Old 12-25-2012, 10:19 AM   #50566
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,330
Originally Posted by therealbigman View Post
Merry Christmas Yall , .
Hmmmmmmmmmmm drinkin already eh..........
K.......... i`m in
B
techforlife is offline   Reply With Quote
Old 12-25-2012, 10:53 AM   #50567
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,411
Merry Christmas Everyone!!
A little video from a few months ago when Heywood and I went to "La Presa Rodriguez" here in TJ.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 12-25-2012, 11:21 AM   #50568
Haywood
Haywood's Avatar
Oddometer: 401
Merry Christmas!
Thanks for the video!
Haywood is offline   Reply With Quote
Old 12-25-2012, 12:04 PM   #50569
Break_Syncro
Oddometer: 189
Merry Christmas to you all!
Ride safe!
'95 XR650L - Dave's Mod and de-smogged, XRs Only header with XR600R muffler , XRs Only temp gauge, Twin air filter, CRF USD Fork with RSW clamps, Acerbis CRF vented front fender, MSR brush and hand guards, Trail Tech temp gauge, Acerbis 5.8 gal tank, XR400R oil cooler, D606 tires for dirt! Excel sumo wheel ! EBC 320mm Sumo front rotor for street carnage! Thanks to you all the your help!
Break_Syncro is offline   Reply With Quote
Old 12-25-2012, 12:10 PM   #50570
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,644
Merry Christmas everyone! I hope you have a wonderful and blessed day!
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 12-25-2012, 12:47 PM   #50571
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
Originally Posted by snofrog View Post
I am considering an XRL for its off road bias . Being air cooled, is it ever an issue with heat and riding slowly or idling ? thanks , Mark
Yes it can be an issue. When you are working it hard in slow tight stuff, it's a good idea to stop and rest once in a while (I am usually ready for a break and use the bike as an excuse)
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 12-25-2012, 02:21 PM   #50572
purpledrake
No Pretensions
Oddometer: 334
Originally Posted by MentalGuru View Post
Anytime.
This is engine fogger. Spray into carb while cranking the engine.
With a steel gas tank I would fill and add stabilzer. Drain a plastic one.
Geese should work great. Swans are even better... They are mean...
Thanks again, MentalGuru. I didn't know about this. I will get some ASAP.
PD
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 12-25-2012, 02:30 PM   #50573
purpledrake
No Pretensions
Oddometer: 334
Originally Posted by mcma111 View Post
RZRob,
Spring #6 can become a problem when it loses it's tension. My son's bike would not start when cold and I found that the engine would rotate around to TDC with a pressurized cylinder and not be able to get past TDC due to the decom not opening the right exhaust valve. I finally replaced that little spring and the engine would start normally again. I have a buddy's bike that is doing the exact same thing and we will be replacing the spring this coming week.
Boy I wish that I lived close to you. I could really grow into the buddy role.
Old 12-25-2012, 02:33 PM   #50574
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,619
Merry Christmas all.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 12-25-2012, 04:53 PM   #50575
RZRob
RZRob's Avatar
Oddometer: 1,657
Replacing Spring #6
Okay, been there before. Spring 6 was new I think maybe...I'd replace it again, but pressing that gear off/on again sounds like a real bitch.
RZ Rob
RZRob is offline   Reply With Quote
Old 12-25-2012, 05:02 PM   #50576
mcma111
mcma111's Avatar
Oddometer: 12,403
RZ Rob
You only need to move the cam chain sprocket over about 1/4" to access the spring.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-25-2012, 06:02 PM   #50577
super samurai
super samurai's Avatar
Oddometer: 316
Originally Posted by Spud Rider View Post
I don't think my oil temperature has exceeded 290 degrees Fahrenheit since I installed my Spud Oil Cooler. My XR650L will only approach that oil temperature when I am ascending very long, steep mountain trails, or riding WOT down the freeway for 35 miles, or more. However, it's not hard to exceed 275 degrees while climbing 2,500-4,000 vertical feet in the Rocky Mountains. If you can keep oil temperatures below 275 degrees, that's great. However, I think 300 degrees is a very practical, maximum temperature which will still prevent heat degradation of the engine oil.
If you remove the stock air scoops, and ride the bike hard, an oil cooler is a very wise investment. The oil cooler not only reduces oil temperatures while riding; it also cools the oil much more rapidly after you stop the engine. My oil cooler not only radiates heat from the cooler itself and its external oil lines; as the external oil cools it also reduces the oil temperature in the reservoir to which it is connected. At any given time, a large amount of the engine oil resides in the oil reservoir and downtube. Therefore, an oil cooler will greatly reduce operating oil temperatures after you restart the bike, and the much cooler, external oil is returned to the engine.
If anyone is interested, here's a link to the installation thread for my Spud Oil Cooler, which costs less than $100 to fabricate.
http://www.advrider.com/forums/showthread.php?t=781962
Spud
so i am ordering the same cooler you have tonight spud. i am gonna run some bent stainless lines only cuz i have it.
could you post up a close up pic of your final fender mod. got lost in your write up as to how much you trimmed and final slots. also do you think it would matter if the lines from the cooler were pointed up?
i know my clear tank is ugly!
super samurai is offline   Reply With Quote
Old 12-25-2012, 06:56 PM   #50578
super samurai
Oddometer: 316
Wicked
Ohh and the spud cooler oil cooler is now $32.00
It was $29 when spud did his.
Old 12-25-2012, 08:18 PM   #50579
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,622
Merry Christmas folks, hope everyone had a great Christmas.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 12-25-2012, 08:45 PM   #50580
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,411
Here's another vid from June. Me solo. This is 20 minutes of the border on the south side of TJ.
Times are GMT -7.   It's 06:01 AM.
