Old 11-21-2012, 10:38 AM   #49186
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,516
Originally Posted by Haywood View Post
first post, bangin on the keyboard all drunk. That's never happened here. Post away on that project right here. (I assume you're talking XRL) You're going to fit right in.
Just made me blow coffee out my nose.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 11-21-2012, 10:38 AM   #49187
Schultz!
Recovering Lurker
Schultz!'s Avatar
Oddometer: 80
Very nice Schultz, first post, bangin on the keyboard all drunk. That's never happened here. Post away on that project right here. (I assume you're talking XRL) You're going to fit right in.
Hehehe, cool have a post in que for mod approval then the fun can began.
Yes she was a XRL but unless you know your Hondas it will be confusing as hell to figure out what she started her life out as. Stuck waiting on cash and parts so sitting at the comp all day cruising the sites.
lots of dismantled parts to a 2007 XR650L
Schultz! is offline   Reply With Quote
Old 11-21-2012, 12:04 PM   #49188
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,582
Originally Posted by fritzcoinc View Post
The plug melted off the back of my light. Repaired by sodering on new FM spade connections to the ends of the wires and shrink tube.
I'll check the plug and see if that sent bad.
Originally Posted by taco250 View Post
My '94 has done that twice. Both times I replaced the bulb with no results, checked for power on various wires and finally took the start button switch apart, blew it out with what little breath I had and that fixed it. For some odd reason if the start button doesn't rebound enough or gets stuck in a little, it can kill the front lights but not anything else. Moral of the story, clean all your handbar switches then lube with dialectric grease. Corvallis is moist in the fall/winter/spring just like GA so they can get gunked up. Hope this helps you.
Thanks, I'll take the switch apart and see if that helps.
Evan
2013 Husqvarna Strada
'93 XR650L (Gone, but missed)
Ooh-Rah! Once a Marine, always a Marine!
Originally Posted by kenny61 View Post
figures...my stud was rusty I played with my nuts a little and it cranked right over
Mossy-Back is offline   Reply With Quote
Old 11-21-2012, 12:51 PM   #49189
mcma111
mcma111's Avatar
Oddometer: 11,905
Hose out the start button with contact cleaner. I had the same problem with the head light and on occasion the bike would crank but not fire. It would bump start though.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-21-2012, 01:09 PM   #49190
absoluteclint
absoluteclint's Avatar
Oddometer: 206
Smog Removal
Hey... I'm anticipating the arrival of my smog removal kit later today (according to UPS tracking) and just wanted to verify a few things before I tackle it... Probably gonna jump on it tonite.
First... Does everyone concur it is better to leave the oil separator on? Thank you to the few folks who responded a couple days ago advising me to leave it in place. What are the consequences of removing it?
Second... If I leave the oil separator on the bike what do I do with the smog kit's main tubing... the tubing that runs from the smog kit to the lower end of the air box. The pics I've been studying on 4strokes.com says that when leaving the oil separator on to just discard the tubing. If I do that it will leave the tubing's connection at the airbox open... Is it ok to leave this open or should I plug it? If plug it... suggestions on a good plugger?
Lastly... When sealing the block-off plates to the head do you all recommend high temp gasket sealer? Like this stuff...
http://www.amazon.com/Permatex-81160.../dp/B0002UEN1A
This is what I already have in my garage. Found or recommend anything that might work better?
In response to the bikini chicks on the XRL's... Somebody needs to crop the face off the 2nd one and paste it over the 1st one's... Best of both worlds!!!
Thanks guys!
absoluteclint is offline   Reply With Quote
Old 11-21-2012, 01:18 PM   #49191
mcma111
mcma111's Avatar
Oddometer: 11,905
Leave the oil separator on. There is nothing to be gained by removing it. The hose for the separator goes from the engine case above the transmission to the separator and then the air box. Mr Honda put the separator on for a purpose. Don't mess with it. I have a buddy here at work whose bike is pissing oil all over the place when he parks it because the PO removed the separator. Truth be told I think the rings are bad in his engine there is so much oil coming out of it. Blow by is preasurizing the lower end and sending the oil mist to the air box. With the separator at least the oil would flow back to the engine instead of losing it.
The block off plates can go on dry. There are seals on the cylinder for the plumbing that stay in place.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-21-2012, 01:21 PM   #49192
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,821
Originally Posted by ThumpnRed View Post
Speel werds the rite wey
Thats very funny. This is wierden me out man!
Ok, go to Quick links/Subscribed threads, isn't the V message, upper left, orange?
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 11-21-2012, 01:37 PM   #49193
absoluteclint
Oddometer: 206
Thanks Steve... The oil separator will stay put. The image of losing oil is enough to leave it alone!
Regarding the tubing... See picture #24
http://www.4strokes.com/tech/honda/xrlsmog/
It's the tubing coming from the bottom of the airbox vent... Where his pencil is pointing that I'm in question about. My tubing from the top of the airbox vent goes to the separator and then on to the top of the transmission... I'm assuming this tubing will stay in place. From what I can see... after I remove the smog pieces I'll be left with an open lower airbox vent.
Maybe my kit will come with a large rubber plug... Like picture #19... And I need to plug the lower end of the airbox vent instead of the top end (like pic #19 shows)??? Makes sense???
Old 11-21-2012, 01:51 PM   #49194
mcma111
mcma111's Avatar
Oddometer: 11,905
Plugging the lower port on the air box sounds correct but I don't have my bike near by to go look at.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-21-2012, 01:54 PM   #49195
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,227
I'm loosing a lot of oil through the airbox. All of what I'm "leaking" I imagine.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 11-21-2012, 02:07 PM   #49196
Lane_N
Pig Wrangler
Lane_N's Avatar
Oddometer: 87
[QUOTE Maybe my kit will come with a large rubber plug... Like picture #19... And I need to plug the lower end of the airbox vent instead of the top end (like pic #19 shows)??? Makes sense???[/QUOTE]
That is right. I fabbed my own plug out of aluminum, but you will need to block this bottom port off somehow.
Lane_N is offline   Reply With Quote
Old 11-21-2012, 02:18 PM   #49197
absoluteclint
Oddometer: 206
Excellent... Thanks guys! Still anxiously awaiting the big brown truck. I just checked the tracking number and saw this message "An exception in the sorting process has occurred. UPS has taken corrective action." I guess the new verbage for error or mistake is "exception!" Who knows... might be tomorrow or Fri before I get to tinker.
Old 11-21-2012, 03:01 PM   #49198
pngaudioguy
Just...one...more...
pngaudioguy's Avatar
Oddometer: 486
Whatever you're smokin', I want some! The only "V message" I can find is "View all subscribed threads", which is decidedly underlined white. Try checking to make sure you didn't enable some kind of accessibility features or accidentally pick a different theme for the site - this new version has multiple themes, you know. Other than that, reboot and have another beer while you wait .
pngaudioguy is offline   Reply With Quote
Old 11-21-2012, 03:07 PM   #49199
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,516
Right there with you... those moments of sudden, unexpected sobriety can be a bitch! I need another beer
Old 11-21-2012, 04:59 PM   #49200
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,286
Am I the only one getting the double underline in orange link shit? ( see above post, shrink tube as an example)
What do I do to end?
You been drinkin again Fritz......
Try this beer,,gotta be better than that crap you drink..
B
techforlife is offline   Reply With Quote
Times are GMT -7.   It's 09:38 PM.
