Old 12-24-2012, 05:21 AM   #50536
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Originally Posted by purpledrake View Post
Thanks a bunch, MentalGuru
Anytime.
This is engine fogger. Spray into carb while cranking the engine.
http://www.amsoil.com/shop/by-produc...e-fogging-oil/
With a steel gas tank I would fill and add stabilzer. Drain a plastic one.
Geese should work great. Swans are even better... They are mean...
xladv.com
MentalGuru is offline   Reply With Quote
Old 12-24-2012, 05:54 AM   #50537
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Originally Posted by junkyardroad View Post
Check this out. I was several miles up a box canyon north of Moab with my son when I just knew I could climb this dune. Was going great until my loose chain jumped on the rear sprocked and siezed it hard. 5 miles from the Jeep in ankle deep sand. We rode out on his CRF230 and were able to retrieve it after dark. Then we went for pizza and beer. Love this pic.
I almost had a similar thing happen climbing a sandy hill on my old '91 WR250. I made it to the top and after I turned to go back down, the bike stalled and wouldn't start until I got it in neutral. Then it would barely roll down the hill. When I got to the bottom, the chain was bow-string tight from sand. I managed to get it rolling and stopped about fifty yards down the trail where there was a stump I could lean the bike against. By then, the sand had worked itself out so I kept riding but headed home. Later on, the chain and sprockets got a good cleaning but I had no other issues. I also didn't try that hill climb again.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 12-24-2012, 06:55 AM   #50538
Kawidad
Kawidad's Avatar
Oddometer: 4,968
Originally Posted by Brown Falcon View Post
Can anyone verify that this is the correct Moose Racing gasket to replace the factory gasket p/n 11394-MY2-621 ???
http://www.powersportsuperstore.com/...tm?Click=35177
And has anyone used the Moose gasket? Good, bad, ugly? It would be nice to pay $5 instead of $30...
Just avoid Tusk gaskets from Rocky Mtn ATV. They are Chinese crap and leak badly. A total waste of time and money!
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 12-24-2012, 07:18 AM   #50539
AZ TOM
Oddometer: 4,074
OEM the best. Moose good & have not used any others.
AZ TOM is offline   Reply With Quote
Old 12-24-2012, 01:13 PM   #50540
RZRob
RZRob's Avatar
Oddometer: 1,693
Happy Christmas....
To me .
Just found this deal on a "fresh" XRL too good to pass-up. It's like getting a second chance... I'm thrilled!
RZ Rob
RZRob is offline   Reply With Quote
Old 12-24-2012, 01:22 PM   #50541
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Originally Posted by RZRob View Post
To me .
RZ Rob
Nice score!!!
xladv.com
Old 12-24-2012, 01:43 PM   #50542
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,652
Originally Posted by Ben99r1 View Post
I am using one now. It has not giving me any problems in 2000 miles. Just make sure you remove all the old gasket.When you remove the clutch cover lookout for a dowel that sits on the oil pump.
Thank you. I'll probably pick up the new o-ring from the honda shop for that oil tube.
Thanks, I'll stay away from them.
I still might go OEM. Depends on if they have it in stock.
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 12-24-2012, 03:21 PM   #50543
my6
my6's Avatar
Oddometer: 380
Laugh
To me .
RZ Rob
Sweet. Merry Christmas, but it looks like you all ready knew that.
Check your Six
04/625 SXC
98/200/MXC
my6 is offline   Reply With Quote
Old 12-24-2012, 03:26 PM   #50544
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,331
Merry Christmas guys........
B
techforlife is offline   Reply With Quote
Old 12-24-2012, 04:38 PM   #50545
RZRob
RZRob's Avatar
Oddometer: 1,693
Originally Posted by MentalGuru View Post
Nice score!!!
I'm all jolly. It even has the factory tool kit and owner's manual including lanyard cable extension to helmet lock. Hopefully I can flip my old bike soon enough to not feel the pain.
RZ Rob
Old 12-24-2012, 05:36 PM   #50546
RZRob
RZRob's Avatar
Oddometer: 1,693
Question for the Clan
So like I've got this XRL motor that was in my old XR when I bought it. Low miles, but due to monkey service by PO, they broke the cam gear bolts and munched the top gear. So I changed the top gear, chain, guides and tensioners.
Engine develops a bit of a top-end rattle after a half hour or so of riding. I'm thinking when the oil gets up to temperature. My suspicions are worn rubber o-ring on right side cover causing low oil pressure (I didn't change this when I had it apart) or possibly the wrong spring under the pressed-on cam gear (things went flying in the garage when I pressed it off). Does anyone have an actual photograph of the cam decompressor springs (not parts drawing)? Engine seems to run good though.
Any thoughts?
Old 12-24-2012, 06:08 PM   #50547
mcma111
mcma111's Avatar
Oddometer: 12,535
Any thoughts?
Your fucking killing me. Now I have to break out the camera and take the cam apart.
Hold on, it'll be a while.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-24-2012, 06:36 PM   #50548
techforlife
CDI REPAIR
Oddometer: 4,331
B
Old 12-24-2012, 06:59 PM   #50549
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,561
I always wanted to see what the insides looked like. Now I wont have to tear my spare apart.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 12-24-2012, 07:15 PM   #50550
mcma111
mcma111's Avatar
Oddometer: 12,535
XR/XRL Cam Decompressor Assembly
The above picture shows the spring and roller at the 2' position incorrectly. The roller should be on the other end of the spring. It fell apart and I installed it incorrectly.
The above picture shows the correct orientation of the rollers and springs.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 01:50 AM.
