Old 12-28-2012, 09:52 PM   #50716
KyoXR
KyoXR's Avatar
Oddometer: 402
Originally Posted by Spud Rider View Post
Thank you, Red. I looked online at AutoZone and O'Reilly, but I can't find that flasher anywhere. Do you remember approximately how much it cost?
Spud
I bought one of those for my bicycle to put turn signals on it to "dumb it down" for the masses around me, the two prong relay cost $7.99 at the time, the closest I could find now online is: http://www.oreillyauto.com/site/c/se...0381/C0335.oap
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
KyoXR is offline   Reply With Quote
Old 12-28-2012, 09:52 PM   #50717
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,562
Originally Posted by bwalsh View Post
I told ThumpnRed I was electrically illiterate. I was right!
So the resistor/flasher is for the low setting? If so then why is it on the wire that goes to the "hi" side of the switch? That's what is throwing me for a loop.
Thanks Guys! I couldn't have re-engineered these grip heaters without you!
Anyway...I got heated grips!!!
The switch is confusing. Look at the pole that the bottom of the toggle points to.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 12-28-2012, 09:54 PM   #50718
bwalsh
Oddometer: 7,706
Red got it right. When the top of the switch rotates to one side, the contacts in the body of the switch connect on the opposite side.
Spud
OK, I just figured it out. Duh!
That flasher I posted is also carried by Advance auto for the same price, $6.99.
2004 XR650L
1992 Specialized Stump Jumper FS
NWVA TAG
NWVA TAG MAP
RTE THREAD & IN LIST
bwalsh is online now   Reply With Quote
Old 12-28-2012, 10:00 PM   #50719
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,562
Old 12-28-2012, 10:06 PM   #50720
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Thank you, Kyo. I found a great flasher for $9.49 at NAPA. It has two terminals, and a service life of 400 hours.
http://www.napaonline.com/Catalog/Ca...D12_0335211065
Those relays you posted are excellent values! The highest current draw should be under 3 amps, so those heavy-duty relays are more than capable of handling the current.
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Old 12-28-2012, 10:09 PM   #50721
bwalsh
Oddometer: 7,706
Originally Posted by ThumpnRed View Post
Whooooosh! Right over my head!
Now, back to drinking...
2004 XR650L
NWVA TAG
NWVA TAG MAP
bwalsh screwed with this post 12-28-2012 at 10:19 PM
Old 12-28-2012, 10:19 PM   #50722
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
...Now, back to drinking...
It's important to keep your priorities in order.
Spud
Old 12-28-2012, 10:23 PM   #50723
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,562
You took a break from drinking?! What the heck?! If you cant type and drink, you need to give up this internet crap.
Old 12-29-2012, 04:50 AM   #50724
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,298
Originally Posted by mcma111 View Post
Am I going to tell all of you guys ALL of my secrets ???
I bet you've forgotten quite a few already so don't worry about it.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is online now   Reply With Quote
Old 12-29-2012, 07:06 AM   #50725
AZ TOM
Oddometer: 2,364
Am I going to tell all of you guys ALL of my secrets ??? [/QUOTE]
No, just where you keep that extra Renazco seat so when I do my breakin to steal the seat I know where to look. I will have my pockets full of treats for the guard also
AZ TOM is offline   Reply With Quote
Old 12-29-2012, 07:31 AM   #50726
mcma111
mcma111's Avatar
Oddometer: 7,965
No, just where you keep that extra Renazco seat so when I do my breakin to steal the seat I know where to look. I will have my pockets full of treats for the guard also[/QUOTE]
It's in a box on the shelf with the extra helmets above the Harley.
But you'll have to get past these guys first.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-29-2012, 08:18 AM   #50727
AZ TOM
Oddometer: 2,364
This looks like a full bag of treats mission
Old 12-29-2012, 08:57 AM   #50728
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Rocky Mountain ATV/MC has the MSR Tire Changing Stand on sale for $84.99. I own a stand almost identical to this, and it is excellent.
http://www.rockymountainatvmc.com/p/...changing+stand
After you use a tire changing stand, you will never again want to change tires on your hands and knees.
Motion Pro changed the design of the new "bead buddy." The Tusk "bead buddy" still has the original, superior design, and costs $4 less.
http://www.rockymountainatvmc.com/p/...Tire-Bead-Tool
Along with the above items, purchase a valve core remover and three tire spoons, and you will have everything you need to change you own tires.
The following videos demonstrate an easy way to change tires. I use these techniques, and they work exactly as demonstrated.
Spud
Old 12-29-2012, 09:03 AM   #50729
XR BADGER
XR BADGER's Avatar
Oddometer: 38
Tire
Might I inquire what some of you are running for a rear tire ? I tried to order a D606 140 from cycle gear and they replied it was no longer available . So, do I run the D606 130, or is there another 140 that I should look into? On another note note, just installed the Easton EXP freestyle bars, not sure yet how I like them, really like the height when on the bike, very tall when trying to get on the bike. They do not have much pull back, which makes standing up nice, but may be a little much while sitting. Anyway, let you know, as I get some more miles on it.
2007 XR650L, Dave's carb mod's, XR'S only smog kit, XR'S only skid plate, Acerbis 5.8 tank, CRF 450 front fender...
XR BADGER is offline   Reply With Quote
Old 12-29-2012, 09:26 AM   #50730
Memnok
Fly high, go far.
Memnok's Avatar
Oddometer: 341
Send a message via Yahoo to Memnok
I grew up with Boxers, they are just big softies. All they want to do is be your friend. I keep telling my wife our next dog will be a boxer, but she wanted a Lab. Labs are just too emotionally needy for me.
Clint >>> 2007 XR650L <<<
Good government is no substitute for self-government. Mahatma Gandhi
That government is best which governs least, because its people discipline themselves. - Thomas Jefferson
Memnok is offline   Reply With Quote
Times are GMT -7.   It's 06:15 PM.
