Old 12-27-2012, 07:17 AM   #50611
Gone14s
Gone14s's Avatar
Oddometer: 86
Originally Posted by sc-razor View Post
I like my Acerbis 5.8. Almost the same look and ability to carry enough fuel for everyone!
Because of you Steve I put a spit fire windscreen on my bike. Made a world of difference when riding in the winter. Needless to say it does not look bad and is a good fit.
Kurt
Def. of man:
We spend 9 months trying to get out, and the rest of our lives trying to get back in.
http://s1085.photobucket.com/albums/...900%20elefant/
Gone14s is offline   Reply With Quote
Old 12-27-2012, 07:21 AM   #50612
sc-razor
sc-razor's Avatar
Oddometer: 3,463
Kurt
Cool! This was my second trip to Colorado and I didn't have it the first time. We are are notorious for getting lost and ending up 150-200 miles from the house at 4pm and have to slab it back. That windscreen made all of the difference in the world and I actually don't mind the looks of it either.
2009 XR650L
Steve
sc-razor is offline   Reply With Quote
Old 12-27-2012, 08:52 AM   #50613
Gone14s
Gone14s's Avatar
Oddometer: 86
May I suggest a tip for you.
I drilled 2 holes in each lower corner of the windscreen. I'm sure as you notice that as you ride the screen bouces and vibrates a lot on the mounts. With the 2 holes drilled I mount the lower screen to the wind deflector above the head light with screws and plastic and rubber washers and wing nuts. It made the screen very solid with no vibration and you can still do a quick removal when you want. It also keeps the stock screen mount from coming loose as you ride on trails.
Even with the 2 lower mount points you can still loosen the upper screen mounts and tilt and adjust the screen to a point.
Even with lock tight in the mount crews on the stock mounts, when trail riding, it managed to shake itself loose.....not anymore!!!!!!
Kurt
Def. of man:
Old 12-27-2012, 09:40 AM   #50614
ONandOFF
Must / takeit / easy
ONandOFF's Avatar
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,407
Originally Posted by MentalGuru View Post
...CRF plastics with a stock tank.... .
Hmmmmm...
I don't get it.....
Does this look better than stock? Better than the standard mods? (Clarke tank etc)
Who looks at the bike? Only when I'm working on mine do I look at it... and others only get to look at it when helping me get it back upright or when stopping for a break, but we're usually checking out the view, and the mechanical condition, not the artistic lines of the bikes...
Aesthetics are about the last of the priorities I'm concerned about for my dirt bike.
Let's ride!!!
- No offense, but there've been a lot of people over time who were just as sure, but got it wrong.
- Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad.
ONandOFF is offline   Reply With Quote
Old 12-27-2012, 09:52 AM   #50615
ONandOFF
ONandOFF's Avatar
Oddometer: 4,407
I drilled 2 holes in each lower corner of the windscreen. I'm sure as you notice that as you ride the screen bouces and vibrates a lot on the mounts. With the 2 holes drilled I mount the lower screen to the wind deflector above the head light with screws and plastic and rubber washers and wing nuts. It made the screen very solid with no vibration and you can still do a quick removal when you want. It also keeps the stock screen mount from coming loose as you ride on trails. ..Kurt
This must be what I missed. It was great on the 20 min. ride out to the mountains. But it didn't quite make it to the top of the first ridge; I had to take it off and carry it out in three pieces!
Let's ride!!!
Old 12-27-2012, 09:57 AM   #50616
sc-razor
sc-razor's Avatar
Oddometer: 3,463
Kurt
Good idea. Yeah, when on trails mine kept coming loose so I finally used Gorilla tape on the wing nuts to keep them from backing out for a temporary fix.
2009 XR650L
Steve
Old 12-27-2012, 10:03 AM   #50617
Gone14s
Gone14s's Avatar
Oddometer: 86
Agreed, Mine would come loose after a few min's on the trail. With the lower screen mounted to the head light upper fairing it stays put now. In the summer I take it off. Don't really have to but I like the fresh air in the summer. Really makes riding at high speed nice though. Our upper bodies act like a wall moving against the wind with out it.
But to each his own.
Kurt
Def. of man:
Old 12-27-2012, 10:03 AM   #50618
sc-razor
sc-razor's Avatar
Oddometer: 3,463
I don't get it.....
I'd say there's not a pair of our bikes exactly the same. It's all about what "you" like and what works for "you". Some are about looks, some are about function, some are about both. I like mine, but there are plenty here I like more or better and I plan on using some of those ideas in the future too.
2009 XR650L
Steve
Old 12-27-2012, 10:08 AM   #50619
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
I don't get it.....
I saw that picture and thought wtf. I figured I'd post it for kicks...
Function first is how I think... That mod probably has no benefits and just adds things to break...
What I want is the custom tank kubiak built.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 12-27-2012, 10:10 AM   #50620
Gone14s
Gone14s's Avatar
Oddometer: 86
Yes sir, it does get to be a pain in the butt to have to stop and tighten them all the time. I also added a 2 1 inch plastic spacers between the windscreen and the fairing. This allows a little bit of air to come up from behind the windscreen.
Kurt
Def. of man:
Old 12-27-2012, 10:14 AM   #50621
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
We are all special in some way....
Old 12-27-2012, 10:21 AM   #50622
sc-razor
sc-razor's Avatar
Oddometer: 3,463
No question which one I am in that pic!
2009 XR650L
Steve
Old 12-27-2012, 10:34 AM   #50623
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,151
Originally Posted by Brown Falcon View Post
The TUSK hand-warmers don't seem to fit over my handguards, and the stitching on one broke just trying to slide it on.
Love mine.... Mine are over Cycra's and the other bike has Acerbis Hand-guards. They work well with both... with slight modifications.
West - "Oeste Sanchez"
"I keep telling myself I'm getting too old for this kid stuff, then my natural immaturity takes over." Pluric
RideAbout is offline   Reply With Quote
Old 12-27-2012, 11:27 AM   #50624
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,606
I don't get it.....
I dont get it either. Although... I did put CRF fenders on my bike purely for aesthetics, so I shouldn't get to slinging too much judgement around
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 12-27-2012, 11:29 AM   #50625
Sierra Thumper
Oddometer: 641
Question How much to jet up for aftermarket header?
I'm thinking of possibly sticking an aftermarket header on my xrl to go with my big gun muffler and Daves mods/desnorkeled/desmogged/uni filter. I live and ride at 5000ft and up. I'm currently running a 58 pilot and 155 main jet, and the bike runs great. Plug color is good, maybe slightly rich with a dark tan/light chocolate color.
I'm wondering if I could just stick the header on, or would it make a big enough difference I'd need to jet up some more? Thanks in advance for any and all feedback
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Times are GMT -7.   It's 02:43 AM.
