Old 12-23-2012, 12:12 PM   #50506
Gone14s
Gone14s's Avatar
Oddometer: 109
Is there a link for Dave's carb mod, I did a search and could not find it. 95 XR650l.
Thanks Kurt
Def. of man:
We spend 9 months trying to get out, and the rest of our lives trying to get back in.
http://s1085.photobucket.com/albums/...900%20elefant/
Gone14s screwed with this post 12-23-2012 at 12:20 PM
Gone14s is offline   Reply With Quote
Old 12-23-2012, 12:14 PM   #50507
The Dogger
Oddometer: 148
Originally Posted by JThompson View Post
Just want to say thanks to Christian, Steve, Mike, Headtrauma, Fritz and everyone else for the advice on the clutch job. I took a little ride this morning and everything worked great, no slipping, no leaks and the bike is shifting smoother than ever.
Cheers,
JT
Hi JT
I noted you said in an earlier post " I'll wait till morning to start it with the the oil line to the head cracked loose."
I was lead to believe you should crack the oil line open after the motor has been running for a short while , rather than crack it before starting the bike.??
Good to hear your bike is running well now
Cheers , Stu
The Dogger is offline   Reply With Quote
Old 12-23-2012, 12:22 PM   #50508
mcma111
mcma111's Avatar
Oddometer: 12,884
Thanks Kurt
http://www.4strokes.com/tech/honda/xr650lcarbmods/
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-23-2012, 01:10 PM   #50509
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Originally Posted by HONDABIKEPRO View Post
here some pic of my xr650l dale
Nice! What's that fairing off of?
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 12-23-2012, 01:24 PM   #50510
JT
JT's Avatar
Oddometer: 352
Originally Posted by The Dogger View Post
Hi JT
Cheers , Stu
Well maybe I did it wrong. I loosened the banjo bolt and cranked it, it fired immediately and about 2 seconds later the oil started blowing out. I immediately shut it down and tightened the bolt. Started it again and it sounded normal. It's running as well as ever and it has about 35000 miles on it. Shifting better than ever too. It used to be difficult to find neutral and a little crunchy on downshifts. Now neutral is easy and the downshifts are smooth as can be.
JT is offline   Reply With Quote
Old 12-23-2012, 01:36 PM   #50511
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
You did well.
I crack the bottom banjo bolt, and crank the engine with the kill switch turned off. If you see any oil issue from the banjo bolt, the pump is primed. If you run the engine with the banjo bolt loose, the oil flow can quickly make a good mess.
Spud
Old 12-23-2012, 01:51 PM   #50512
The Dogger
Oddometer: 148
Originally Posted by Spud Rider View Post
You did well.
Spud
Good point , Spud. Hadn't thought of whizzing it over with the kill switch off.........having said that , mine's a kick only 600 so makes sense ( for me ) to have it running, open the banjo,check the flow and close the banjo, all in one quick move. Quick wipe down , and I'm done.
Cheers , Stu
Old 12-23-2012, 02:19 PM   #50513
HONDABIKEPRO
Oddometer: 14
It is targa fairing.
HONDABIKEPRO is offline   Reply With Quote
Old 12-23-2012, 02:22 PM   #50514
bosley1980
Oddometer: 162
Originally Posted by sub zero View Post
those are for an xt600. They wont fit
i thank you for report
bosley1980 is offline   Reply With Quote
Old 12-23-2012, 02:57 PM   #50515
Mossy-Back
Brown Falcon
Mossy-Back's Avatar
Oddometer: 1,657
Cheers,
JT
Glad it went well! I should be doing mine later this week sometime as long as I can get the gasket and o-ring.
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 12-23-2012, 02:57 PM   #50516
Mossy-Back
Brown Falcon
Mossy-Back's Avatar
Oddometer: 1,657
That's a pretty sweet looking XR there. How's the handling on and off road with the 17's on it?
'05 CRF450X
Old 12-23-2012, 03:10 PM   #50517
kubiak
Oddometer: 4,845
super nice setup!
Old 12-23-2012, 03:27 PM   #50518
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 815
here some pic of my F800GS dale
ur in the wrong thread dood!!! you should be posting in the forum containing these kinda bikes!
1994 WR250-Z | 1997 KX500 | 1998 KLX300 | 2004 CRF450R (Motard) | 2009 KX450F | 2001 XR650R | 1992 WR200R | 1992 WR500-Z | 1986 GPZ900 | 2005 RMZ450 | 1986 CR500AF in a 1998 CR250R frame | all street legal
"Great! What am I supposed to use now?! Harsh language?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 12-23-2012, 03:56 PM   #50519
Gone14s
Gone14s's Avatar
Oddometer: 109
Originally Posted by mcma111 View Post
Thanks Steve.
Kurt
Def. of man:
Old 12-23-2012, 05:27 PM   #50520
Sierra Thumper
Oddometer: 641
Yep thats a beautiful set-up xrl adventure-tourer......but it would never survive my kinda riding, I'd either kill the bike or it would kill me
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Times are GMT -7.   It's 05:19 PM.
