11-21-2012, 02:07 PM
#49201 | ||
Pig Wrangler
Oddometer: 1,607
11-21-2012, 03:59 PM
#49202 | |
CDI REPAIR
Oddometer: 3,421
Try this beer,,gotta be better than that crap you drink.. ![]() ![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.FCR MX pumper.42/158 NVCT needle.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
11-21-2012, 04:09 PM
#49203 |
Oddometer: 8,162
I'm on my second one of these. Feeling the effects already.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
11-21-2012, 04:29 PM
#49204 | ||
Pig Wrangler
Oddometer: 1,607
11-21-2012, 04:38 PM
#49205 |
Oddometer: 8,162
I'm gonna beat all of you FF's to the punch.
Happy Thanksgiving ![]() ![]()
11-21-2012, 04:51 PM
#49206 |
Oddometer: 4
Thanksgiving weekend ride coming up but I have one problem...I just installed a FMF powerbomb header and its connecting to a Q4 pipe. Problem is that even though I used high temp silicone on the header before I jammed it in the pipe, I have a leak at the joint. I don't know if it's because I fired the bike up with the silicone still wet or what. Should I clean the surfaces, use an assload of silicone and let it dry overnight? This is a common pipe/header combo and I can't find much info on leakage.
11-21-2012, 04:55 PM
#49207 |
Oddometer: 8,162
Remove the muffler and clean both the header and muffler joints. Apply sealant and assemble. Let dry overnight.
Done...
11-21-2012, 04:57 PM
#49208 | |
Oddometer: 4
11-21-2012, 05:13 PM
#49209 | ||
Pig Wrangler
Oddometer: 1,607
11-21-2012, 05:49 PM
#49210 | |
Enjoying my last V8
Oddometer: 5,414
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, Google: TX7 |
11-21-2012, 05:54 PM
#49211 |
Enjoying my last V8
Oddometer: 5,414
Ya know, maybe your oil pump is not moving the oil out of the engine like it should. Have you made the check of the pump by removing the bolt in the clutch cover while the bike is level on a stand and running? If oil gushes out the pump is not pumping well.
11-21-2012, 06:00 PM
#49212 |
Oddometer: 38
Usd
I know this has been discussed at some length , but I am looking at maybe an early x- mas gift
I was wondering from those who have made the swap, what they felt was the best route to follow on this. Which triple clamps are the easiest and provide the best results? Cut up stockers, emig, rsw? 250. or 450 forks, I have the acerbics tank( if weight is involved in the equation ) and I weigh over 200 ![]() I appreciate the feed back, just trying to make the swap as simple as possible so I do not fall into paralysis by analysis syndrome. Which I found is profoundly exacerbated through the consumption of said beverages.
2007 XR650L, Dave's carb mod's, XR'S only smog kit, XR'S only skid plate, Acerbis 5.8 tank, CRF 450 front fender... |
11-21-2012, 06:03 PM
#49213 |
I'm Going Racing!!!
Oddometer: 18,876
rsw is quickest and easiest as everything bolts right up all you need to do is press stem out of old and into the new clamps... careful it only goes one way
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died. |
11-21-2012, 06:29 PM
#49214 | |
bout a dollar 3.98
Oddometer: 3,068
RSW clamp with The CRF-X front wheel .
Marko 08 xr650l 99 xr650l 84atc200s 85atc200s 80ct110 99xr70 04xr50 85atc70 87trx70 Dumb ass people do dumb ass things
11-21-2012, 06:54 PM
#49215 |
Oddometer: 4
hmm
