Old 12-20-2012, 07:38 PM   #50416
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Originally Posted by mcma111 View Post
Sierra,
Turn around and walk away from a Hot Cam
You have been warned.
Originally Posted by prince_ruben View Post
Preach!
Sent from my DROID RAZR using Tapatalk 2
X3.
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Old 12-20-2012, 07:54 PM   #50417
Ulyses
Ulyses's Avatar
Oddometer: 694
Originally Posted by purpledrake View Post
Hey, Ulyses,
No. I am focused on the Olympics (my backyard) and the Cascades. I can get to either by bike or truck, and summertime climbing fulfills the dual purpose of scouting for rifle season in the autumn. Drag your brother up here sometime; I am always looking for riding/climbing partners. There are a ton of XRL inmates on this site who live within a day's ride of these climbs. I am sure that we could put together an interesting weekend of fire road riding + hiking/climbing. Something tells me that WBedient has an arsenal, which would add some interesting flavor to a ride.
PD
Yes, I think that we definetly need to involve guns in this trip. Maybe we could fire at pre-set targets from our bikes as we ride to the trailhead....
The sad thing is that if I dragged alvincullumyork up there, we would only have the one XRL to share between us ...... and I don't fancy riding bitch....
Ulyses is offline   Reply With Quote
Old 12-20-2012, 07:57 PM   #50418
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 704
Originally Posted by Ben99r1 View Post
19 to 20 mpg really? What kind of speeds do you drive to get that? I keep my cars and trucks for along time. I have a 99 ford 150 with 198,000 miles. Ill probably keep it for another 4 to 5 years till I pay off my house. I am planning to get a full size diesel something next. I would be ok with something that will get me 20 mpg. Hell I am hoping I get buried in my next truck.
My last trip from Oregon down to Riverside, CA I was driving 70mph pretty much the whole way with the cruise on and I got 19mpg. Around town I get around 15.
It has intake done, 3" downpipe, 4" exhaust, 160cc injectors (stock is 90cc), chip from Power Hungry Performance, and gauges to keep an eye on everything. VERY fun to drive, and great mileage if you keep your foot out of it. One reason for the good mileage is that it weighs a lot less than the newer body style Fords.
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is offline   Reply With Quote
Old 12-20-2012, 07:57 PM   #50419
Brown Falcon
Mossy-Back
Oddometer: 704
Just throw some knobbies on the Harley!
Evan
'93 XR650L (Xena)
Old 12-20-2012, 08:05 PM   #50420
Lonestar2112
Crash test dummy
Lonestar2112's Avatar
Oddometer: 5,197
Originally Posted by nic579 View Post
Hi guys a proud new owner of a low mile basket case that someone drove into a car its in need of a straight front end. It seems to run smoothly with the whir of a sewing machine and the thump of a Huey chopper. The bike has a slip-on but has not been jetted or been opened up on the intake side. I have a UNI filter coming and a selection of jets to do Dave's mod. I am also looking at getting a crf450r front end for the repair but an tempted by the cheeper stock front ends available. Is the $400+ difference worth it for the CRF450 fork and wheel stuff? Plastics are scraped up a bit but good enough and it needs a battery as it holds just enough juice for one start so if you miss back to the charger. Also I read that the suspension linkages should be disassembled and lubed as they can come dry from the factory is this correct? Any other thing I should look at please let me know. I think this would offically be my 4th XR and ,my first XR650L
I am in the process of upgrading my L to the 450 front end. If you can wait a month or so I will have a mostly complete L front end at a reasonable price.
Where am I?
"I love the wild spaces above the border, takes some work to get here, ain’t a Starbucks run." jdrocks
F*CK Cancer
Lonestar2112 is online now   Reply With Quote
Old 12-20-2012, 08:08 PM   #50421
Lonestar2112
Crash test dummy
Oddometer: 5,197
Originally Posted by Sierra Thumper View Post
Hey guys, how much of a difference will an XR's only stage one hotcam make on an otherwise internally stock motor?
The specs are-
INTAKE LIFT: 8.8 mm
INTAKE DURATION: 258°
EXHAUST LIFT: 8.8mm
EXHAUST DURATION: 258°
I'm not sure what the stock lift/duration is....just wondering if the hotcam would make enough of a diff to be worth it money and labor wise? And how much low end, if any, would I give up?
Thanks in advance for any feedback
I was going to buy a 650 with a hot cam. The owner had just installed the new cam as a performance enhancement. The owner used to build bikes for the KTM race team, so I am confident that he did everything right on the install. The bottom line.....less than 1000 miles later he rebuilt the motor and replaced teh cam with a stock one.
I would not touch a motor that had a hot cam in it. YMMV.
Good luck.
Where am I?
F*CK Cancer
Old 12-20-2012, 08:08 PM   #50422
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,295
You can make chain sliders out of pretty much any plastic or rubber. It's a fun project.
OEM front slider for my XRL on right, rubber home made on left with metal locator bracket and sleeve ready to install. Starting raw rubber material at top. The soft rubber does not wear as long as plasitc of course but sure is smooth and silent. I drilled the hole first then cut out on a band saw. A hand saw would work. A little drum sanding to finish.
Here's a plastic rear slider I made a while back. Life is endless but it makes noise like a cajun playing a rubbing board. And some vibration as well. The ridge I routered, the only wear is at the leading edge.
Here's the rubber replacement for the plastic rear slider shown above. Very smoooooooooth. Make the same way as front slider. This one is big enough to drill holes at any time. I put a hump in the front of the rear slider. Once the chain wears into the rubber far enough for the rollers to roll on the rubber surface wear is very slow.
Here's how I came up with the shape'
Finished rubber slider. Assemble with SS screws and lock nuts, 1/4" - 20NC from HDWE store AND lock tight.
Here's a plastic slider I make for an old Husky. Wear is great, noise/vibration is bad. For this one I made a template from the original slider and then cut out the plastic with a copy bit in my router. A little hot bending as well. Another draw back or using hard plasitic I discovered during assembly of swing arm to frame was that you would need to pull the swing arm to repalce slider. That would not be an issue with rubber or urathane material.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM,
fritzcoinc screwed with this post 12-20-2012 at 08:16 PM
fritzcoinc is offline   Reply With Quote
Old 12-20-2012, 08:12 PM   #50423
purpledrake
No Pretensions
Oddometer: 275
Do you mean this? (Yabusame, 流鏑馬)
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 12-20-2012, 08:18 PM   #50424
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
OEM front slider for my XRL on right, rubber home made on left with metal locator bracket and sleeve ready to install. Rubber material at top. The soft rubber does not wear as long as plasitc of course but sure is smooth and silent. I drilled the hole first then cut out on a band saw. A hand saw would work.
Hey fritz,
I got some old husky parts around here.... I sold a swingarm just like that that one this spring. I have a clean O-Neal PJ-1 shock from it and some other odds and ends...
The slider looks good too.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 12-20-2012, 08:31 PM   #50425
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,562
The specs are-
INTAKE LIFT: 8.8 mm
EXHAUST LIFT: 8.8mm
With an otherwise stock motor, I suspect it would make very little difference.
btw... I have had one in my engine for three years now... It is doing just fine. No apocalyptic meltdowns or anything. A guy up the street has had a Hotcam in his XR650R for a couple of years longer. He just rebuilt the top end... valve springs were sacked. The cam still looked great.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 12-20-2012, 08:36 PM   #50426
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,295
The HotCam haters sound like the Wiesco piston conspirators.
But the Hotcam is going top have a more agressive ramp, aye?
Regards
Fritzcoinc
Old 12-20-2012, 08:41 PM   #50427
wbedient
MoTard
wbedient's Avatar
Oddometer: 864
Don't know who I and my firearms got drug into this but... I'm game!
Got lots of good riding and a spare enduro for guests. Bring your own ammo.
wbedient is offline   Reply With Quote
Old 12-20-2012, 10:43 PM   #50428
beechum1
beechum1's Avatar
Oddometer: 4,796
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Helped me with the pinging I was having with the JE102.
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
beechum1 is online now   Reply With Quote
Old 12-20-2012, 11:42 PM   #50429
F250Pal
F250Pal's Avatar
Oddometer: 79
I know a powdercoater.
...and he just sprayed his wheels.
F250Pal is offline   Reply With Quote
Old 12-20-2012, 11:57 PM   #50430
F250Pal
F250Pal's Avatar
Oddometer: 79
Frame Gussets
Right side is weld on. Left side is bolt on. XR6 exhaust can, D606 130/90-18 tire. Plenty of room on both sides.
Times are GMT -7.   It's 03:43 PM.
