:18 PM   #49123
XR BADGER
XR BADGER's Avatar
Oddometer: 38
Went the epoxy route, let you know how it holds up.
2007 XR650L, Dave's carb mod's, XR'S only smog kit, XR'S only skid plate, Acerbis 5.8 tank, CRF 450 front fender...
XR BADGER is offline   Reply With Quote
Old 11-19-2012, 02:01 PM   #49124
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,576
I think the 49s were 1999 and 2000. Mine are off of a 2000. Yours look just like mine. I have a spare billet top triple if you ever get the itch to go to fatbars and dont want to futz with adapters.
Old 11-19-2012, 03:01 PM   #49125
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,299
SWEET!!! Nothing like a dirt-only play toy like that!
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Times are GMT -7.   It's 02:42 AM.
